Question about Canon PIXMA MP830 All-In-One InkJet Printer
Error inner cover open I have checked it many times and appears to be closed. what is wrong???
  • Canon Master
  • 1,297 Answers
Check the cover sensor actuator.
Posted on Apr 20, 2013
SOURCE: Inner Cover error on Canon PIXMA ip4300 printer
This is a "Sensor" issue, there is a sensor that detects when the Cover is closed, this is either faulty, not being activated, or being activated but not registering at the CPU. Sometimes it is an actual switch, others it is a hall effect sensor, optical, magnetic sensor or the like. Have a squiz and see if ya can see any sensor etc. maybe its blocked etc. Otherwise I think it's gonna have to go 4 repair.. If so get a firm "Quote" B4 allowing them to proceede.
Posted on Aug 01, 2007
eagle338
  • 4889 Answers
SOURCE: error is inner cover is open.
The "inner cover" can be seen if you open the paper output door, which you have to do to open the "printer cover" to get inside the machine and install the ink cartridges. The inner cover is a black bar right inside here. Push it up firmly enough , and it will snap up.
Regards,
Sai.
Posted on Mar 15, 2008
  • 5 Answers
SOURCE: my mp600 keeps saying close inner cover-which is closed
I had the same issue, turning off didn't solve it.
There's a plastic flap the width of the print tray just inside that I flipped up and it solved this problem. It is directly in front of the ink tanks. I'm assuming we flipped it down and forgot about it. It seems it needs to stay up, although you wouldn't notice it when it flips down when you close the top, as it closes just fine with it down. It's easy to overlook. This took me a few hours to realize.
The top of the flap has a half circle cut out of it in the middle.
Posted on Dec 18, 2008
  • 413 Answers
SOURCE: Error Number : 1851 Printing cannot be executed
Try this Canon site for MAC driver.
http://support-au.canon.com.au/EN/search?v%3aproject=ABS-EN&binning-state=model%3d%3dPIXMA%20MP500%0Amenu%3d%3dDownload%0Aos%3d%3dMac%20OS%20X&
Posted on May 04, 2009
huntwolfe
  • 20 Answers
SOURCE: Canon Pixma ip3000 flashing amber 6 times
If the 6 flashes are accompanied by an on screen message #5400, this is a "Service Call Error" code.
This code indicates the following;
Internal temperature error [5400]
The solution to this is the following part replacementl
- Logic board ***'y (QM2-1548) *1
*1: Before replacement of the logic board ***'y, check the waste ink amount (by service test print or EEPROM information print). If the waste ink amount is 7% or
more, also replace the bottom case unit (QM2-1205) or the ink absorbers (QC1-4222 / 4223 / 4224 / 4263 / 4264 / 4864 / 4221 / 4257) when replacing the
logic board ***'y.
[See Section 3-3. Adjustment / Settings, (6) Service mode, for details.]
Good luck!!!
Posted on Oct 02, 2009
What's E00025-2c0
Error in Cover Sensor (PS14) in M Toner Container
Description Unable to detect opening of the Toner Container Inner
Cover when removing the Toner Container.
Remedy Identify the cause of the error whether it is due to link
mechanism to open the Toner Container Inner Cover or
problem at the Toner Container Inner Cover Sensor side. ?
1. Perform the user mode (Adjustment/Maintenance>
Replace Specified Toner) to check if the Toner Container
Inner Cover opens normally (damage, slide of shaft area,
etc.). ?
2. Check if the Toner Container Inner Cover Sensor is
soiled and the installation of the sensor. ?
3. Check the service mode (COPIER> I/O> DCON> P024
bit9) to see that the output value of the Toner Container
Inner Cover Sensor is changed normally when opening/
closing the Toner Container Inner Cover. ?
If it is normal, the value becomes 0 by rotating the Set-on
Drive Shaft with the attached tool and opening the Toner
Container Inner Cover. When closing the Toner Container
Inner Cover by hand, it becomes 1. ?
3-1. When the Toner Container Inner Cover is not opened
although the Set-on Drive Shaft rotates, check the drive
system from upstream (Set-on Drive Unit -> Hopper Unit
-> Bottle Base Unit -> Toner Container Inner Cover Unit). ?
If it is damaged, replace the damaged part and then
perform step 5 and later steps. ?
3-2. When the output value is not changed normally
although the Toner Container Inner Cover can be opened/
closed, check the Sensor Harness (to see if the harness
is caught, disconnected or physically removed, *including
the Relay Connector). ?
If there is no problem, replace the sensor. After checking
the output value in step 3, perform step 5 and later steps. ?
4. If the problem is not solved by replacing the foregoing
parts, replace the Drum Driver PCB (UN4) and then
5. Clear the error in service mode (COPIER>
FUNCTION> CLEAR> ERR), and then turn OFF and then
ON the main power. ?
6. Replace the toner (reinstall the removed Toner
Container) at least once in user mode (Adjustment/
Maintenance> Replace Specified Toner), and check that
toner replacement can be performed normally.
Sep 24, 2014 | Canon imageRUNNER ADVANCE C5051
Problem with my Canon Pixma MP500
Try a hard reset first: Unplug the printer from power source and PC, wait about 5 minutes and replug. Should the issue recur, then the cover sensor is probably faulty. That is the reason you are getting this error repeatedly. The only solution is to send the printer in for servicing and get the sensor repaired/replaced.
In any case, here are the steps to close the inner cover:
1. Press the Open Button (1) to open the Paper Output Tray (2).
2. Raise the Scanning Unit until it stops.
3. Close the Inner Cover
4. Now close the Scanning Unit.
You can also try reinstalling the printer software along with any patches, updates, etc from the Canon website. Make sure you uninstall the existing software first though..
If neither works, then its time to take the printer in for servicing. You could try to contact them by phone first:
  • Toll-free live technical support** Monday through Friday 10:00 AM ET to 10:00 PM ET (excluding holidays) at 1-800-828-4040
  • The location of the ASF nearest you for carry-in service at 1-800-828-4040
  • Toll-free TDD Support Line for the Hearing Impaired Monday - Saturday (excluding holidays) at 1-866-251-3752
  • Technical Support for Customers in Canada at 1-800-OK-CANON
Hope that helps!
Jul 03, 2008 | Canon Pixma MP500 All-In-One InkJet...
Green light flashes 7 times
LED Blinking in Orange/Green:
2 times: No paper. (ASF) [1000]; Set the paper in the ASF, and press the Resume/Cancel button.No CD-R tray. [1001]*1; Set the CD-R tray, and press the Resume/Cancel button.
No paper in the cassette. [1003]; Set the paper in the cassette, and press the Resume/Cancel button.
3 times: Paper jam. [1300]; Remove the jammed paper, and press the Resume/Cancel button.
Paper jam in the under guide. [1304]
Paper jam in the rear guide.[1303]
Front door closed. [1250]; Open the paper output tray.
4 times: No ink.[1601 / 1611 / 1612 / 1613]; Replace the empty ink tank(s), or press the Resume/Cancel button. Pressing the Resume/Cancelbutton will exit the error without ink tank replacement, however, ink may run out during printing.
5 times: The print head is not installed [1401], or it is not properly installed (EEPROM data of the print head is faulty) [1403 /1405]. Install the print head properly, and close the access cover. Or, with the print head installed, turn the printer off and on.
6 times: Inner cover open. [1841]*2; Close the inner cover, and press the Resume/Cancel button.
Inner cover open (during printing on paper). [1846]*2; Close the inner cover, and press the Resume/Cancel button.
CD-R tray guide closed (during CD-R printing).[1850 / 1855]*1; Open the CD-R tray guide, set the
CD-R tray properly, and press the Resume/Cancel button.
CD-R tray guide open (during printing to paper). [1851 /1856]*1; Close the CD-R tray guide, and press the Resume/Cancel button.
7 times:No CD-R or DVD-R. [1002] After setting a CD-R or DVD-R in the tray, set the tray in the tray guide, and press the Resume/Cancel button.
8 times: Warning: The waste ink absorber becomes almost full (approx. 95% of the maximum capacity). [1700]; Pressing the Resume/Cancel button will exit the error, and enable printing. The service call error, indicating the waste ink absorber is full, is likely to occur soon.
In repair servicing, replace the bottom case unit (QM2-1249), or the ink absorbers (QC1-4222 / 4223 / 4224 / 4263 / 4264 / 4864).
9 times: The connected digital camera or digital video camera does not support Camera Direct Printing. [2001]; After removing the cable between the camera and the printer, press the Resume/Cancel button, and
re-connect the cable.
10 times: Automatic duplex printing cannot be performed (paper size not supported). [1310]; Press the Resume/Cancel button to eject the paper being used at error occurrence. Printing will resume from on the front side of the next page.
11 times: Failed in automatic print head alignment. [2500]; Press the Resume/Cancel button, and after confirming the following, perform print head alignment again: - Set an appropriate type and size of paper (plain paper, A4 or letter). - Check that the nozzle check pattern is properly printed (all ink ejected, no faint printing). - Protect the paper output slot from exposure to excessive light.
Access cover open. [1200]; Close the access cover.
LED Blinking in Orange and Green Alternately, or Lit in Orange:
2 times: Carriage error [5100]
3 times: Paper feed error [6000]
4 times: Purge unit error [5C00]
5 times: ASF (cam) sensor error [5700]
6 times: Internal temperature error [5400]
7 times: Waste ink absorber full [5B00]
8 times: Print head temperature rise error [5200]
9 times: EEPROM error [6800]
11 times: Carriage lift mechanism error [5110]
12 times: AP position error [6A00]
13 times: Paper feed position error [6B00]
14 times: Paper feed cam sensor error [6B10]
15 times: USB Host VBUS overcurrent [9000]
16 times: Valve sensor error [6C00]
17 times: Motor driver error [6D00]
20 times: Other hardware error [6500]
Continuous alternate blinking: rom error
Aug 31, 2014 | Canon PIXMA iP2000
My canon pixma ip2000 lights flashing 7 times
LED Blinking in Orange:
Pixma 4250 printer 6 yellow flashes
Hey Gary.
The error code is for the inner cover that needs to be close.
1841 *2/1846 *2 Orange light blinking 6 times Description:
The inner cover is open.
Resolution:
  1. Close the inner cover.
    innercover_tcm13-1070771.jpgThe above picture shows the inner cover.
  2. Press the [Resume/Cancel] button on the device to continue printing.
Nov 10, 2013 | Canon PIXMA MX320 Color USB InkJet Printer
Canon MP830 printer giving error message "inner
If the inner cover is open when starting normal printing,close it before pressing [OK] on the machine.Do not open or close the inner cover when printing.This may damage the machine.
Jun 02, 2011 | Canon PIXMA MP830 All-In-One InkJet...
Getting "inner cover is open" message
The inner cover is a flap on the inside in front of the carriage when it is at rest when the cover us open. You had to flip the inner cover down to access the ink cartridges.
Open the cover. The inner cover is in the center and need to be flipped up.
Good luck.
Dec 04, 2009 | Canon Pixma MP500 All-In-One InkJet...
Inner cover of printer MP610 -error 'inner cover not closed'
I am still on . Get back if your problem is not solved.
Aug 03, 2009 | Canon PIXMA MP610 InkJet Printer
When attempting to print, I receive an error message which states "Inner conver is open. Close the inner cover and press OK". However, the inner cover is closed...? I have opened and closed...
Are you looking at the canon error window picture that show up on your monitor: It is the front inner flap you see after you open up the two top "covers". I forgot I opened this one looking for a paper jam. The printer cartridges would not even move to the front with this flap opened. After I closed the inner flap it all works (after opening and closing the top two "covers" many times!
Apr 16, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Canon PIXMA MP830 All-In-One InkJet Printer Logo
99 people viewed this question
old marine
old marine
