Question about Dell Inspiron Computers & Internet
Windows cannot initialize the driver for this hardware code 37
Apple, blackberry devices do not work
    New Friend:
  • 3 Answers
Uninstalling and then reinstalling the drivers for the device is a likely solution to a Code 37 error, especially if the error is showing up on a device other than a BD/DVD/CD drive.
Important: If a USB device is generating the Code 37 error, uninstall every device under the Universal Serial Bus controllers hardware category in Device Manager as part of the driver reinstall. This includes any USB Mass Storage Device, USB Host Controller, and USB Root Hub.
Note: Correctly reinstalling a driver, as in the instructions linked above, is not the same as simply updating a driver. A full driver reinstall involves completely removing the currently installed driver and then letting Windows install it over again from scratch.
Posted on Apr 20, 2013
SOURCE: HL-DT-ST DVDRAM GSA-T20F ATA Device
I had this problem going into the new year of 2011. If there are not registry editions such as Upper or Lower keys present, then try this solution because many times this is not the case as people will say. The alternative to registry editing is the following:
1) Disconnect your internal optical drive.
2) Go to the Device Manager and select
3) Under DVD/CD-ROM drives, uninstall all of your drives.
*Preferably you want to uninstall the one that is not working. But likely it won't show.
4) Select under Action menu, scan for hardware changes.
5) Place your optical drive back into your computer and then
6) Repeat step 4.
7) Next, you should see your computer checking for any hardware additions or compliant plug and play devices.
8) Check your device manager and all of your drives should automatically reinstall themselves including the one that was missing.
This worked for me and I hope it will for you.
If you want, you could try check the registry for the Upper level and lower levels, and use that method to be sure, but you likely don't need to if my method works for you.
Posted on Jan 02, 2011
  • 2427 Answers
SOURCE: CD Rom
Do a system restore to a time previous to where you drive worked..
For xp .. start all - all programs - axcessories - system tools - system restore
for vista .. start - system tools - system restore
or start search,, type system restore and hit enter
scroll down until you see system restore " restore to a previous date) cliak on that..
In eighter case follow the onscreen instrustions to do the restore..
if that fails you may need to format the system with the cd's that cam with it. insert the disk and restart the system..follow all instructions. NB:: this will erase all data,, backup important files before doing this..
Posted on Mar 02, 2009
Jerry Pal
  • 130 Answers
SOURCE: Disc drive not working! Urgent help needed!
Hello
i will provide you a link where you can download a fix. With this fix you can resolve the issue.
Run the following fix on the notebook and restart the notebook :
http://techiesspot.com/filez/cddvdfix.reg
I have fixed 100's of laptops with this issue
Posted on Jul 25, 2009
ailia
  • 175 Answers
SOURCE: Code 41 Windows successfully loaded the device
Which type of hardware you loaded the driver? If its WLAN or Bluetooth, then check function button for wlan and bluetooth is power ON. Or you are not loading proper driver or your hardware is not available.
Regards;
Hasan
Posted on Nov 08, 2009
  • 111 Answers
SOURCE: device driver cannot load by Windows
Click on the link below to fix the issue.
CD/DVD drive not working
Posted on Sep 01, 2010
Windows cannot initialize the device driver for this hardware. (Code 37) HDPVR
It means there is a problem with the device driver for the hdpvr. Try uninstalling the drivers, rebooting and then reinstalling the driver for it.
In some cases it can also mean a registry problem, where removing the UpperFilter/LowerFilter entries can help:
http://pcsupport.about.com/od/driverssupport/ht/upperfilters-lowerfilters.htm
Feb 08, 2013 | Hauppauge 1212 Hd Pvr High Definition...
Code 37 on dvd drive
The Code 37 error may occur when the concerned device is not connected to the system correctly and when its driver is faulty. A code 10 error is common when you add or remove USB devices or video & sound cards to and from your PC. When these errors occur, you may receive the error message given below.
To resolve code 37 errors, first ensure that your device is properly connected to your system. For instance, check all the cables of your printer or check that your sound or video adaptor is properly seated in its slot.
Try to remove and reinstall the device, and run the Add New Hardware Wizard from the Control Panel to see if Windows detects and installs it. If this does not resolve the issue, then update the device driver by performing the following steps:
1. Open Control Panel and select System.
2. In the System Properties dialog box, select Hardware tab, and then click on the Device Manager tab.
3. Scroll down the Device Manager window and identify the faulty hardware from the list.
4. Right-click on the hardware and select Update Driver.
5. Follow the screen instructions to resolve the error.
If these steps do not resolve your error, then the problem might be with your device. Get it checked by an authorized technician.
Aug 04, 2009 | Dell DVD-rom DVD Drive
Error code 37
Hi there
Good luck
Jan 14, 2009 | Computers & Internet
Dvd drive not working
Hi and welcome to FixYa,
Problems similar to yours have been addressed before and another member has written a good fix, pls click here. Try it, we got favorable results even with codes not mentioned by Ekse.
Good luck and Thank you for using FixYa. Happy Holidays.
Dec 12, 2008 | Computers & Internet
I have a gateway M-6841 s/n N3F8481009154 LAPTOP COMPUTER WHICH SAYS CODE 37 for the CD-ROM. Windows cannot initialize he device driver for this hardware.
From the microsoft support page, it suggests to uninstall the driver and and click on scan for hardware changes to re-install or upgrade the driver. Here is the page:
Code 37
Windows cannot initialize the device driver for this hardware. (Code 37) Recommended resolution
The driver returned failure from its DriverEntry routine. Uninstall the driver, and then click Scan for hardware changes to reinstall or upgrade the driver.
On the General Properties tab of the device, click Troubleshoot to start the Troubleshooting Wizard.
Hope this helps,
Good Luck
Jul 21, 2008 | Gateway Computers & Internet
Computers & Internet Logo
217 people viewed this question
Alun Cox
