Question about Hampton Bay 24002 Ceiling Fan
My ceiling fan is making a clicking noise on low and medium speeds
    Genius:
  • Hampton Bay Master
  • 1,617 Answers
Make sure all screws are tighten, Since this is a store brand for Home Depot it could be the bearings. You get what you pay for. Low-end fans are made from cheaper parts.
Posted on Apr 20, 2013
  • Vern Wilson
    Vern Wilson Jan 01, 2014
    Would all you fan pros stop the automatic "tighten the screws advice". Loose screws do not give enough thread clearance for the screw to slap against the thread to produce a "taping sound". THE PROBLEM with Hampton Bay fans is from the (approx) 1.5 inch long METAL WEIGHT BEARING PEG IN THE "BALL/DOWN ROD" ASSEMBLY as it TAPs against the plastic BALL piece caused by always out of balance Fan Blades Hampton produces. NOT SO YOU SAY because the weight of the fan pulls the downshaft against the peg tightly --NOT SO--the PEG remains LOOSE because the SCREW IN THE SIDE OF THE BALL combine with the very (impressive engineering) close clearance tolerance between Ball & Shaft holds the downshaft up without need of Peg support. THUS the METAL PEG TAPS against the HARD PLASTIC BALL intermittently producing taping sound. Put some non permanent glue against the Peg to keep it from rattling OR take the screw out so the Peg will support the weight.
SOURCE: Hampton Bay Ceiling Fan At Slow Speed
I recently replaced my hampton bay fan for the same reason (slow at all speeds) and discovered scorched and melted capacitors and wiring inside the fan. My suggestion is to stop using fan and replace immediately.
Posted on May 11, 2008
  • 158 Answers
SOURCE: Ceiling fan stuck on high
Try removing 120 volt power from the fan by turning offf the house circuit breaker or removing the fuse from the fusebox that supplies power to the fan. Wait 30 seconds and restore power. This may reset the fan speed control in the fan itself.
Posted on Aug 05, 2008
SOURCE: Hunter fan with remote control was 3 speed, now only 2 speed
It sounds like fan motor is okay. There are two motor windings -- one low speed, one medium speed. Low winding gives you low speed, medium winding gives you medium speed, both windings give you high speed -- so I would say if you get high speed, both windings are good.
The remote (the hand held transmitter) controls the speed by raising and lowering the frequency of the current which is 60 cycle coming to the fan ceiling box. If the fan speed -selector switch (usually a pull switch) is set to high, when the remote (transmitter) signals the receiver to change speeds, the frequency of the current is changed by the receiver (the receiver is usually in the fan housing).
Sounds like you'll need to replace the remote system -- these come in sets, both transmitter and receiver, and cost about $30. If you're not experienced with wiring fans, you should get an electrician to do the job.
Posted on Apr 22, 2009
SOURCE: Hamilton Bay Remote Control Ceiling Fan
Rempte light comes on but does not activate fan or light?? thanks
SOURCE: The Hampton Bay Altura Ceiling fan functions only with remote.
I contacted the manufacturer (kingofffans.com) after my Altura fan would run on high speed only and the remote would not control any thing. They said their was a manufacturing defect with a capacitor that affected many of the Altura fans. We are now on a waiting list for a new capacitor and housing, because they did not have enough replacement parts.
Posted on May 27, 2009
My Hunter ceiling fan make a clicking noise whenever I have it on a high speed. If I put it to medium it doesn't make that sound. I actually have the same problem with my other fan. One is in the...
You need to balance the fan blades. There should have been some small metal pieces that came with the fan. I you can not find the pieces, your local Lowe's or Home Depot carries them in the lighting area.
Jun 22, 2011 | Heating & Cooling
Hunter Ceiling fan lost medium speed, kept hi and low. Speed control capacitor melted. Replaced both capacitors (speed and start) AND switch. Still no medium speed. Is it possible part of the motor...
well, they could have. but before you throw it out, go to the hardware store, and buy a new pull switch. either that, or just run it with the high and low speeds. It shouldn't hurt it at all. But, if there is any clicking sounds, or wierd noises coming from it , DON'T USE IT!! it may catch fire. but it did last a long time. 20 years is good for a modern celing fan. though I like my antique 1907 westinghouse 72 inch 2 blade fan. It hasn't died yet!!!
Aug 12, 2010 | Hunter Ceiling Fan Control Switch
Noise problem CXL52WB
mcdevito75 here, From the little I know about these ceiling fans, they are a sealed bearing type motor, you may be hearing a dry bearing on medium speed for which you"d have to replace the fan to fix. Or, you may be hearing vibration of the fan itself when it"s on medium, vibration could be the fan itself or something slightly loose. Have a handy man take a look at the fan and it"s hook up, make sure everything is tight. Hope this helps.
Jul 19, 2010 | Craftmade International Craftmade...
Our hunter fan won't work on high speed any longer, low and medium speed work fine, when clicked on high - it only goes at medium
Sounds like the variable speed switch may be worn out.
You should be able to purchase replacement switch at the local home depot- type store in the electrical supplies.
Trying to get an exact match to replace may be a bit difficult, but a similar 3 speed switch should work just fine.
Jul 18, 2010 | Hunter Ceiling Fan Control Switch
My hunter remote control ceiling fan doesn't go real fast. the highest speed is what a normal fan would do on medium. is there a fix?
if you have pull chain switches in addition to the remote control, your pull chain switch may be set to Medium, which would make the fan run on a maximum of medium speed.
May 16, 2010 | Hunter 52" Ceiling Fan With Light And...
Hunter ceiling fan-just installed -possible speed control problem
Sounds like the fan is defective. All internal wiring from the switch to the motor is factory installed. The fan has power going to it. Just to make sure, double check the wiring from the ceiling fixture to the fan.
Problem could be a faulty switch on the fan or faulty motor(bad winding for med. speed). Try reverse switch on the fan to operate the opposite direction and see if medium speed works. If medium does work in opposite direction, it pretty much points to a defective fan. In any case, unless you discover that the ceiling wires were reversed going into the fan, I'd say new fan to the returns dept.
Jul 21, 2009 | Hunter Ceiling Fan Control Switch
Apr 21, 2009 | Hampton Bay 24002 Ceiling Fan
Hampton bay fan makes squeeking noise
If the fan is fairly new, remove it and return it to Home Depot. It is almost certainly something that has fallen down into the motor and is rubbing loudly enough to make a squeak as the fan runs faster.
The fan itself has sealed lubrication and you don't have to lubricate it.
Apr 07, 2009 | Hampton Bay 24750 Huntington III Ceiling...
Casablanca fan speed problem
If this fan has a pullchain that also controls the fan speed, and you have a remote, the pullchain has to be set for the highest speed. If it is set at medium or low, it will mess with the remote operation. Note: usually high speed is the first pull after the "off" position.
Oct 27, 2008 | Casablanca Fan Bel Air 3811T Ceiling
Fan makes noise
try to find the manual through the internet. Look for model number and name of product then click manul to your chosen then it should be no problem to help you find it better!
Jul 18, 2008 | Hampton Bay Cessna 04313 Ceiling Fan
Hampton Bay 24002 Ceiling Fan Logo
331 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Donald Klecher
Donald Klecher
Level 1 Expert
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
