Question about Sylvania LC320SS9 32 in. LCD TV
My tv is plug in but i wont come on no power light
When tv is unpluged and pluged back in it wont power on and no lights blinck
Sure the plug is getting power from wall outlet? If power is there you might want to check out the power supply board first for issues.
Oct 13, 2015 | Televison & Video
Lights went off now tv wont come back on
We recommend you remove all HDMI cables from the TV then unplug the unit's power cord for 30 seconds. Then plug the power cord directly into the wall. If the problem persists we recommend you have the TV evaluated by an authorized service center.
Mar 22, 2014 | Panasonic VIERA Televison & Video
The tv is plugged in and light is red but wont turn on when power is pushed
When the red light is on you have power to your tv.Then you must turn it on by the TVs remote NOT by pressing the power button on the TV.
Aug 17, 2012 | Hitachi 43FDX01B TV
T.v. wont turn on.
you might find that the power cut has blown the tv does happen - check the fuse first in the plug
Jan 24, 2012 | iLO Televison & Video
TV wont trun on. Pull plug and wait 5min, still wont turn on. What can be done to fix this
Tv turn on?Front LCD panel LED power light indication flashing?Yes,than the power supply board is dead,that the board where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Jul 09, 2010 | Philips 32PFL3403D/27 32 in. LCD TV
The red light in the bottom left corner keeps blinking and it wont turn on. Yet when i unplug the tv and plug it back in the blue light comes on but then turns into red light blinking again and it wont...
Ur tv power supply board have dead componnents call capacitors.These capacitors are leaking gas,and it bulges up on it top or puff up on it top.These capacitors parts are dead,they must be replaced.U know basic electronic's and soldering?Take ur tv aparts,the board where the power cord plug into it.That ur power supply board,searches all around for these dead gas leakage capacitors,replaced them.Ur tv power LED light will be stable and the tv power will work again.Or tries websites like Shopjimmy.com,ebay.com to buy a whole reburbish power supply board for the replacement.
May 24, 2010 | Philips 42PFL5603D - 42 IN. LCD HDTV
Power serge
ok First question does the led continue to blink after 70 seconds after u plug it in. it is common for a cuircit board called the dm(digital module) to go bad in these units. this set has a keyboard lockout feature. Press menu for 10 seconds on front panel. if that does not release control then u more than likely have a problem with dm module. there are several bullitens about this and several things a tech can do to repair this set
Jan 16, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Sylvania LC320SS9 32 in. LCD TV Logo
32 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
