Question about Fujitsu 18C1 Air Conditioner
Service manual for hyundai split system acon HSH 2402BA
Outdoor fan very noisy
3 Suggested Answers
SOURCE: NEED SERVICE MANUAL FOR FUJITSU SPLIT SYSTEM
try, http://www.uelements.com/downloads/Fj-aby14rga-sm.pdf
Posted on Jan 07, 2009
jgwhomeequip
  • 1902 Answers
SOURCE: outdoor fan is running continuously without using Wireless Remote Controller
Bad control board on the condensing unit up top. The board needs to be replaced as it is sending the message that the system is calling for cooling/heating all the time and doesnt know what to do. If you continue to let it run this way you will ed up having more major issues
Posted on Jun 01, 2009
My carrier split ac trip after some time and green light blinking contsly
If this is a ductless split call a tech! The ductless split systems can be a troublesome unit to diagnose. A few things to try. Clean air filters and ensure coil behind is clean. And build up or debris on blower wheel (indoor fan blades) will cause unit to fault. Turn off power at breaker or disconnect and clean (with water hose and medium pressure) the outdoor coil. Be sure you will not damage outdoor coils fins with too much water pressure. Turn power on. If this simple service don't do it again, call a tech! Be sure to ask if they have someone who is experienced with mini split systems and be patient. Even the best technician will need to call carrier for tech support.
Jun 04, 2015 | Carrier Heating & Cooling
Fujita split system air conditioner filter outdoor unit
Pull the filters make sure it's not freezing and catching the fan blades, if not then the fan motor needs replacing
Sep 27, 2013 | Heating & Cooling
I got a C9 error on a C12AWR artcool split ac which doesn't work anymore i replaced the mainboard of the outdoor unit which didn't help i replaced the fan motor which didn't help either does...
Split = Outdoor unit fan problem. Check Outdoor fan motor is plugged in, Electrically & Mechanically sound, if not replace motor, otherwise replace PCB. Multi V
= indoor PCB failure. Replace PCB.
Let me informed again if problem persists,.
Oct 25, 2011 | LG LA185HV Split System Air Conditioner
I have a honeywell Design Air reverse cycle aircondton system. Two weeks back it stopped working. When I switch it on it starts the system. The air is flowing but it is not cooling. what could be wrong and...
Hi, Just to to let you know, I am a contractor for heating and air conditioning. You have a split system heat pump it sounds like to me. If you have the indoor unit and an outdoor unit, this is a split. If the blower is running but not getting cold air, there could be several problems that would cause this. The service tech should be able to troubleshoot and find the problem in 1 hour or less. Depending on who you call, you are looking at anywhere from $65.00 to $85.00 per hour. Some places also charge you a travel or truck charge of $20.00, try and stay away from them. It will be a 1 hour minimum and in 1/4 hours there after. It could be a quick fix, breaker, fuse, or a serious problem as a compressor. This is what you are looking at. If you do have a split system and the outdoor unit is not on, check the breakers and fuses before you call any one. This may save you many $$$$$!! If you have a system that is all in one or a package unit and the blower comes on, make sure the outdoor fan is running ( condenser fan motor ) and listen to see if you can hear the compressor running. If you do have a split unit, go to the outdoor unit and see if the fan is running and compressor also. If not, check you're power supply. You may get lucky.
Sincerely,
Shastalaker7
Feb 12, 2010 | Heating & Cooling
Need a manual for a LG split system
You should be able to get a service manual from the manufacturer online and down load it? Or go to where this unit was purchased and they should be able to help you.Get the model, serial, and product numbers from both indoor and outdoor units to take with you. The more info you have the better. The outdoor serial number shows the manufacture date.Have you removed the excess panel on the outdoor unit to see if a manual may be inside? they sometimes put them there instead of handing them to the owner. Good Luck!
Sincerely, shastalaker7
Oct 19, 2009 | LG LS-L1210CL Mini Split Air Conditioner
WMH24-1A 1st 2 lights ar blinking
http://www.sanyohvac.com/assets/documents/service/SM09KHS51.PDF
go to this website and see if this is the manual you are looking for.
http://www.sanyohvac.com/assets/documents/installation/ii09KHS51.PDF
One is the service manual and the other is the installation manual.
Good Luck.
Aug 05, 2009 | Sanyo 09KHS51 Ductless Mini Split Air...
I have a split air conditioner my out fan keeps
It depends on the effiency of the unit. The fan could be cycling because the condensor coil is not hot enough. When it get hot enough the fan will turn on. If not you have a bad fan motor
Jun 25, 2009 | LG LSC091PMA Split System Air Conditioner
Fujitsu 18C1 Air Conditioner Logo
69 people viewed this question
Top Fujitsu Heating & Cooling Experts
Fotis Papastamatiou
AJMAL KHAN
Donni Steen
Are you a Fujitsu Heating and Cooling Expert? Answer questions, earn points and help others
