Question about Panasonic Lands Phones
How do I enter 'one touch dialing' on a panasonic kx-t7636 / kx-tda100 system so when I hit the button it will automatically pick up an outside line and dial the number?
  • bryno57 Mar 12, 2009
    I'm hoping that I don't have to go "off hook" first. This becomes a two stage process. From the KX-TDA manual it says that "a line access was not stored" How do I make this part of the programming so that with the phone on hook I can "one touch" and have it call using the speaker phone?
    Sergeant:
    Champion:
  • 435 Answers
Hi, Try this. It has a section for touch dialing.
http://service.us.panasonic.com/OPERMANPDF/KXT7630.PDF
Posted on Mar 12, 2009
  • 15,935 Answers
CLICK HERE for your owners manual in PDF format.
Page 3 describes call functions.
Thanks for using FixYa. a FixYa rating is appreciated!
Posted on Mar 11, 2009
  • 408 Answers
Http://service.us.panasonic.com/OPERMANPDF/KXT7630.PDF
Top of page 3 will tell you what you need to know.  Or you can hit program, hit (co), hit 2, then enter your outsideline and number you want to dial, hit auto dial store.  To use that number, pick up the phone and press the button you assigned to that number.
    Genius:
  • 1,550 Answers
You can get the instruction from the manual
manual for phone
See the page 16 to get the details .
  • SAM ANDERSON Mar 12, 2009
    You can see clear instruction on page 16 . see that particular page if you still have problem .
    Let me know .
How do i change the preferred line assignment (outgoing)?
The manual (same as KX-T7636) explains that, and can be downloaded from...
Jun 23, 2014 | Panasonic Kx-t7633 Single Line Corded...
How do you set up voicemail on the Panasonic KX-T7636 system?
1. Raise the handset on any telephone in the Panasonic Telephone system.
2. Press the "INTERCOM" button and dial 165.
3. When answered by the Auto Attendant, dial # XXXXX * 9 9 8.
(Pound Six Star Nine Nine Eight)
4. Enter the Administrator Password. Followed by a #. (Pound) If required.
5. Dial 5 to "Modify Message"
6. Dial 1 to "To Change The Company Greeting"
7. Enter the Company Greeting Number from 1 to 32.
If you are not sure of which Company Greeting Number to change, then start with 1.
The Panasonic Voice Mail system will actually play the greeting to you.
Then you can determine if it is the correct one you want to change.
If it isn't, you can dial 2 and move on to next greeting and so on.
If you select a greeting number where there is no greeting recorded,
the Panasonic Voice Mail system will prompt you to record one at that time.
You may dial *1 (STAR ONE) to skip recording and return to Step 7.
8. When you have found the Company Greeting you want to re-record
follow the system prompts to record and save your new greeting.
Note:
You can change the Company Greetings remotely from anywhere.
1. Call the main number of your business.
2. When answered go to Step 3 and follow the same procedures.
3. When completed....Hang up....
Aug 09, 2011 | Panasonic KX-T7636-B Corded Phone
I have Panasonic kx-T7453 and one of the Outside lines was already connected to a station and while programming a One-Touch dialing ended causing the outside line to be disconnected to this station. How do...
In a TD system, the lines have 2 digit number 01-12 normally, up to 55 actually. So, if line 1 is missing, press PROGRAM dial 99 press the unprogrammed button and dial 0 01 STORE
Press PROGRAM or pick up the handset and drop it back down to exit programming.
Carl
Apr 21, 2011 | Panasonic KX-T7453 Corded Phone
How do I program a phone number to the one touch buttons on a Panasonic KX-T7730 phone?
It depends on what you get when you dial "9" on the intercom. If you get an outside line, then the 12 right side buttons on your phone can be programmed for one touch dialing like this:
On an idle phone, press PROGRAM a button and dial 9 plus the number and STORE. You can program more than one button by just pressing button numbers and STORE. Exit programming by picking up the handset and dropping it back down.
If you want a specific line, you may be able to dial the specific 8x code to access a line directly, or you can go into system programming and delete the open lines in program 400. Disabling would be the best, because if your 8x line is busy, you can't make the call with the auto dial button.
Carl
Mar 08, 2011 | Panasonic KX-T7730 Corded Phone
Display screen shows "Will return soon" Would like
You need to cancel absent message on your phone. The method depends on which Panasonic phone system your phone is connected to. Following are the methods for three different Panasonic phone systems. Once you cancel absent message, your screen should return to date and time, if not then press * until it does.
KX-TA624 Phone System
Press intercom button, dial 750#, lift handset then return handset to cradle to end.
KX-TA1232 Phone System
Press intercom button, dial 7500, lift hanset then return hansdset to cradle to end.
KX-TDA100 or KX-TDA200 Phone Systems
Press intercom button, dial *7500, lift handset then return handset to cradle to end.
Jan 27, 2011 | Panasonic KX-T7633 Corded Phone
Hello, I have 4 Panasonic KX-T7630 with TDA100, and I set the flexible button for CO or INT, but the LED on the buttons didn't light when I receive a call. I can make a call use this buttons, but the LED...
Whenyou program the buttons use the following steps -
press PROG
press the BUTTON to store
press 1 for an extension and the enter the extn no. followed by STORE
(or press 0 to store a line key)
(or 2 to dial an outside number dont forget a 9 for outside line access)
Aug 10, 2010 | Panasonic KX-T7630 Corded Phone
HOW TO SET THE TIME KX-T7636
If you are using this phone on a Panasonic KX-TDA 30/100/200/600 system.
From the Switcboard / Main telephone or Managers phone with the handset on the cradle/hook:
1. Press PROGRAM * * or PROGRAM * # followed by the system password ( usaully default is 1234).
2. Now press 000 and then ENTER.
3. Enter the last 2 digits of the year and then select the month with either SEL+ or AUTO ANS / MUTE.
4. Scroll right with the right arrow key and change the date.
5. Press the NEXT button on the screen and the time will appear.
6. Set the time. Press AUTO DIAL / STORE to save your changes.
7. Lift the handset and put it down to exit program mode.
Mar 14, 2010 | Panasonic KX-T7630 Corded Phone
Hi, Expert Guy , I have some problem with Panasonic TDA100 about calling Out by co line i have 20 extension and 4 CO line , so when i need to call out , i press number 9 , it will switch to the line free ....
To call out: Go off hook press an idle CO button-- Dial outside phone number. There is no need to dial "9".
If you need a copy of the manual you can get one for free at the following link: HTTP://phone.manualsonline.com/manuals/mfg/panasonic/kx-t7630.html....Let me know if this answers your question. Master FixYa...
saailer@att.net
Dec 05, 2009 | Panasonic KX-T7630 Corded Phone
How do i Names to Extention numbers on the Panasonic KX-T7636
If you are using this phone on a Panasonic KX-TDA 30/100/200/600 system. From the Switcboard / Main telephone or Managers phone with the handset on the cradle/hook press Program * * or Program * # followed by the system password ( default is 1234). Now press 004 and then ENTER. Enter the extension number you want to change. Now enter the name (the same way as texting on a cellphone) To save the changes press AUTO DIAL / STORE. To go to the next extension press NEXT on the screen. When you are done lift the handset and put it down to exit program mode.
PLEASE rate/vote this answer if it was helpfull.
THANK YOU
Nov 09, 2009 | Panasonic KX-T7636W Corded Phone
Programming one-touch dialing
I'll try my instructions and see if those are the ones you used.
Press Program 99 the button to program, dial 2+9 or whatever you use to get an outside line, and the number STORE.
Program exits programming.
Now, just press the button and it will automatically dial or you can pick up the handset and press the button.
Carl
Mar 25, 2009 | Panasonic KX-T7431 Corded Phone
Lands Phones Logo
125 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
