Question about Toro 51486 Cordless 12-Inch 24-Volt Lithium-Ion Electric Trimmer/E
I have a cordless toro 51486 12 inch 24 volt trimmer I can't put new string on the spool
I need help adding string to the spool
4 Suggested Answers
SOURCE: I have a Toro 12 inch Toro Electric trimmer and I can't get the spool off to change. Any solution?
I am having the same problem - the spool should just come off by turning it counter-clockwise but is completely stuck. This model does not have any tabs that need to be pushed in to get the spool off. Very frustrating!
Posted on Apr 25, 2010
rycgl
  • 1545 Answers
SOURCE: I can't get the spool
You are doing well. The Toro site states that this is a model from 1985. User manuals were much more concise back then and so I will have you view yours. Click on the link on the left that states:
Toroe Electric Trimmer/Service Manual (English). I have viewed it and spool removal instructions with pictures are there.
https://homeownersolutions.toro.com/portal/server.pt/community/product_center/225#manualsResultPage
Posted on Oct 24, 2010
woobie dog
  • 1273 Answers
SOURCE: Toro 8" 12 volt trimmer.
Look at this tip, an oldie but a goodie:
http://www.fixya.com/support/r2827867-winding_line_trimmers
Should be what you need.
Best regards, --W/D--
Posted on Jun 04, 2011
Toro 8 inch cut home duty trimmer how do you remove the spool
You have to hold in the two tabs at top of spool assembly
Aug 30, 2012 | Toro& Electric String Trimmer
I can't get the spool off of my Toro 12 inch trimmer model 51325. I have tried all the suggestions on the web site and it won't come off, however it came off my itself earlier when it ran out of string...
Oct 24, 2010 | Toro Electric Trimmer
I properly replaced the line spool but it won't feed automatically.
After you replaced your string in the trimmer and fed it through the hole in the plastic casing in which the spool fits into, did you pull the string until you hear a click? The click locks the string in, then you can bump and feed as usual. Otherwise it won't feed normally.
Aug 13, 2010 | Black & Decker Grasshog 12 Inch 18 Volt...
Cordless trimmer 7inch cut model 51556 serial
Go here....you can download the manual....It's free!
https://homeownersolutions.toro.com/portal/server.pt/community/product_center/225#productDetailsPage
Jun 16, 2010 | Toro& Electric String Trimmer
It has come apart and I would like to refill the line on my toro heavy duty electric trimmer
Cut two separate pieces of string, about 7 ft. each.
Stick the end of the line in the hole on the inside of spool.
Wind clockwise onto spool, putting the line that is closest to the ground on first.
Once you have winded this piece on, lock the last 4 inches of line through the slits on spool.
Repeat process for second piece of line, locking the last 4 inches in slot opposite the other locked in piece.
Put the spool on the trimmer, feeding the end of lines through either hole on trimmer.
Before you push the spool all the way on, pull the strings out of the locked position.
Jim
Jun 23, 2009 | Toro Garden
Adding trimmer line to spool on husqvarna trimmer-two strings
Before you push the spool all the way on, pull the strings out of the locked position. Put cap on and GO CRAZY!
Jim
Jun 19, 2009 | Troy Bilt 17 Inch 29 Cc Gas Powered...
SPOOL
You have the string wound the wrong way. Wind in the other direction.
Jim
Jun 16, 2009 | Black & Decker Grasshog 12 Inch 18 Volt...
Worx WG150 Cordless Grass Trimmer spool nut keeps falling off
Thanks for update. Glad you got some resolution.
Would you mind rating my response?
thanks...
Charlie
May 29, 2009 | Worx GT WG150 10 in. 18 Volt Cordless...
Cannot undo the string compartment to put new string in. There may still be string in the compartment but I cannot get into it. This is a 12 inch Toro electric wacker.
There sould be a knob that turns counterclockwise to take spool off. If not there sould be two taps that push in and pull down on what they call the spool head. Hopefully this will help you.
May 14, 2009 | Toro& Electric String Trimmer
Toro 51486 Cordless 12-Inch 24-Volt Lithium-Ion Electric Trimmer/E Logo
61 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
