Question about Aurora Electronics PR620M Calculator
Which piece exactly is the "ink roll" on the Aurora PR620 and how do I replace it?
Exactly which piece under the cover is the "ink roll" that can be removed and replaced? And how do I "pick it out" from the roll holder, as the manual vaguely instructs? Thanks!
Where is the lighting module on a1997 oldsmobile aurora
Look in web site known as Rock auto.com and find Aurora and then under "Electrical Switch&Relay Section"-and will find Complete Replacement for the Lights switch&Twilight sentinel ALL in One Complete Module!:) just Remove Old& replace W/New one&IS Simple-2!:)If IN' Colorado Spings Area-Try Going to "Cooper Automotive"-I've Been for over 25 years Now&Has taken Great care of My'66 Mustang-On Top of my 1997 Olds Aurora Too!!...:):)Give it a try&Rock auto has GM OEM Parts@Wholesale Pricing TOO!!..:):)-Look around the WHOLE Olds Aurora section&open&Close as many that sound at least close to what-U-Need, and they ALL have the Products Pics TOO-Hence you'll likely/Eventually Find Exactly what -U-Need and maybe an Extra Relay/switch/Wiring harness/Fuses&Etc.-That GO with Part-U-Need also-give it a Whirl-U-May_B-Surprised Nicely@a Good Price-2!!.:):)
Take care!!
Nov 29, 2013 | 1997 Oldsmobile Aurora
Were is the a/c compressor loction on a aurora
Go to a part store get the book for your car it's a diagram that will show exactly where it is............ You don't even have to buy the book..........
Sep 16, 2012 | 1996 Oldsmobile Aurora
Installing ink cartrage in a royal 435dx cash register
1. Open the printer compartment by lifting the black, plastic printer cover.
2. The ink roll is found in the front of the printer compartment, just behind the print
head, and is mounted in a plastic cartridge.
To remove, grasp the small clip on the left of the ink roll (where the words "PULL UP" may
be printed on the ink roll cartridge) and pull up.
The ink roll will easily pull up and away from the print head.
3. To replace a new ink roll, insert the ink roll according to markings "L" (Left) and "R"
(Right) by pressing downward to lock it into position, then close the printer cover. No tools
are necessary.
For best performance, store unopened ink roll package in a cool, dry place until installed.
NOTE: Replace with ROYAL Ink Roll, Part #013109.
Nov 16, 2010 | Office Equipment & Supplies
Doesn't print black ink
Have you taken the protective film/sticker off the cartridge? - so the ink can get out...
May 06, 2010 | Brother MFC-685cw InkJet Printer
Don't have a manual; have pulled the top off but can't figure out exactly how the paper should go in.
Slide off the upper cover of the calculator, and cut across the paper roll to form a clean end.
If you are mounting the roll externally (outside of the back of the calculator), then look for a slot in the rear of the calculator, which will accept the paper. Feed the end of the paper through the rear slot, and then into the internal feed slot, and hold the [FEED] key. After that, you can flip the arm back to mount the roll and replace the upper cover.
If you want to place the roll inside of the calculator, then you need to feed from the bottom of the roll into the internal feed slot, and hold the [FEED] key. After you are finished, replace the upper cover.
Sep 08, 2009 | Texas Instruments TI-5019 Calculator
95 olds aurora interior lights dont come on anymore
Replace fuse under the back seat. Look in your manual, look in the fuse section and it will tell you which fuse it is exactly
Nov 20, 2008 | 1998 Oldsmobile Aurora
Ribbon installation
I searched this online, and have found the following instructions:
1) Set the power switch to OFF
2) Remove the printer cover
3) Remove the ink roller by turning it counterclockwise and pulling it upward.
4) Install the correct color new ink roller and press it in the correct position. Make sure that the ink roller is securely in place.
5) Put back the printer cover.
May 30, 2008 | Sharp EL-1801P Calculator
How do i take out the ink thingy
You will need: 1 Replacement ink roll - Porelon PR42 Ink Roll (This roll will replace the black and red ink all on one roll) Available at OfficeMax or other supply stores.
You must first remove the clear plastic cover on top of the calculator (where the tape comes out). Remove the old ink roll. You will see on the roll where it says "pull up". It will pop out easily. Replace it with the new ink roll, it will just snap in place. Replace the clear plastic cover. It should now be ready to go!
Mar 28, 2008 | Casio FR-2650Plus Calculator
Changing paper roll on Citizen CX-121 Calculator
At the back between the top cover and bottom cover is a tiny groove to slip the paper in. Simple if you know how. I need a manual please.
Dec 04, 2007 | Office Equipment & Supplies
Aurora Electronics PR620M Calculator Logo
41 people viewed this question
Top Aurora Electronics Office Equipment & Supplies Experts
k24674
Jim Keysor
ka4iup
ka4iup
Are you an Aurora Electronics Office Equipment and Supply Expert? Answer questions, earn points and help others
