Question about Dell Dimension XPS PC Desktop
Operating System Not Found Message
Turn on the power to the tower and as it starts to boot up, it suddenly gives a "beep" sound and then the message: Operating System Not Found appears on the screen and I am stuck there! What do I do?
    Brigadier General:
  • Dell Master
  • 3,400 Answers
Dsflews 1 or 2 HDD ?
made any changes in BIOS ?
if 2 HDDs and you set optimal defaults in BIOS windows can change BOOTDISK. if two it's easy just change back.
http://www.pcmag.com/encyclopedia/term/38515/beep-codes
good reading.
Posted on Apr 20, 2013
SOURCE: Dell Optiplex GX260 .....Windows OS wont load
You have to repair windows using the installation CD
follow this link: http://www.microsoft.com/windowsxp/using/helpandsupport/learnmore/tips/doug92.mspx
I f that doesn't help, then your hard disk is corrupt(damaged) consider buying a new hard drive and reinstall windows on the new drive
Please rate this solution. thanks
Posted on Dec 28, 2008
shoib127300
  • 55 Answers
SOURCE: my dell dimensions 4600 will not boot
Dont worry.This can be resolved.Goto the BIOS by tapping the F2 key on the restart -Goto the option which says Maintainence>>Event log>>Clear all even logs -Now press F10 to save and exit or press the ESC key just once and Select SAVE and EXIT
Posted on Mar 17, 2009
pferd
  • 94 Answers
SOURCE: Dell logo appears and message appears INSERT BOOT DISKETTE...
A couple of things can cause this.
1] having the 'boot order' set up so that the computer looks to a removable device that has non-bootable media in it.
2] somehow the 'boot' device has lost it's 'boot' properties.
Best way to troubleshoot:
1] find the boot CD
2] re-strat the machine and enter the "BIOS setup" mode <f10>, or <DEL>; I think::verify the boot order
this should likely be: C: ; CD ; A:
allow machine to start with CD and check to see if anything on the wanted 'boot' device has been lost; sometimes it will get smashed.
Let us know what you get after this point, because I would rather give you an answer based on knowledge from this part of the exercise.
Posted on Mar 21, 2009
  • 59 Answers
SOURCE: dell xps 730 does not boot
I think it is a problem with your RAM memory. If you have 2 dims extract one and try to boot if not work extract the other one and try.
Posted on Jul 18, 2009
IT Steve
  • 36 Answers
SOURCE: GX520 screen display message: cannot display this video mode
This means that the windows setting you have set can not display on your current monitor. There are two ways to fix this, one is to boot the computer in safe mode by pressing f8 after the POST screen and change the resolution and the other is to plug the computer into a different monitor to see if supports that resolution and then change the resolution in windows to a lower setting.
In case you don't know how to change the resolution in windows, follow below.
Right click on the desktop
Properties
Settings at the top
Move the slider to 1024x768
Click ok
Try rebooting. If that still doesn't work, try another resolution.
Posted on Oct 19, 2009
When i boot up my laptop i am getting the error message, "operating system not found." Can you please give me advice on what to do to fix my laptop? Toshiba laptop and im scared i may lose the things
Your hard drive is missing from the system. Or, just does not recognize it. The obvious - Remove any USB devices like drives and any media from disc player. Its trying to load, but can't find bootable hard drive, CD, or USB... Remove the hard drive and reseat (reconnect). Check BIOS by pressing an F key during boot. Look on the screen for correct Function key. Might be F2 key. Verify BIOS recognizes the drive. It must be listed! There is no going forward if it's not. Check boot order and make internal hard drive first. Save and restart.
Nov 30, 2012 | Toshiba Computers & Internet
Hp compaq desktop black screen message disk boot failure insert system press enter
The words "disc boot failure" are terrifying for most computer users.
A disc boot failure notification generally means that your hard drive and operating system may be useless.
Fortunately, there are a variety of ways to troubleshoot your system in order to salvage your computer.
You may need to restart your computer a number of times before you manage to fix the error, so don't get discouraged.
A couple things to check first, make sure there's no floppy disc/cd in the drives, and if you are comfortable with computers, you can enter the boot setup of your BIOS, and check to see that your hard drive is listed as the primary boot device.
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Or there is a connection problem such as a bad cable
Test all power and data leads that attach to your hard drive IDE,SATA
the leads from your MOTHERBOARD TO THE HARD DRIVE make sure they have a
secure dust free connections and are not faulty or just replace them they could be faulty if its a flat 40pin ide
this will be the first to fail
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty
or just replace them they could be faulty a computer needs power and data to travel through every working device and continue its cycle and have an end so any faulty leads will end up with a computer error
Turn off your computer by pressing and holding the power button until the computer shuts down.
Locate the boot disc for your operating system (OS).
Turn on your computer and insert the CD into the proper drive before your monitor reaches the BIOS screen.
If the computer cannot read the CD, eject it and wipe the readable side of the disc with a clean cloth.
Restart your computer and re-insert the CD.
If this does not begin to load your operating system
Restart your computer and press the "DEL" key when you reach the BIOS screen.
This will bring you to BIOS settings.
Make sure that your hard drive is enabled to be read by BIOS. Restart your computer.
Access the command prompt by pressing the "F8" button at the appropriate moment.
Your monitor will display a notification at the bottom of the screen when you can access the system options with "F8." From the menu that appears, select the "Command Prompt" option.
Enter the text "fdisk /mbr". On the next line, enter "sys c:" and press "Enter."
This will initiate a system restore of corrupted discs.
If this does not clear the disc boot error problem.
Turn off your computer and remove the power supply.
Remove the side panel from your hard drive tower by hand or with a screwdriver.
Locate the hard drive of your computer in the top-front section of the hard drive tower when viewed from the side.
Using your fingertips, make sure all connections to and from your hard drive component are secure.
Locate the BIOS battery, which is a circular battery found on the motherboard.
Make sure that all connections to and from the BIOS battery are secure.
Check the connection of your computer's RAM to your motherboard.
hope this helps
Oct 14, 2012 | HP Compaq Presario SR1950NX PC Desktop
One short beep one long beep continuous and power green led flashes continuos
I would say you have a failed memory (RAM) module. Probably a module in one of the secondary slots since the computer is able to POST and will attempt to boot.
Mar 20, 2012 | HEWLETT-PACKARD Computers & Internet
I have an Evesham Solar desktop and have just tried to turn it on to be greeted by a message "Disk Boot Failure,Insert System Disk and press Enter". There is a clicking sound coming from the...
This sounds like your hard drive has failed or the connection is faulty.
Disconnect the tower from the mains, take off the cover and check the ribbon connector between the hard drive and the motherboard, one may have come adrift. If so, remake the connection, if not, then the drive has failed.
The only way around it is to replace it with another and re-install the operating system
Feb 07, 2011 | Computers & Internet
I am having problem with my computer. Initially it started with a Beep everytime I use to boot the computer, it gave me a message after the beep that " Your password expires in 14 days do you want to...
hi nitind
  • It's not big problem
  • re-boot ur system
  • you r telling you r upgrade your pc,so it supports windows7 too
  • put a new copy of windows 7 original
  • if not means disable the windows update after installing ...
  • before the problem may arise due to corruption of files or password is not a valid one ..
  • so put a fresh copy of windows in which drive already you have os...
  • other drive data must be safe...
  • keep antivirus active this must be helpful for your pc ...
Dec 25, 2010 | Computers & Internet
When I turn it on, it makes a continuous sound for aprox 30 secs, then shows "PXE-E61 Media test failure". When working, it self-fills any empty fields with "n", not allowing any wrting...
If the sound you are referring to is a clicking sound, then it is a hard drive failure.
Your computer is trying to boot up the operating system from the hard drive, but when it fails to access the hard drive, it tries to boot up from other devices configured on the BIOS. Apparently, your next choice for booting the operating system is set to the LAN card. Hence, you get the message "PXE-E61 Media test failure", which means that the computer tried to boot up the operating system over the network but it found out that your network cable is not connected to your computer's network interface card.
Dec 04, 2010 | Toshiba Satellite L505-S5966 Notebook
My computer doesn't load on the screen as I turn it in
A solid amber power LED on a Dell System is indicative of a no post. There are 4 diagnostics LEDs on most Dell Towers (Either on the back marked ABCD, or on the front marked 1234) they can give more details of what the POST problem is.
Troubleshooting: Disconnect all external connections to tower except power, turn it on, see if the LED indications changed. If they change, then connect disconnected items one at a time till the failed item is found. If no change, the open tower, remove all PCI expansion cards, see if system will boot. If still no change, then most likely a motherboard failure. Take RAM out, see if you get a Beep error code when powered on, if no beeps, replace motherboard. If it does beep, try RAM modules one at a time, if it boots with 1 but not the other, replace the effected module. If no boot, with either replace MB
Oct 08, 2009 | Dell E173FPb 17" TFT LCD Monitor
Dell vista will not boot up
Typically, it's a memory problem. If you have multiple memory modules, leave one in the CPU at a time and boot your system todetermine which module is bad. Good luck.
Jun 27, 2009 | Dell Dimension 4550 PC Desktop
Alert system battery voltage low (Beep Beep)
Three possible:
1 does new battery test good?
2 is battery inserted properly (backwards)?
3 do U clean the battery holder with a pencil eraser?
May 12, 2008 | Computers & Internet
Blank screen - won't boot!
iv had this problem , you'll have to put the correct disc for the comptuer and start over again :) otherwise you mite aswell just throw your comptuer out.
Dec 17, 2007 | Dell Dimension 2300 PC Desktop
Dell Dimension XPS PC Desktop Logo
52 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
