Question about KitchenAid KUIS18NNT 18" Automatic Ice Maker with 35lbs. Storage Capacity, Drop Down Door & Accepts Custom Panels
Kitchen aid ice maker full of water - KitchenAid KUIS18NNT 18" Automatic Ice Maker with 35lbs. Storage Capacity, Drop Down Door & Accepts Custom Panels
  • KitchenAid Master
  • 4,654 Answers
Sounds to me like a water level sensor is not working causing water to overflow and flood the ice storage compartment. Try the diagnostics provided in the video above. Here is a link to a service manual=> HERE I am here should you have questions, Thanks Sea Breeze
Posted on Jul 25, 2013
  • 63 Answers
SOURCE: kitchen aid ref, ice maker quit making ice
hi my name is mark, do you have a water filter on this unit. shut off water to ice maker. remove water line from ice maker, hold water line in a bucket slowly turn on water. if you get water. then the fill solinoid has failed. if you do not get water trace water line back to water shut off. if it is the solinoid valve. you will need model and serial number to order part
Posted on Mar 10, 2009
SolutionGuy
  • 331 Answers
SOURCE: kitchen aid under counter ice maker
S, the interior light is timed. If you leave the door open for more than 5 minutes, it'll shut off automatically. Close the light switch manually (at the top up there) and hold for 5 seconds. After you release it, you may see a red LED where the clean light is... disregard for now.
Now replace all of the hoses you removed for cleaning. These can be cleaned using the "cleaning method" posted and labeled on the inside of you IM door.
Now go get some of this, or something similar and follow the cleaning instructions.
As an aside here... I ran a service call for a guy who did exactly what you did, except that he chose to go to Home Depot and get all new tubing. (!!!!) Well, the tubing didn't fit and even if it di it was routed improperly. Then he called me to come fix it.
Close to $200 later everything was back to normal. All he had to do in the first place was to maintain his IM like it was a swimming pool. Get the right chemicals and use them as instructed on the label.
Please don't misunderstand. I'm not scolding or anything like that... it's just that sometimes the simplest approach is the best approach. Your high dollar IM is a complicated and computer controlled piece of equipment, when you start pulling the guts out, the "brain" has a difficult time interpreting what your doing, that's all.
Let us know how it goes. If there are any additional symptoms, please let us know immediately.
Posted on Mar 17, 2009
TheRepairGur
  • 27 Answers
SOURCE: My Kitchen Aid freestanding ice maker keeps going
This is very likely due to a bad main electronic control board but the only way to know for sure is to do some electrical testing with a volt/ohm meter and the wiring diagram located within the appliance. If possible use the meter and the wiring diagram to check input/output voltages looking for discrepancies between the diagram and the actual meter readings.
Go here for: http://www.repairclinic.com/KitchenAid-Ice-Maker-Parts
RepairClinic.com
logonobyline3.jpg?ver=23
appliance parts, help & more
Posted on Apr 09, 2009
rickyrt441
  • 4399 Answers
SOURCE: ice maker stuck in a cleaning cycle kitchen
Is it showing any codes?
Posted on Feb 19, 2011
  • 3 Answers
SOURCE: I have a Kitchen Aid
make sure it has water feed on also it look for a trouble shooting book
Posted on Aug 24, 2011
Buzzing sound Kitchen Aid fridge Model KBLA20EMSS
It may be the arm in the ice maker is down. Even though the ice maker does not have the water hooked up if the arm above the ice bin is down it will still cycle the ice maker try lifting up the arm it should stay up this signals the ice maker that the bin is full and should shut off the ice maker. Hope this helps.
Dec 31, 2013 | KitchenAid KSCS25FKSS Side by Side...
Kitchen aid ice maker not working
make sure water line is not plugged up. The small line can plug.
Oct 22, 2012 | Kenmore Kitchen Aid Ice Maker 4200520...
Water, but "no ice" in my Kitchen Aid
The ice maker not working: ---
Its the problem of water inlet valve. It's a dual valve. This valve has two tubes in it. One for water dispenser and one for ice maker chamber. The one side of valve is working, but other side of the valve is not working. The valve is got stuck in one position
Click this link below to troubleshoot the problem: ----
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
This will help. Thanks. Helpmech.
Oct 28, 2011 | KitchenAid KSCS25FKSS Side by Side...
KITCHEN AID REFRIGERATOR PROBLEM We bought a used Kitchen Aid fridge YKSRS22Q (1993), the ice maker is not working but water does work. What should we check to see why the ice maker doesn't work?
Ice makers work off of temperature. If it's not cold enough in the freezer it won't work. Check the temperature with a thermometer, it should be 0 to +10F
Jan 29, 2011 | Refrigerators
My kitchen aid refrigerator model KSB251NBL..NO ICE
Problem could be a couple of things.One There is a little control in the very back,its should be on the lower right side looking at the freg. from the back.It has a water line running up to the ice maker.If that is ok,you will need to replace the ice maker.It is not a big problem on either.Cost is for the little controll about $30.For the ice maker about &90.
Aug 29, 2009 | KitchenAid Refrigerators
I have a kitchen aid refrigerator freezer. The
the supply line of the ice maker might be blocked please check it.
Aug 18, 2009 | Refrigerators
Kitchen Aid KSRP25F Ice Maker
The ice maker is not working, no ice ice is coming in the tray on my Kitchen Aid KSRP25F Refridgerator, the red light keeps on
blinking
Del
Dec 05, 2008 | KitchenAid Superba Architect KSCS25INSS...
My Kitchen aid ice maker is making hollow ice cubes and will never stop no matter how full the tub gets
hollow ice cubbes generllay a sign of low water pressure, check you instalaiiton lone for good oncoming supply as well as replxce filter if need be
Nov 04, 2008 | Whirlpool Refrigerators
Kitchen Aid Ice maker Stopped working
The ice maker has stopped working. The red led light blinks when the freezer door is opened. Any thoughts?
Nov 22, 2007 | KitchenAid Superba Architect KSCS25INSS...
KitchenAid KUIS18NNT 18" Automatic Ice Maker with 35lbs. Storage Capacity, Drop Down Door & Accepts Custom Panels Logo
205 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
