Question about SWR Music
Change 110v to 220v - SWR Music
Tip
Dynaudio BM - Power from 110V to 240V or 240V to 110V
Hi Guys,<br /><br />This is what I have learnt the hardway so wanted to share it with everyone who wants to get his Dynaudio Speakers converted from 240V to 110V or 110V to 240V.<br /><br />I actually requested many forums including Dynaudio Support as I bought mine from US and they were 110V, I wanted to use it in my Country which has 240V standard, What these guys suggested me was to order the whole AMP Modules for the speakers if I want to have them work in my country. In other words it was a solution of $350 per module totals to $700.<br /><br />Shame on them as I opened the speakers myself and found a small jumper wire hooked up on the connections marked 110V and there were other connectors marked with 220V and 240V.<br />All I did was just took out the jumper from 110 and inserted it in 240V connectors!!<br />Thats about it!<br />So guys forget these mean techiz at Dynaudio and use my experiene to solve your problem :-)<br /><br />Cheers<br />Satch<br /><a href="mailto:satchriani2@hotmail.com">satchriani2@hotmail.com</a>
on Apr 04, 2011 | Dynaudio Acoustics BM6A MK II Active...
What happens if I plug a 110v device into 220v outlet WITH adaptor
Is the adapter simply a plug adapter or does it step down the voltage? If it steps down the 22ovac to 110vac then the device should work fine. If it simply changes the plug to fit then you will fry the amp. What is the brand and model number of the adapter?
Jun 18, 2014 | ART New Art Tube MP Studio V3 VIII Mic...
Connected alesis sr16 with alesis 110v power supply.to 240v mains...........briefly powered up and then nothing. Have I "fried" the adapter or the sr16?
Look carefully at the adaptor and see if it takes any voltage besides 110 (it will say in very tiny print, you will need a magnifying glass). if it does NOT say 220V or 240V then you friend the adaptor. Get another adaptor - most are "dual" voltage meaning they run in the U.S. or overseas.
Also check for "polarity" (which part of your plug is + or - ).
Jan 24, 2013 | Alesis Sr 16 Stereo Drum Machine
Bought from usa to australia changed to recomended fuse, fuse blows as soon as turned on the unit was brand new any ideas ?
hi,
You have to check the working voltage of the adapter of you device. If it purchased from US then it will be 110V. I think the Line voltage in Australia is 220V.Also You have to check is there is any input voltage selector in the in its adaptor . If it there you have to change it to 220V. If there is no such selector then you have to buy a 220v to 110v converter .Then connect the out put of that converter to to your device. You can by this converter at any electronic spare part shope near to you. Or you have to by a new 9V 1.3Amps AC adaptor. When you going to by the converter or a new adaptor take the device. If so they will explain you how to connect the converter or adaptor . By changing a fuse you can't change the operating voltage. If The adapter is designed to use in 110V then the fuse will blow. If you change the fuse and make more experiment with it it will make the full system useless.
ok
Aug 05, 2011 | Lexicon MX200 Multi-Effects Processor
Can this unit be easily converted from 110V to 220V for use in Europe?
im pretty sure they sell a converter kit for pretty much anything, so i wouldnt see why not
May 16, 2011 | Peavey XR 8600D Class D Powered Mixer
110v is pluged to 220v. What part of the organ damage?
This totally depends on what organ you have.
Many would blow the input fuse. Some organs have a wide range power supply that would use either 110 or 220.
What model is it?
Apr 15, 2010 | Yamaha Music
Europower pmp 3000 120v or 220v ?
Unit has wide range power supply will operate on 100 volts to 240 volts without any change other than possible plug adapter to mate with each countries receptacle standard.
Feb 05, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
Europowre pmp 3000 a120v or 220v?
There is a jumper (JP1 or J1). If you cut that jumper, the mixer will operate for 220V. This power supply is the same with the ones used in desktop computers. I did that to my mixer bought from US made for 110v. I replaced that jumper with a switch (from a desktop power supply), I made a whole and I fixed the switch on the pack panel of the mixer. So now, I can switch it manually for 110v or 220v. It's working perfectly. I tested it for long time and no problems. Good luck.
PS. I called the Behringer technical support in the US and they weren't able to teach me that. So I figured it out myself after a big research. See the pictures about my project. :)
Music Logo
26 people viewed this question
Top SWR Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a SWR Music Expert? Answer questions, earn points and help others
