Question about Pyle PPHP153MU 15 1000W Powered Speaker with MP3/USB/SD
No power when plugged in
I've plugged the speaker in to multiple outlets and even used other cables and received no power
  • 3,799 Answers
If it is new take it back or read the manual. If it is second hand, then you may want to check to see if the internal fuse is intact. These power speaker units usually have an internal fuse to back up the one in the mains connector.
Posted on Apr 25, 2013
Speakers won't power on when plugged in
firstly check your power cable by moving the wire in various directions while it is plugged in ac outlet and powered on, if it lit up the standby power LED then the prob lies on the power cable. If not, try opening the speaker system box itself (be sure to unplugged the power cable before opening the box), then visually check inside for the little cylindrical glass type tube(if the circuitry still uses this kind of fuse) if it is burnt-out.
Hope this help pal...
Feb 23, 2013 | Labtec Pulse 285 Computer Speakers
My Remington Keratin Therapy Flat Iron Doesn't Turn On.
see thi steps and fix it.God bless you
If the iron doesn't heat, make sure 1) power is on to the outlet, 2) check the electrical cord and 3) check the thermostat and replace if necessary. Use the VOM.
Oct 15, 2012 | Remington Style Therapy: Keratin Therapy...
Yamaha rx 530 center channel cuts out
Thanks for all the suggestions guys.
I've tried using the balance for left and right speakers, and when the receiver is acting up with the right speaker having a low volume, I tried moving the balance all the way over to the right speaker. The right speaker volume will not increase in volume but the left speaker will decrease in volume.
Just to clarify, the center and the rear speakers are balanced. The issue only happens sometimes when I first power on the receiver I will have no center channel. If I leave everything alone for a few mins, the center channel will come on.
So it seems to me that something one the receiver is going. The question is, can anyone suggest a physical repair for the receiver for these symptoms?
Thanks
Jul 20, 2012 | Yamaha RX-V530 Receiver
Emerson TV Model #LC401EM2F Fix after lightning?
Lightning damage on LCD TV's can be a doozie. You really need to get it checked out by a qualified technician. I've repaired several TV's hit by lightning, most of the time the damage was limited to the power supply board. However, it is possible that multiple boards were damaged. If multiple boards were damaged, it's not worth repairing the set.
Jun 02, 2012 | LG Televison & Video
Toshiba satellite laptop
good question. Indeed through a phone jack one an receive the ever-going current that stays on even if our power is turned off. However to remain brief, to charge a laptop battery from that outlets would be a path I've never encountered, and of-course be careful to consider hooking up to multiples if you plan to even great 1 in each hand Yikes!. if you get them out. strip ends of each cord, then I'd stick with a small..
Nov 02, 2011 | Toshiba Satellite L305-S5908 Notebook
Loud static noise coming front right speaker on home theater system. I've removed all cables and all speaker wires except that one and still get the noise. I've tried plugging the unit into another...
Make certain you have not started some kind of test signal going by looking in the the user manual, if not by all means send it back. Phone or E-Mail the makers helpline first they should sort any problems and confirm you have set it up right.
Jul 04, 2011 | Audio Players & Recorders
I set up my RX-V365 recently, and the center speaker doesnt seem to work. i use it for listening to music, the sound should come out right?
Sound from a speaker, nah, that's an optional feature (kidding).
If you dig into the manual annd go through the setup using the test tones you can prove/disprove the viability of all the speakers and channels. THAT is required before we try to listen to 'music' (assumed 2-channel) on multiple speakers.
Sound Field programs (page 25) can be applied to just about any source. Experiment, even within a given recording. You'll be amazed how different digital processes can make even familiar recordings new and more interesting. I've discovered instruments and sounds in old recording I never noticed before.
Jun 22, 2011 | Yamaha Rx-v365 A/V Home Theater Receiver
My AV receiver turns off a couple of seconds after I turn it on. I did what the manual said, unplugged the power source and removed all of the speakers but it continues to do the same thing. Anything else...
you may have a bad Earth power 110 V AC cable connection which makes such hum / buzz even nothing connected..
Check the connections between components and make sure they are secure before proceeding to the next Step. Sometimes, loose connections can cause a hum.
  • Separate the audio cables from the power cables; electromagnetic interference from the power cables can cause stereo hum. Use cable ties to secure the audio cables away from the power cables.
  • Plug in a surge protector to the outlet, and then plug all the components into that surge protector
  • Connect a ground plug to the surge protector and then plug the ground plug into the main outlet. A ground plug is available at any hardware store, and turns a three prong connection into a two prong. Ground plugs help eliminate 60 cycle hum.
  • 5 Connect the ground wire from your turntable to the ground wire connection on the receiver. If this doesn't work, looking on the back there should be a grounding point,
    Unplug your receiver.. Split a wire and attach one of the splits to the receiver where you will see the text, "ground" or something similar. Attach the other end to something metal such as a pipe that goes into the ground. Secure with electrical tape. Plug in.
    connect the ground wire to a screw on the electrical outlet.
    Read more: How to Fix a Hum on a Stereo Receiver ' eHow.com http://www.ehow.com/how_5183193_fix-hum-stereo-receiver.html#ixzz1PpFHs1Mv
    Take care and please remember to rate me"AS THUMBS UP" Thanks
  • Jun 20, 2011 | Onkyo TX-SR606 Receiver
    I have an older model Harman Kardon AVR and have started hearing humming from the speakers that are attached to it. Is my receiver going bad or is there something else I need to do to fix this problem?
    Take care and please remember to rate "AS THUMBS UP" Thanks
  • Jun 20, 2011 | Harman Kardon AVR 85
    Buzzing sound when sub is on even without turning my amp on, if you can call me on my phone 909 938 9219 it be better for me thanks, i am little slow with my computer, please help
    Buzzing is usally AC line noise leaking into an un-shielded cable somewhere or a floating ground. If the AC plug is reversible, try that. Sometimes the buzz is from an attached device. Make sure all audio cables are plugged in tightly at each end and routed away from or at right angles to any power cords and away from other sources of strong magnetic fields like TV's.
    Disconnect the input(s) and see if it hums in the absence of an audio source. A bad audio cable shield or unwisely-routed audio cables will allow entrance of unwanted signals from external power sources, magnetic fields, even dimmer-controlled track lights.
    I've also seen variable track lights induce noise but it's usually minor.
    Try rotating the power cord in the wall outlet.
    If it still buzzes with no cables or anything external attached there's an internal problem.
    Apr 30, 2011 | KEF Audio PSW 2150 Speaker
    Pyle PPHP153MU 15 1000W Powered Speaker with MP3/USB/SD Logo
    Top Pyle Computers & Internet Experts
    Stan Skaggs
    Stan Skaggs
    Tom Chichester
    Andrew Taylor
    Andrew Taylor
    Are you a Pyle Computer and Internet Expert? Answer questions, earn points and help others
