Question about Rheem 50 GAL ELEC TALL Water Heater 6YR SC 83VR522
My electric water heater won't ignite. - Rheem 50 GAL ELEC TALL Water Heater 6YR SC 83VR522
  • Rheem Master
  • 5,245 Answers
Posted on Apr 20, 2013
We have changed the element and is still not working.
What water heater do you have? Question posted under BW 120V 6 gallon electric.
Element is found on electric water heater.
Igniter is found on gas water heater.
So now it get's confusing what water heater you have.... for example some 6 gallon RV water heaters have both electric and gas. And troubleshoot for that is different than electric water heater.
Copy following link for electric water heater troubleshoot resources:
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
Does tank have 2 elements or 1? Which element did you change... why did you change element before replacing thermostat? What symptoms were you experiencing before changing element?
Is this a new heater? Was tank full of water before power turned ON?
Add a comment and describe problem in detail.
Gene
Jul 29, 2013 | Bradford White M16u6ss 6 Gallon 120v 1500w...
Hotpoint water heater the electric igniter won't spark
Copy following link for troubleshooting igniter, and troubleshoot by type of gas control valve:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#igniter
Add a comment and say what manufacturer appears on label.
Open link above and scroll to top for information about FV lockout.
Mar 16, 2013 | Rheem 50 Gallon FVR NATGAS Water Heater...
I have a 640dors reliance capacity40 water won't stay hot long(electric)
remove the two covers one high and one low and set the temp higher. This time of year with colder water comming in the house the water heater has to work harder to raise the temp of the incomming water. In the summer the incommong water is much warmer. 40 gal is a small water heater and you will only get about 15 gal of hot water with the ice cold water entering the water heater as you use the hot water. You can get a bigger water heater. even better is to go tankless and a have never ending hot water and save money at the same time.
Jan 10, 2013 | Reliance & 40 Gal Electric Mobile Home...
Water heater won't come on
Go to your electrical panel and see if the circuit breaker has tripped,if so then your heater element is bad and may need new water heater,
Oct 10, 2012 | Whirlpool Water Heaters
BFG1H4040T3NOV Whirlpool gas water heater won't ignite
Bad thermocouple or gas control valve.
Good luck,
Marty
Jun 08, 2012 | Whirlpool Water Heaters
GE (Rheem) SmartShield Water Heater. it rained on the hot water heater and now the pilot won't light. Any ideas?
Does it have an electric ignition? If so, remove the pilot light access panel, blow inside the chamber with a hair dryer. Do this until there is no more moisture inside. Then follow the lighting instructions. Try this even if it's a match start. Thanks and please rate.
Sep 05, 2011 | General Electric Water Heaters
Our tankless water heat will not heat the water-it won't ignite
Question posted under Boasch tankless. Model number not known.
Before calling service technician, open following link for Bosch troubleshooting resources, including phone and contact for Bosch, error codes, and possible manual, plus hours of reading and research:
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
As you know from reading manual, tankless water heaters require yearly maintenance by trained service technician, or by homeowner. This action would check gas and pressure, venting draft, condensation drain, burner and combustion parts, igniter and-or pilot light, electrical connections, air intake and general condition of plumbing.
Problem you describe does not include error code.
Open following link for possible help with general plumbing problem:
http://waterheatertimer.org/pdf/No-Error-Code.pdf
Add a comment with model number that appears on side of unit, and I can directly locate possible service bulletins and further troubleshoot resources available at Bosch for possible do-it-yourself diagnosis and repair.
Sep 02, 2011 | Bosch & Tankless LP Hot Water Heater
Pilot will light after 30 seconds when you try to move knob to on position the pilot goes out and heater won't ignite.
You need to replace the thermocouple.
When you light the pilot it is supose to heat the thermocouple.
the thermocouple produces a small electric current which allows the gas valve to open and keep the pilot going. and allowing the main burner to come on.
Jun 21, 2011 | RTO Atwood Water Heater - 6 Gal LP
We have a 2011 Keystone Sprinter 311 BHS camper that we bought last year; it has a 6 gallon gas and electric DSI auto ignition water heater, It won't stay on. When we first turn it on, you can hear...
Are you getting any hot water from taps? If not, check by-pass valve on back for proper positioning. You want cold going in bottom fitting open, as well as hot coming from top fitting open too. Any valves etc., in between should be closed. Let me know what happens please.
May 16, 2011 | Water Heaters
Rheem 50 GAL ELEC TALL Water Heater 6YR SC 83VR522 Logo
99 people viewed this question
Top Rheem Water Heaters Experts
Donni Steen
gizmonix
Level 1 Expert
Jim Goldsmith
Jim Goldsmith
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
