Washer fills but won't start
I have a Maytag Performa, Model LAT2300AAE, top-load washing machine. It fills with water, but it won't start. There's a buzzing sound coming from the knob. I replaced the timer, but that's not the problem. I replaced the lid switch approximately 5 years ago and it still appears to be working fine. I know the problem could be one of several things, but can you offer some guidance as to what the problem might be? Thank you in advance!
  • 261 Answers
SOURCE: won,t drain on rinse cycle
Ok mc we need a timer at this point. You see the timer doing several steps different than before.
Posted on Nov 01, 2008
  • 36 Answers
SOURCE: maytag washer won't fill or agitate; only spins on cycle
sounds like you have a blown fuse. I dont have a schematic so I dont kno where you have to look to find it
Posted on Jan 03, 2009
  • 462 Answers
SOURCE: maytag top load washer won't pump water out=intermittent problem
If your lid switch was the problem I dont think (and I might be wrong) that it would spin in the first place.
Your pump may have a separate belt and it could be loose or worn out but this is on older models. The pump may not be turning or turning and not pumping. The pulley may be turning on the shaft and its not pumping. Give it a spin and see if you see it turning inside. If not replace it.
The motor and timmer sounds good because of the "spin" you discribed. So we are left with the pump or a filter if it has one.
Look in the lower section find the pump front right hand corner I believe. Trace the hose back up to the tub above nothing in between and you have eliminated the filter. I filter could be any shape but will either attach with 2 hoses or 1 hose and attached to the side or bottom of the outer tub.
I think your pump is probably stopped up, strings and lint especially if you have some older rugs, towels, and rags that are shedding or coming apart. You can try and clean it pretty easily Unplug. Then remove it and look inside it. Catch all the water you can and keep another towel close by. Examine the water. Looking for lint and the like. If its pretty clean looking and not turning freely look for signs of something wrapped up inside it.
Hope this helps. Please rate me accordingly and good luck.
Posted on Mar 10, 2009
  • 9 Answers
SOURCE: Leak from under the washer
tub seal has gone bad, will only get worse. Expensive fix,
Posted on Jul 02, 2009
SOURCE: Maytag Atlantis MAV6257AWW
I have a Maytag Atlantis MAV6257AWW. I need to replace the transmission. So I removed all four screws from the inner tub but I couldnt get the inner tub pull out, it's stuck.
From what I read on here, the seal nut doesn't have to be remove in order to remove the inner tub.
I tried every, I even hammer the shaft down from the inside of the tub but still no luck. Can someone help, thanks.
Posted on Oct 19, 2009
I have may tag wash model nu mav5920eww i just hooked it up tried reg wash it filled with water then would not continue to wash went to pause mode
Maytag & Whirlpool washer diagnostic - Fills with water then ...
? 3:03
Jul 11, 2013 - Uploaded by
Troubleshoot your trusty Maytag Washer that has some of the ...washer diagnostic - Fills with water then cycle stops - LAT8014AAE .... Not agitating Maytag 2 belts top load washers - Duration: 26:55. by theapplianceman 23,820 views. 26:55.Washing Machine Keeps Filling With Water and Will Not Agitate ...
Maytag top loading washing machine stopped working & filled with
Dec 02, 2015 | Maytag MAV5920E Top Load Washer
Maytag atlantis washer water won't stop filling with water even when power is off.
water fill valve have a particle of trash or deposit from water.replace water valve and problem solved.
Jan 31, 2013 | Maytag Atlantis MAV6000 Top Load Washer
Top load maytag performa washer won`t stop flling both on wash and rinse cycles.
The switch the tube connects to shuts the water off. Will it cut off on high medium or low level. You can try blowing on the tube to see if it works. It should cut off when you blow.
Oct 15, 2017 | Maytag Performa PAV2200
Washer wont start, it will spin but will not begin the wash or start to fill
It won't wash till the water fills to the point of tripping the water level switch. Check your screens for clogsthemobilian_3029.jpg
Service manual and more
Sep 22, 2011 | Maytag Centennial MTW5800TW Top Load...
My washer fills with water and keeps filling doesn't stop on the selected water level for the load. It doesn't wash because the water keeps filling. What's wrong with my washer? Help please (Maytag...
The problem is simple and easy to fix. Your washer has a tubing which runs from the base of the tub to the water pressure switch. It might have vibrated loose from the switch, or their can be some sediment in the tub. Blow out the tubing and reattach it securely to the switch and pump out the water in the tub. Then try it again. I wrote an article about this:
Help my washer is overflowing !!!
Jan 07, 2011 | Maytag PAV2300 Top Load Washer
I have a Maytag Performa Washer, model number PAVT244AWW, that does not agitate. Everything else is working. It makes a loud noise during the wash and rinse cycles when the agitator is supposed to be...
My Maytag Performa makes a grinding sound when it agitates. When it starts to dump the water it makes a loud grinding on metal sound... really loud. What is the problem and how much to fix?
Sep 05, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Water problem
Apr 01, 2009 | Washing Machines
Burned belt?
Yes, smell like your belt.. if there is water in tub, try to get it out... (wet vac)... slide your washer out and tilt it back so you can see under... there should be 2 belts.. 1 for gear and 1 for water drain pump... and you can check for parts.. good luck...
Jan 23, 2009 | Maytag SAV5710 Top Load Washer
Maytag performa pav2300
Just rehook the clear tube back onto the air dome (back right side of drum), drain any water from the drum, the refill, pressure switch will reset itself. Start to fill on small load size first, then move up when washer starts to be sure it reset all the sizes.
Aug 06, 2008 | Maytag Performa PAV2200
Washing Machines Logo
124 people viewed this question
Top Washing Machines Experts
