Question about HP DeskJet 3520 InkJet Printer
I need a step by step instruction on how to replace ink cartridge for 3520 printer
  • Anonymous Mar 17, 2014
    How to know which cartridge needs replacing #3520
Go to hp and get a free users guide in there you will find out how to replace the ink cartridge
you will have to have your model number
Posted on Apr 19, 2013
don_farr
  • 1011 Answers
SOURCE: my HP J6480 printer will not recognize the ink
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink cartridge?
Please consider the following:
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Don
Posted on Dec 17, 2009
pishta68
  • 579 Answers
SOURCE: ink cartridge light keeps blinking
you need to print only in black if that is all the ink you have, and also you need to remove the color cartridge as it still registers in the printer as able to be used, although it is empty or near so. Did you remove the tape over the print head fron the new ink cartridge? Do a print head alignment, or use the toolbox icon to tell the printer that you just replaced the cartridge. Some HP models chip the ink cartridges so even a refill wont register as a full tank and the printer wont print. chip needs to be reset (difficult) or just replaced with a new cartridge.
Posted on Jul 07, 2008
Instant Help
  • 73 Answers
SOURCE: Printer Reset instructions for HP 564 inkjet cartridge.
Dear, this is basically an auto generated message based on system registery keys, if you want to bypass the message, then there are two ways.
1. put another cartridge in the printer and try to print, after than install the previous (original) cateridge, this will doge the printer as a new cateridge, you problem will be removed. but if you don't have another similar cateridge at hand then follow the step 2 given below.
2. Uninstall the driver, unplug the printer, restart the system and reinstall the printer dirver again, your problem will be removed.
Best regards.
Posted on May 26, 2009
cene765
  • 787 Answers
SOURCE: I have a HP CP1700
Make sure that printer ask for ink cartridges.It can ask for yellow and magenta print heads!!!Check this again and if need replace the print heads.
Posted on Nov 20, 2009
  • 39 Answers
SOURCE: Replaced black ink cartridge and printer keeps asking to replace
The message that persists in saying to "replace black cartridge" could be due to a defective cartridge chip. The chip maintains counts and tells the printer when a new cartridge is installed. If you cartridge is remanufactured, they may have neglected to install a new chip.
Regarding the new fuser not working, I'll have to get back to you on that.
Posted on Feb 19, 2010
Can't get WF-3520 cartridge holder box from far right position so I can remove & replace an ink cartridge
To force cartridge removal do the following
Shut down the printer (if it is powered on)
Now turn the printer on
When you see that the carriage starts to move instantly unplug the printer power cable
Now you can move the carriage freely by hand!
Move it in the cartridge change position and change the cartridge you want to change
Do it just if the printer has a defective cartridge and the carriage won't go to the cartridge change position :)
Hope you found it useful!
Dec 17, 2015 | Epson WorkForce WF-3520 All-in-One Inkjet...
Why does ink cartridge not push down
Epson WorkForce WF 3520 All in One Printer
1. Are you sure you have the correct model ink cartridge?
2. Did you remove the yellow strip as shown in the illustration at the link above?
May 02, 2015 | Epson WorkForce WF-3520 All-in-One Inkjet...
Replace cartridge
Turn on the machine, if it says replace ink press ok and the instructions will be on the screen, if you are replacing early, press setup, maint, ink, lift the scanner, you should see the cover for the ink on the right hand side. After you replace it, let it do its thing , it is going to prime the new one.
Aug 12, 2014 | Epson WorkForce WF-3520 All-in-One Inkjet...
I have a hp desk jet 3520 it wont print it keeps saying intall setup cartridges but i have them installed correctly.
Are these the ink cartridges that came with the unit?
Are you sure they're in the correct positions?
Possible that one of the chips is defective. Try replacing with a new cartridge.
Jul 21, 2014 | HP Deskjet 3520 e-All-in-One -...
I need a manual with the instructions how to replace ink cartridges
Depend of the brand name and model number of you printer..also try to check-up your printer Casing.
I know some printer have instruction already wrote at the case of your printer "how to change printer Ink cartridge. also you can replace your ink cartridge using software operating system command.
Try to do this step.
Click start
Click printers and faxes > right click your default printer icon ( like hp, canon etc.) > choose and click properties
Click printing preferences
Under printing preferences you can see there services
Click services
And then choose cartridge replace( please follow software step-by-step instructions to replace your ink cartridge just read the instruction carefully)
Hope this information will be helpful.
Regards
Aug 25, 2011 | Office Equipment & Supplies
Can't change the ink in a canon printer
Step by step instructions along with pictures can be found at the below site,
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mp_series/pixma_mp240#Overview
1.Click on the subheading " Service & Support ".
2.In the question box type " replace ink cartridge " and click the " search " arrow.
3.Click on " How do I replace the ink cartridge (s)? " in the search results.
4.The instructions you need for ink cartridge replacement will be listed after clicking.
Feb 25, 2011 | Canon PIXMA MP240 All-In-One InkJet...
HP DeskJet 3520 InkJet Printer Logo
Seeker5211
Seeker5211
