Question about Vehicle Parts & Accessories
Still squaking and making noise. Could it be old diff fluid?
    Problem Solver:
  • 17 Answers
Did you check the brakes
Posted on Apr 19, 2013
Can the front differential on a 2003 ford explorer make a loud hum like a wheel bearing. I just replaced the drivers side front wh bearing and it seems to make less noise but it still makes it and changes...
Do the other bearing & change the diff fluid
Then get back to us
Flush the Power Steering Fluid
& add Lubgard,just make sure it
isn't the honda one
Jun 09, 2011 | 2003 Ford Explorer
'03 F150 lariat-rear end makes a whining noise when turning left or right. sometimes feels like brakes are grabbing. I think it started after submersing truck in water.Changed oil in diff. no different.
The noise usually is the clutches in the posi unit not releasing properly when turning, I've had sucess by taking the diff.cover off and cleaning as much old fluid out as possible. Install cover and add two bottles of Ford posi additive and fill with 75/140 synthetic gear lube. It holds about 3.3 litres. Drive vehicle to a parking lot with enough room to do figure eights. At low speed make fairly tight turns in a figure eight. Do this several times, then reverse your direction and repeat. This forces new lube into the clutch packs. Drive vehicle and listen for improvement,
Nov 07, 2010 | 2003 Ford Explorer
Rear diff jolting and making a loud sound with alittle of grindin
What you were told is correct...the rear differential is going out; most definitely.
It is a safety hazard to continue driving the vehicle in that condition...could lock up while driving down the freeway - not a pretty site.
Used diff. anywhere from $400 to $600...invest in a Haynes/Chiltons manual and replace the unit yourself.
Mike...
Nov 20, 2009 | 2001 Chevrolet Camaro
Front grinding noise. All new fluids. Front
yes the spiders can make this noise or the DIFF carrier bearings
Jul 21, 2009 | Jeep Grand Cherokee Cars & Trucks
Rear diff whining noise
Give the old man a pat on the back! There is an oil plug on the rear differential. On a level surface, remove the plug; if oil starts to flow out, the fluid is full. If no oil flows, carefully put your finger in the hole and feel for the oil level. Your finger should go no lower than the first knuckle before you feel oil. If it goes further, you are low on oil and should either fill it up or better yet replace it. Rear axle oil doesn't get replaced nearly often enough in most vehicles and since your truck is 18 years old, would be a bad idea to have it changed. Best of luck.
Greg
Jul 13, 2009 | 1991 Toyota 4Runner
Noise in the rear diff
one of the most common problems with this is different tire sizes on rear is any of ur tires wearing out faster then the rest
May 01, 2009 | 2004 Kia Sorento
Rear diff fluid is a milky color and it whines while driving
Sounds like there is water getting into the diff. Most of the time it is from the vent on the top. That will cause damage to the bearings and make noise.
Mar 09, 2009 | 2001 Jeep Wrangler
I have a 2002 buick rendezvous when all wheel drive is engaged sometimes it makes a terrible groaning noise
The fluid in the versa trak AWD in the rear is old and needs to be drained and refilled. After you drain and refill it, make a bunch of sharp left and right hand turns, then drive it for 10 minutes. Drain and refill it for the second time and problem solved. Use only versa trak fluid available at any GM dealership. Your vehicle takes 2 bottles (16.9 oz) each change. There is a TSB at the Buick dealership on this now.
Dec 24, 2008 | 2002 Buick Rendezvous
Vehicle Parts & Accessories Logo
29 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
