Question about Dell Computers & Internet
On starting my computer up it says "floppy diskette seek failure" press F1 to continue or F2 to run set up utility
I havent had this notice on my screen till approx a week ago, i dont use floppy discs so why is it saying this message. help..
  • Dell Master
  • 5,660 Answers
Go into BIOS Setup, and disable the FDD
Regards,
joecoolvette
Posted on Apr 20, 2013
  • hughes_jacki
    hughes_jacki Apr 22, 2013
    thankyou for your help i will try this and fingers crossed it will be fine, thanx agen, :)
3 Suggested Answers
20YrsCompExp
  • 227 Answers
SOURCE: Hi! my computer doesn't start normally it goes back to the same error every time. Errors: Floppy diskette seek failure Drive 3 not found: Parallel ATA,PATA-1 (PRI IDE Slave) Strike the F1 key to conti
Sounds like you have a bad/disconnected Hard Drive and the system is looking for a second boot device (ie: Floppy with a disk) or your primary IDE channel on your motherboard is bad
Posted on Apr 16, 2009
  • 68 Answers
SOURCE: "Floppy Diskette seek Failure Strike F1 key to
maybe the floppy disk drive is defective or maybe the IDE cable is deffective, or maybe the cable on the floppy drive is not properly inserted , try to replace IDE cable of the floppy drive if still the symptoms happens replace the floppy drive
Posted on Jul 20, 2011
Floppy diskette seek failure strike the F1 key to
it's not a major problem.go to bios screen by pressing F2 and DEL in keyboard at startup you will enter bios screen there you can change the boot device properties.change the first device to hard disk and second to CD or DVD ROM drive.it will solve your problem
Aug 29, 2014 | Computers & Internet
When i switch on computer the screen comes up with Drive1 not found:SerialATA,SATA2 Floppy diskette seek failure Strike the F1 key to continue,F2 to run the set up utility
Ok. It sounds like something happened inside the BIOS settings for the machine. Most PCs todays do NOT have 3.5" floppy disk drives (drive A) anymore. There is a place in the BIOS where you select the type and size floppy drive connected as drive A. One of the options is "NOT INSTALLED" . If your BIOS setting shows a floppy drive and there is none present, every time you boot up it will give the Floppy disk seek error you mention. Next time your boot, select the F2 option. Check to see if a floppy drive is selected. If so, change to NOT INSTALLED. Also, there may be on the advanced page an option of "Floppy seek at bootup" . You can disable this and that will help as well.
Jan 05, 2012 | Computers & Internet
Jul 20, 2011 | Dell OptiPlex GX520n PC Desktop
On the Boot-up screen I get the message: "Diskette
I think you should press F2 to go to the setup page.
There, you should change the order of your boot device.
set the first boot device to hard disk
set the second boot device to cd rom
and the third to floppy.
follow the instructions and click save and continue
Dec 22, 2010 | Dell Inspiron 530 Desktop Computer
Hi, When I try to start my Dimemsion 5150C in Windows XP computer, I received one of the following error messages "Floppy diskette seek failure Strike the F1 key to continue, F2 to run the setup...
The "floppy" disk-drive (3.5-inch diskette) on your computer is broken.
Press F1 to ignore the error, and to boot from your C: drive.
Or, press F2 to enter BIOS SETUP, and then navigate through those "setup" screens to tell the computer to "disable floppy seek", or change the setting from "3.5 1.44Mb drive" to "none".
Or, take the computer to a technician, and buy a replacement disk-drive, and get it installed.
Sep 12, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
On startup a black screen with message "diskette drive seek failure" what does it mean? Then it says press F1 to continue or F2 to enter setup. I always press F1 and it starts up ok. this has only just...
This indicates that your computer is configured to boot on the floppy drive.
1. At the start of the computer Press F2
2. Go to the Boot Device Configuration.
3. Enable Hard Disk Boot Priority.
4. Set the First Boot Priority to Hard Disk
5. Save and Exit.
Please let me know of the outcome. Thank you and regards.
Aug 28, 2010 | Dell Inspiron 530 Desktop Computer
My Dell desktop computer is plugged into a master switch. But I still have to turn on the computer to use it. Lately when I turn on the master switch, the computer turns on automatically. But the Windows...
Press F2 to enter the system setup. Someone or something (Bad Motherboard battery most likely) has reset the BIOS defaults, which includes the Floppy diskette drive controller to be ON. Set Diskette Drive to NONE, then under integrated Devices, set diskette controller to off, save settings and reboot
(ALT + B)
if issue re-occurs then the watch battery on motherboard is bad and needs to be replaced
Jul 16, 2010 | Dell Dimension 3000® Pentium® 4...
Boot up screen says "diskette drive 0 seek failure"
Press F2 look through the menus and remove / disable 3.5 floppy drives.
Jan 06, 2010 | Dell Dimension 8400 PC Desktop
Hi! my computer doesn't start normally it goes back to the same error every time. Errors: Floppy diskette seek failure Drive 3 not found: Parallel ATA,PATA-1 (PRI IDE Slave) Strike the F1 key to continue,...
Press F2 to enter the Bios, on the first screen navigate to the floppy A: drive select disable and the error should go away.
From the sounds of it your Floppy drive is damaged or just bad. you can take it for repair or purchase a new one fairly cheap and replace it yourself. But just disabling it should do the trick since floppy's are pretty much obsolete.
the recovery Disk wont help you unless its an error you get in windows itself btw.. (unless its a OS start problem which this doesn't seem to be)
Apr 16, 2009 | Dell Dimension 3100 PC Desktop
Computers & Internet Logo
64 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
