I have a RCA model p61937 home theater and the volume go down by it self then I cna;t get it to work none , when the volume go down I cant even turn the tv off the picture shows good it change channel
Sometime leaving it unplug for a hour help then it go down again.
4 Suggested Answers
SOURCE: power turns on and off by its self
The problem is the key board controller is malfunctioning. I have contacted a multitude of supply houses even
RCA included and I have not been able to buy the part. However, you can bypass the problem by disabling the key board functions by activating the parental control item, not the password, by using the remote. All the keys on the front panel will be disabled but you can still operate the tv with the remote plus save yourself a cost on parts and labor.
Posted on Apr 13, 2008
SOURCE: OLDER MODEL RCA HOME THEATER PICTURE AND PICTURE
Hi Unykue,
I am an electronics technician who just happened have been given the same set as you because it was giving the previous owner the same problem. Since I am confident in my trade, I took the set and diagnosed noise in the remote receivers input to the cpu.
What this means is that a capacitor( or something) wasn't working properly and was either not filtering the noise out or it was introducing noise into the data stream that controls the TV through your remote control.
My fix was to essentially cut out the entire remote control input to the TV. Since I have a directtv box to give me remote control, I don't care if the TV's remote works anyway.
The way I did this was to open up the unit and find the front I/O board were the buttons meet the switches for power,chaennel, volume, etc. On that board there is a plug with white wires and one black wire. The two wires to cut are the one next to the black wire and the one all the way at the other end of the black wire. These two wires are easy to splice back if you do not like the results of this procedure so that there is really no risk of damaging your set. If you wish to verify the proper wires to cut, they are the two wires that come from the IR receiver's side of the board YET DO NOT GO TO THE OTHER SIDE WITH THE BUTTONS! There is one wire that does indeed go to both sides.
This may not be a perfect solution but it is free. I hope that this will help someone out there.
Len
Posted on Dec 09, 2008
  • 668 Answers
SOURCE: i was watching tv when suddenly the volume control
The front panel Tactile Switches probably need to be replaced. The part # of the switches is 23344507. You can order them through Encompass Elect. 800-638-3328.
Hope this helps,
Skyassoc
Posted on Jul 02, 2009
Bose system is just over 1 yr old, hooked up to Smart Tv ( same age) sound was working fine, turned volume down, no sound at all after that
Hi, You have a Bose Home Theater System hooked up to your television and I'm wondering if you're controlling the volume through the Bose Home Theater System or the television because both have a volume control and if you have the television volume turned down and you're using the Bose Home Theater System for volume or visa-versa then you're not going to get a decent sound. I hope you know what I mean...... CHEERS..
Mar 31, 2016 | Bose Audio Players & Recorders
WE HAVE A RCA HTS 5000 THAT WE CAN NOT FIGURE OUT HOW TO ADJUST SO THE VOLUME IS NOT ALWAYS SO LOUD BUT THAT CHANGES WHEN THE MOVIE OR SOUND CHANGES
Need more info. Are you using the volume control on the unit as your main control or the volume on the TV? I have a setup in which my sound is routed through a 5.1 Teac amp. The sound level on the amp os set and not changed. The volume control on the TV dictates the amount of sound. If the amp volume is set too high, then this will be amplified even more through the TV's sound input (the red and wite RCA cables).
If this is the case, turn down one of the folumes (the one that remains unchanged) and see what happens.
Jun 05, 2011 | RCA Audio Players & Recorders
Speakers way too loud
You don't say how the Samsung routes out to the receiver. I assume you're using its RCA audio L and R jacks. Inability to adequately lower volume usually means you're NOT using a Line Level input, but maybe a speaker feed.
Your TV may have a setting for variable audio out, but even if you use the fixed setting you should be able to lower the playback volume to something comfortable with the receiver's volume knob. It does go down to completely OFF, right?
Jan 23, 2010 | Denon AVR-3805 Receiver
I have an older RCA home theater proformer amp has a model # of PA4500 I cannot get any remote to program to use it, it has no volume dials and you cannot control the volume without a remote and we have...
The PA-4500-M does not have a wireless remote control. The amp turns on when there is an audio signal present at one of the inputs. The power button on the front is the master power, when the amp is ready the front LED will continuously glow RED, when the audio signal is sensed, the LED will glow GREEN. The audio signals must be variable otherwise you cannot control the volume.
Jan 19, 2010 | RCA Audio Players & Recorders
RCA LCD Flat Panel HDTV and RCA Home Theater System--No sound
Video comes from external device to TV - OUT on device and IN on TV.
Sound connects by the red/white cable set (or HDMI). Place set in Audio OUT ports on TV and Audio IN ports on DVD. Then select AUX IN on DVD.
Jan 05, 2010 | RCA RT2380 Home Theatre System System
When i unplug my rca rt2250 home theater system. the green light comes on on the right side. then goes off. everything works good after that speakers sound good. but once in a while that green light comes...
this is the amp IC and while unplugging and plugging it in again helps reset the IC for a little while , it will eventually completely quit and will need replaced
make sure that none of the speaker wires(bare wires) are touching or look like they might be where they are connected at
also if turning up the volume makes it cut out or sound bad then this will also indicate a bad amp IC
Mar 12, 2009 | RCA RT2250 System
Volume decreases by itself
maybe defective speaker or audio output ic or shorted capacitor within audio circuit
Nov 09, 2008 | RCA F32648 32" TV
Rca rt2770 home theater universal remote code
hehehe i just found it mebbe i will tell u mebbe i will jk this is it either - 0790,1913,31023,31609,31254 mebbe one of those will help. the first one worked for mine. i take it u know how to program the remote
Apr 05, 2008 | Audio Players & Recorders
Freezes up
your system needs to be servicedtake it to a tech and have him clean it up.
Feb 17, 2007 | RCA RT2390 System
Televison & Video Logo
Top Televison & Video Experts
