SOURCE: maytag advanced cooking system oven
Once you put the desired temperature, select a cook time and it should solve the heating issue. Atleast that what worked on mine.
SOURCE: I have a Maytag Advanced Cooking System Model
HI. This will occur when there is a fault present within the main control board, or touch pad assembly. use the procedure below to determine where the actual damage is located.
This simple test will help determine whether the ERC (Electronic Range Control or Clock) or the touch pad is defective when F1 error code is present.
Note: Some models incorporate the touch pad in to the ERC as a single assembly, in which case this test is not necessary. Simply replace the ERC (Clock).
Caution: If you feel in any way uncomfortable performing this test or making this repair, please contact a qualified appliance repair technician.
1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing.
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC.
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
5. Turn the power back on.
6. Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping sound).
7. If F1 comes back, replace the ERC. If it does not, replace the touch pad.
SOURCE: maytag, advanced cooking system , super capacity,
A model number would help, but an F-9 code is usually followed by a 1, 2 or 3.
F-9-1 is the board is not seeing the door lock
F-9-2 is the board not seeing the door unlock
F-9-3 is the board seeing both inputs and not knowing the condition of the door lock.
The problem is like caused by a failed switch in the door lock mechanism. This normally requires the replacement of the door lock assembly.
SOURCE: maytag advanced cooking system manual MER5775Q,
Hi stuartwri190,
Kindly check the door latch components. The F9 fault code is about the door latch.
Hope it helps.
Thank you for using FixYa.
