Question about Mantis 2-Cycle Tiller
How to change mantis rototiller clutch
Engine runs fine but tines run slow It seems the clutch is sliping. How do you change the clutch.
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 17 Answers
Dissembling the clutch uses special tools to prevent damage to other parts. A trusted shop would be able to do this cheap, then you can reassemble without special tools
Posted on Nov 27, 2013
Hightower971
  • 183 Answers
SOURCE: engine runs fine but tines won't rotate when
Check the cable tension
Posted on Apr 28, 2009
  • 376 Answers
SOURCE: Squeeze throttle engine doesn't increase/tines don't turn
Most likely the throttle shaft on your carb is stuck from residual fuel. Follow your throttle cable down to your carburetor and see if the shaft is moving when you press the trigger on the handle. If not, try moving it by hand and see if it loosens up. If not you may have to take off the air filter cover and spray some carb cleaner in the throat of the carb while moving the shaft back and forth until it loosens up. That should work for you.
Posted on May 13, 2009
  • 15 Answers
SOURCE: Engine runs fine on 2-cycle Mantis tiller, but
Your problem is a common one on Mantis tillers. The engine sounds like it is not breathing properly. I have fixed dozens of these problems and it is almost always the spark arrestor clogged up. The spark arrestor is found inside a small housing on the muffler (easy to fix). There are 3 screws that need to be removed to get the muffler cover off, then you will see a small housing a little over an inch long with another 3 screws...remove them and you will see a small screen that is probably clogged. Clean it and the housing with a solvent (I usually use carb cleaner) then re-install the arrestor and reassemble the muffler cover. This will fix your problem about 80% of the time.
If that is not the problem you may need to fix the carburetor (take my advice and just buy a new one...not much more expensive than the repair kit and a lot simpler.
Posted on Jun 14, 2009
wolfwizard11
  • 5 Answers
SOURCE: Mantis 2 cycle - tines lose power.
I had this problem today. Loosen the flange bolt. Pull the engine off and check that the hex end of the shaft is lining up with the clutch pad in the engine-that it seats properly. Then make sure the shaft is seated all the way into the worm gear and put the engine back on. You will probably have to wiggle the shaft until it seats into the clutch. Tighten the flange bolt when the engine is seated flush with the worm housing (with no gap). That's all I did and the power is back up. Hopefully you still have your manual with the parts blow-up. (page 29?) BTW, have you checked that the wormgear is greased?
Posted on Aug 04, 2009
  • 54 Answers
SOURCE: i have a mantis tiller, the tines won't turn, the
If the motor rpms up without drag it might be a bad gear in the transfer case or a broken cable if it's a cable drive, could also be a bad or stuck clutch. Hope this helps
Posted on Apr 28, 2010
Engine runs tines dont
The following was extracted from the Mantis owners manual..
At some point, you may find that the tines won't turn when you press the throttle. This may mean the engine isn't sitting all the way down on the worm gear housing. Perhaps you've been using your Tiller
for several years. Or perhaps you've removed the engine for use with the Mantis hedge trimmer attachment, then replaced it. In either case, the flange bolt may have come loose and lifted the engine up.
If this happened you'll notice a gap between the bottom of the engine clutch case and the top of the worm gear housing.
To fix this, loosen the flange bolt. Take the engine off the worm gear housing. Notice the hex head on top of the drive shaft . Inside the clutch case, you'll find the clutch drum. Make sure the hex head
lines up with the clutch drum inside the clutch case. Then put the engine back on the worm gear housing. Make sure the plastic carrying handle is not under the fuel tank. If you've followed these steps properly, there will be no gap between the clutch case and the worm gear housing. Make sure you tighten the flange bolt.
Jun 12, 2015 | Mantis 2-Cycle Tiller
When I Start Mantis Tilleer it starts in gear ( tines are turning)
The Mantis has a speed controlled automatic clutch.
Lower the idle speed by turning the idle screw counter clockwise. The idle screw is attached where the throttle cable meet the carb. The screw has a pointed end that resembles a pencil point.
The engine speed should be adjusted just above stalling.
If the tines turn even when the engine pull rope is pulled, the the clutch is defective and needs repairing.
j
Aug 03, 2013 | Mantis Tiller
Jul 05, 2009 | Mantis 2-Cycle Tiller
Honda FG100 Tiller - Tines wont move
I took the transmission apart and the gears were fine. The friction pads on the centrifugal clutch don't seem to make full contact with the drum. Does anyone know what the thickness of the friction pads are suppose to be? I used some belt dressing on the pads and got some movement on the tines. With no wear on the gears, I guess I'll be replacing the clutch.
May 02, 2009 | Honda Hmantis Mantis Garden Tiller with...
Won't stay running...
I had the same problem with my mantis. It would start fine after a few pulls, but had no power. I changed the plug, replaced the carb completely...nothing helped. Took it to a shop and paid $70 for a tune up that didn't help at all, and the shop owner just said "sorry".
After everything else was done, I pulled the cover off the muffler, (3 screws) then removed 3 screws over a small spark arrestor screen and found it was clogged...cleaned it and guess what...IT WORKS FINE NOW!
The best and easiest fix I have ever done to a small engine. I felt like an idiot, because the exhaust side of the motor MUST be clear to work properly on small engines. The only reason I was removing the muffler in the first place was to check the compression and VOILA!!!
An easy and quick fix I recommend for all Mantis tillers before you waste money on carb issues (which is what the company will tell you to fix to solve this problem).
Apr 19, 2009 | Mantis Tiller
Craftsman rototiller 3 5 model 917 299130 leaks
Sounds like you are speaking of the float bowl.
It should not have a hole in it.
You could purchase the part from Sears or a small engine shop.
If it were mine, I'd remove the bowl, clean it, and patch with a gasoline impervious material such as JB weld.
Apr 05, 2009 | Craftsman Garden
I am looking for fender for honda fg100 rototiller?
If It is a Honda FG100 like in the title the part number is 65141-V06-003
If it is a FG110 like in the description the part number will be 63411-V25-000 FENDER, RR. and 65141-V25-000 FENDER, FR.
Nov 24, 2008 | Honda Hmantis Mantis Garden Tiller with...
Mantis 2-Cycle Tiller Logo
513 people viewed this question
Top Mantis Garden Experts
paulfvincent
Jim Parker
Jim Parker
Mike Squire
Are you a Mantis Garden Expert? Answer questions, earn points and help others
