Question about Dryers
Drive belt tension problem- squeeling belt during drying.
Hi all! I'm stuck for ideas or solutions so any help would be appreciated! -Dryer was running smoothly, but very noisy and took many hours to dry (7+ hrs for a normal load) -I replaced the blower wheel which had totally worn down. This fixed the loud clunking noise, and made airflow possible again. -After putting the dryer back together, it wouldn't turn! So, I replaced the dryer drive belt just to be safe while I was in there. -Now the barrel WILL turn, but makes an awful squeeling noise! When I took the back panel off, two belts are rubbing together between the idler pulley system at the back. -The idler pulley is being drawn heavily to the left (towards the spring) which is pulling the two belt spots together. When I tried to adjust the idler arm to more of a 90 degree angle, it doesn't stay because the attaching ring seems to be heavily greased. Any help would be greatly appreciated! :) -M
  • Dryers Master
  • 7,482 Answers
Hi mhairi_colga
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like the drum rollers are in need of lubrication
Note: This method works with most front loading machines.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer if you have to.
Note: Some tops hinge and tilt backwards so they do not have to be removed and the electrical console with stay with the lid.
Also remove the lint filter and the screws holding the lint filter housing in place.
Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer by removing two screws located on either side of the top of the dryer housing and unplug the door switch.
This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor.Now is a good time to replace the front felt seal on the drum if it needs to be replaced. Be sure to use a good grade of weatherproof cement on the seal to glue it to the drum, sometimes the glue is furnished with the seal.
Now is also a good time to check the belt to see if it has slipped off of the idler arm pulley and also to check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt.
Check your drum rollers for flat spots or wear, if they have flat spots or wear they will make a thumping type of noise.
If your drum rollers have too much wear on them replace them.
If the drum rollers don't have flat spots or wear on them and are only squeeling then they probably only need lubrication.
Remove the rollers and clean the shafts that the roller rolls on, remove any hair,dust,etc from roller and shaft.
Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil, or a light lubricant like Vaseline.
Reassemble the dryer.
Plug back into your electrical receptical.
This should solve your noise problem.
Please take time to rate me
Bud
Posted on Apr 19, 2013
efriend
  • 15 Answers
SOURCE: Maytag dryer
Dear sloika,
I do not believe the problem lies within the dryer unit.
when the dryer unit fails to dry clothes in reasonable time 90% of the time it is the clogged air vent is the reason.
Dryer vent cleaning improves the safety and efficiency of your dryer installation. As dryer vents become filled with lint and other debris, drying time increases and can cause the dryer itself to overheat. This increases energy consumption since the dryer has to run longer to dry your clothes and can also cause fires in the dryer or the dryer duct. The Consumer Product Safety Commission reports dryer related home fires are on the increase.
  • First check your vent hose between the back of dryer and the air outlet on the wall. Vaccum clean the dirty hose and even into the dryer unit using flexable vaccum attachment. also try to vaccum clean airoutlet that goes into your wall as far reach into and much as possible. The dryer's lint filter and its path needs to be cleaned as well.
  • If all air flow path are cleaned it will improve 200% of your drying time.
There is also professional dryer vent cleaners in your area who can help solve the problem. just check your yellowpages..
Posted on Feb 16, 2008
mikedurland
  • 481 Answers
SOURCE: idler pulley arm
there is a certain way that the belt is supposed to loop around the tensioner and motor. this picture might help.b00f604.jpg
Posted on Jul 20, 2008
pgh_pa_guy
  • 2992 Answers
SOURCE: Kenmore gas dryer 97273100 was drying, but making a loud noise
You need a belt. Here's a link to a site with a good set of instructions if you want to try repairing it yourself. (You should DIY. You can save a bunch on the service call and the belt is only about $20.)
http://repair2000.com/wpoolbelt.htm
Posted on Dec 08, 2008
tzweeb
  • 318 Answers
SOURCE: Kenmore 70 series dryer making loud rattling noise, drying ok
it could be a worn motor bearing, but they usually last for 20 years, i would guess that you have a worn drum roller, the thing that holds up the drum and looks like a wheel.
if your sure the motor has a worn bearing then replacing the motor is not easy as you have to unscrew the blower wheel from the motor shaft.
it also may be that you are talking about the idler pulley being worn. it is the device that holds tension against the belt and they also will wear out and be "wobbly"
Posted on Dec 29, 2008
SOURCE: Maytag Dryer clunking noise
may 26 2009
My maytag dryer is making a very loud squelling sounds in some of it cycles. still drying ok
gmalcom
Posted on May 26, 2009
Squeeling noise, very rough idle (sometimes stalling), no engine code
Rough idle / stall at idle Check for vacume leaks & split intake tube or loose clamps on intake. Noise put spot of grease on drive belts if noise goes you may need new belts or a tighten up.
Jun 16, 2012 | 2004 Ford Freestar
2000 Mustang V-6: New Sepentine Belt installed two years ago with very little mileage since (< 1000 miles) and the belt squeels upon engine exceleration. The tension seems way to low as I can easily...
Hi...if you can easily push on the belt then replacement of your tensioner is definitely needed. It has one bolt holding it in place and if you look carefully at the arm of the tensioner you should see a square hole that was designed to use either a 3/8" or 1/2" drive ratchet. Determine what size yours is and insert it into the square hole on the tensioner arm to loosen the tension on the serpentine belt to temporarily and partially remove it in order to remove your old tensioner and replace it with the new one. NOTE: You will have to determine which way to set your ratchet to release tension on your serpentine belt...either "Righty = Tighty" or "Lefty = Loosey"! Next bolt on your new tensioner and again use your rachet to release tension in order to get your serpentine belt back on. Just be careful as your new tensioner will have way more spring power! Any questions just ask.
over4dy
Sep 14, 2011 | 2000 Ford Mustang
Maytag dryer makes loud squeeling noise when it gets hot. Drys clothes but makes such a loud squeeling noise. Have to let it cool down to continue to dry.
Hi and welcome to FixYa, I am Kelly.
A loud squeal is usually caused by either an idler pulley bearing. a drum roller bearing or a loose belt.
Since you did not include a model number I have to respond with generic across the board information. Idler pulleys, drum rollers and belts for Maytags can be found on this link:
(Just past half way down the page) http://www.apwapplianceparts.com/Laundry+Appliance+Parts/Dryer+Appliance+Parts+/Dryer+Drive+Belts+Idler+Pulleys+and+Support+Rollers/default.aspx
You can enter your model number on this page and find your parts: (Choose model number)
http://www.appliancepartspros.com
If you do repair it yourself.... do yourself a HUGE favor and either take a picture of the belt routing or draw a belt routing diagram BEFORE dis-assembly.
Thanks for choosing FixYa,
Kelly
Jun 08, 2011 | Maytag Dryers
Need to replace a pulley on a 2001 silhouette. don't know which onw though
The pulley youll need to replace is called a pulley tensioner,it comes with a automatic tensioner and a pulley all in one unit, when this tensioner wears the drive belt can no longer maintain a correct tension, when tensions are loose a belt noise develops as high RPM are achieved you develop a squeeling noise even at start up. Failure to replace a worn tension developts a glaze on the drive belt thus wearing it out quicker,by all practical means if you reuse the same belt the rotation must be followed,drive belt being rubber in nature developts conicity and fail if rotation is not maintain,so it always a good idea to replace the drive belt when you replace the pulley tensioner
Apr 26, 2011 | Oldsmobile Silhouette Cars & Trucks
85 chevy celebrity. replaced alternator. that one squealed 2. got another. still hear a squeel. does not squeel when belt is off.
ALTERNATOR BELT NEED ADJUSTING AND REPLACING IT GLAZED. WHEN DRIVE BELT GET GLAZED SHINY CAUSE IT TO SLIP AND SQUEAL.REPLACE ALTERNATOR DRIVE BELT. AND ADJUST IT DRIVE BELT TENSION BY TIGHTEN THE UNTIL YOU CAN PRESS DOWN ON THE BELT IN THE LONGEST RUN. YOU NEED TO PRESS DOWN BELT AND GET A 1/4 TO 1/2 INCH DEFLECTION IN BELT.THE BELT CANT BE TOO TIGHT WHERE WHEN YOU PRESS DOWN AT IT WONT GIVE IN NONE TOO TIGHT, WILL CAUSE PREMATURE ALTERNATOR BEARING FAILURE IF DRIVE BELT TOO TIGHT.
Apr 18, 2011 | Chevrolet Celebrity Cars & Trucks
Diagramm serpantine belt 2005 sprinter2500
Hi.
Here the belt routing for 2005 Dodge Sprinter 2005, whch was sold only with the 2.7 engine mounted:
Fig. Accessory Belt Routing-A/C Compressor (1), Power Steering Pump (2), Tensioner (3), Crankshaft Pulley (4), Water Pump (5), Alternator (6), Idler Pulley (7)-All Engines
Here a different view:
Here also the fan belt routing;
Fig. Fan belt routing-Fan pulley (1), Fan belt (2), Crankshaft pulley (3)-3.0L engine shown
PROCEDURE Removal & Installation
2.7L Engine
1. Loosen the tension adjust and remove the A/C compressor drive belt.
2. Attach a 3 / 8 inch drive ratchet to the automatic belt tensioner.
3. Rotate the belt tensioner counterclockwise to release the belt tension.
4. Remove the accessory drive belt, starting with the water pump pulley.
To install:
1. Position the accessory drive belt around every pulley except the water pump pulley.
2. Rotate the drive belt tensioner clockwise, install the accessory drive belt and release the tensioner.
3. Position the A/C Compressor drive belt over the crankshaft pulley and A/C compressor pulley.
4. Tighten the drive belt tensioner.
5. Ensure the belt is seated properly on all of the pulleys.
If this solution was helpful, then please do not forget to Accept.
Writing dedicate solution, sharing skills, researching and extracting info from service documents takes time, and your feedback is important for us.
If you repute any solution useful, please click on Accept.
All the best.
Ginko.
Sep 21, 2010 | Dodge Sprinter Cars & Trucks
Squeeky dryer
belt is stretched from a worn bearing in the belts idler pulley
Replace the belt along with the pulley sold at most Sears stores
Jun 20, 2010 | GE 5.8 Cu. Ft. Extra-Large Capacity Gas...
11087088601 dyer squeels at start; will stop after a bit
The belt is loose and is most likely due to the belt being stretched out. Replace the belt and the tensioner also to solve this squeal.
Apr 14, 2010 | Dryers
Squeeling drive belt
Correct me if I am wrong, as I understand it, the tensioner position is of. It may be the source of the noise or the tension is off and you may need adjustment. If adjusting the belt does not fix it have the tensioner checked out. If all checked ok, there might be a pulley that the belt goes to that is causing the sound, probably because of worn out bearings.
Jul 23, 2009 | 1987 Mercedes-Benz Mercedes Benz 190 Class
Re-Hoover nextra8 hnc380 Tumble dryer
Had this problem with mine. Its the belt tensioner pulleys that have seized and cause the noise.I got 2 net tensioners and fitted them myself.The parts come to about £15 but its a total strip down to replace the parts. been working fine now for about a year
Feb 21, 2008 | Hoover HDC6 Electric Dryer
Dryers Logo
41 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
