Question about Alpine mc3198 For Repair Mercedes Cd Changer Mc3198
Player can't 'see' installed cd's and displays error. Actually the changer is full. Help
2 Suggested Answers
  • 11800 Answers
SOURCE: I have a 1996 Volvo
In your charger the disk is loaded and unloaded this way: When the load command is given the holding tray for the disk moves out, putting the disk in front of the mechanism; then the arm holding the motor places it with its flange in position; the locking lever with it's free spinning flange drops locking the disk to the motor; finally the tray retreats leaving the disk ready to be read. In your case it appears that the locking lever no longer disengages to release the disk - E-02 signals a mechanical failure of the cd mechanism..
To recover the disk you will have to dismantle the changer to access the mechanism, pull on the locking lever (hold in place by a spring) to release the disk and take it out. Then you will have to find out why the lever isn't releasing - defect in the mechanism, the motor that moves the lever has failed or the motor isn't powered because there is something wrong with the control board of the cd mechanism. In the worst case you will have a dead cd mechanism = the entire charger is dead, replacing it will be cheaper than repairing it.
For all of this you will at least a good experience in electronics - ask a friend who has done this before to help you. If there is noone to help you than just cut your losses and replace the changer.
Posted on Jun 13, 2011
2006 Grand Vitara 6-Changer CD Player will not eject cds. 'Push Eject' error comes on.
this is a longshot, try unplugging it, wait about 30 seconds and plug it back in.
Sep 17, 2012 | 2006 Suzuki Grand Vitara
U70 error message on cd player
U70 error message on cd player - Fixya
www.fixya.com/support/t12308553-u70_error_message_cd_player
Apr 5, 2012 - U70 error message on cd player Cd player doesn't work at all. Displays 0 track, 0:00 (min,sec). The play - Technics CD Players question.
Technics error code f 70 CD Players Questions & Answers ...
www.fixya.com > Forum > Tags > error code f 70 > CD Players
Technics cd players error code f 70 related questions and answers. ... won't play cds changer turns on ok, reads error message I have the same problem.
Apr 05, 2012 | Technics Audio Players & Recorders
I HAVE A 2002 MUSTANG GT. THE CD PLAYER IS MESSING UP AND HAS BEEN FOR A WHILE NOW. IT KEEPS TELLING ME CD ERROR AS SOON AS IT IS STARTED. IF I PUSH THE LOAD BUTTON IT TELLS ME ALL THE SLOTS ARE FULL, BUT...
Sound like the cd player itself has the issue. It will have a small sensor in the player to tell the user if all the slots are full with cd's or not. thats either gummed up or blocked from doing its proper job. as far as the cd error goes, thats your laser. If its still the stock 6 disc cd changer, its a good time for you to concider changing out that cd deck.
good luck bro
May 20, 2011 | 2002 Ford Mustang
When i try cd it keeps writing error.and reject every cd plates i insert.it was playing normal 2days ago.pls what do i do when error notice appear.the car is honda 2003 model coupe.thanx
Unfortunately 90% of the time when you get error codes from the CD player/changer it means that there is a mechanical failure in the CD player/changer unit itself and it usually requires CD player/changer rebuild or replacement...
First make sure you have entered the correct anti-theft code. If battery power has been disconnected recently than the stereo display will read CODE if the incorrect anti-theft code is entered the display will read ERR1 thru ERR3. If this is the case you'll have to get the correct anti-theft code. Note; If you enter the incorrect code three times the stereo locks up. Disconnect the battery for more than 30 seconds and then retry.
FYI;Never use adhesive labels or protective disc covers on recordable CD's. Recordable CD's are actually thicker than pre-recorded CD's. Automotive players and changers use rollers to draw the disc into the unit. The added thickness of an adhesive label or protective disc cover may cause the disc to jam. Also CD players and changers are exposed to high temperatures inside the vehicle. High temp will cause the labels adhesive to soften which may cause the labels edges to curl or cause it to bubble. Either one may cause the disc to jam. If the player can not be disassembled and have the discs removed successfully than it will have to be replaced. -hope this helps.
Oct 18, 2010 | 2003 Honda Accord
1998 Honda Accord EX stereo/CD player has Code E on the screen... What is the cause of this and what can I do to fix it?
FYI;Never use adhesive labels or protective disc covers on recordable CD's. Recordable CD's are actually thicker than pre-recorded CD's. Automotive players and changers use rollers to draw the disc into the unit. The added thickness of an adhesive label or protective disc cover may cause the disc to jam. Also CD players and changers are exposed to high temperatures inside the vehicle. High temp will cause the labels adhesive to soften which may cause the labels edges to curl or cause it to bubble. Either one may cause the disc to jam and cause the player to display error codes E-01 thru E-07. If the player can not be disassembled and have the discs removed successfully than it will have to be replaced. -hope this helps.
Oct 18, 2010 | 1998 Honda Accord
Hyundai CD player displays ''error'' for all functions
my cd player in my sonata keep eject the cd can anybody help
SOS
Dec 11, 2009 | Car Audio & Video
6 dsc changer stock radio 99 ford explorer cddj error
I've had GREAT success by resetting the changer. Try unpluging the changer with the power ON, wait a few, then plug back in. It's not hard to remove. Can I assume that you did NOT misload or install any CD' upside down? If not, then proceed with a reset. Can you eject the magazine? If so, proceed with reset. If you can NOT eject the magazine, then you will need to "open up the can" and do a manual eject with power assist by moving the gears while pushing the eject button. Sounds like a lot, but for me it's easy. Remember patience!!
Larry T
Winona Lae, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Jan 26, 2009 | Pioneer DEH-P6800MP CD Player
Pioneer cdx 12 disc changer
According to manual code simply means electrical or mechanical fault - not extremely helpful.
Try to disconnect and reconnect power and it perhaps will reset the problem.
Feb 03, 2008 | Pioneer CDX-FM1289 12-Disc CD Changer
Error message
got the smae problem gc 02. error msg in display..any tips?
Oct 26, 2007 | Cherokee Jeep Grand CD Changers - 10-Disc
Alpine mc3198 For Repair Mercedes Cd Changer Mc3198 Logo
24 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
