What type of line fuse should i use with krell S-300i integrated amp.
I am changing the line fuse and need to know the value type.
  • Audio Player... Master
  • 5,056 Answers
Depending on the design the fuse rating could be on the board, or if you have the original fuse on the case. Say it says 5A then you can replace it with anything up to 5 amps. The type's not that important. A quick blow will do the trick. If it goes again, it's likely to be a shorted part that's causing it.
Posted on Apr 24, 2013
4 Suggested Answers
supertech6
  • 513 Answers
SOURCE: Hello, after plugging on Ipod through my preamp
Sounds like the volume was way up when the iPod turned on. iPods are DC and cause a sudden thump through the speakers when they power on.
If the fuse is not blown, there may be another fuse you have not seen. Most amps have three to five fuses especially a 150watt/channel like the Krell.
Posted on Apr 17, 2010
  • 4234 Answers
SOURCE: Hello If i wanted to refresh my Krell KAV-300i
Can you please provide more information about what you mean by "refresh"? Is there a performance problem or funcitonal problem with the unit?
Thanks,
Dan
Posted on Aug 17, 2010
micromatikal
  • 2777 Answers
SOURCE: I need to connect a
You will need to use the pre-outs on the receiver to hook up your amplifier. I am trying to verify if that model even has pre-outs for the front channels, many do. You will be able to tell quicker than I can by just looking for outputs labeled pre-out for the front channels. Just use the cables you have to attach the Krell amp to those pre-outs and you will be good to go. Let me know if you are unable to locate them... the receiver may not be designed to do that..
Tim
Posted on Sep 15, 2010
Parts included with new amp in box
You should be able to figur that out but first read the instructions they contain some amazing information. I can not help you because I have no idea of what you are asking.
Oct 05, 2014 | Krell KAV-300i 2-Channel Amplifier
Why is it that only my xlr and tape inputs working, no signals from s1, s2, and s3,. thanks in advance
If you're able to switch between them then your issue is possibly relay, relay driver or microprocessor related; all of which require a service techs attention. hope this helps. Gene
Jun 15, 2014 | Krell KAV-300i 2-Channel Amplifier
Please let me know if the speaker output fuses on a KAV2250 are fast or slow blow?
If you have the original fuses you might be able to tell from that. For example are there remains of a coil? If so it's a slow blow.
However you can fit fast blow in there, it should work normally with that. If it blows again it will be an short in a semi-conductor that causes it not the fuse type.
Nov 28, 2010 | Krell KAV2250 Amplifier
Hi, I have to replace all the 20 transistor of my krell kst-100 power amplifier- wich are the best choice? model and company? maybe mj21195g and 6 from onsemi?
Onsemi ( which is motorola) is a good pic for replacements If youre looking at the 21195 , then there must be a compliment to that as well? 21194 or 21196
Oct 10, 2010 | Krell KAV-300i 2-Channel Amplifier
Hello If i wanted to refresh my Krell KAV-300i what parts should i change out? Thanks :)
Thanks,
Dan
Aug 16, 2010 | Krell KAV-300i 2-Channel Amplifier
Hello, after plugging on Ipod through my preamp hooked through my krell kav 300 integrated amp I heard a super loud noise and lost power. I examined the fuse and it looks fine. What do I do?
Apr 17, 2010 | Krell KAV-300i 2-Channel Amplifier
Krell kav300i, increasing volume by itself.
That is an extremely odd problem. I suggest finding a tech in your area who is familiar with the unit, or contacting krell directly.
Sep 21, 2008 | Krell KAV-300i 2-Channel Amplifier
Fuse at power cord blows
first check your speaker cabels for short circuit and speaker for  short coil .after you confirm there is no shotr of cabel wires by checking with avometer in ohm postion.connect speaker if the problem excit your speaker is guilty - change it with same configuration.about switches put it in low order and chech for sound level and you can go up after that.
Mar 05, 2008 | Krell KAV-300i 2-Channel Amplifier
175 people viewed this question
 Grubhead
Grubhead
