Question about Kenmore Dryers
How do i take apart my kenmore dryer model 41793812200 to clean lint?
jsrock516
  • 5911 Answers
SOURCE: Kenmore dryer...How to remove toe panel to clean lint out.
Insert a putty knife into the seam where it meets the front panel about 2 inches in from each side. There is a small retainer clip that you will need top depress in order for the panel to release. If you go to searspartsdirect.com and enter your model number, you can find a helpful illustration under the "Cabinet" heading. The clips I mention are listed as item 46 just ot give you a perspective. I would also strongly recommend that you UNPLUG the dryer before cleaning the interior cabinet. There are live voltages present even with the dryer turned off. Particulary around the heating circuits. I hope you find this information helpful.
Posted on Oct 29, 2008
  • 66 Answers
SOURCE: Kenmore 600 Series Dryer
What is the model#?
Posted on Nov 12, 2008
JR JR
  • 116 Answers
SOURCE: check lint screen light on and dryer not turning on
check belt might be broken,,,,
Posted on Nov 30, 2008
Sea Breeze
  • 4654 Answers
SOURCE: Frigidaire electric dryer; model # FDEB34RGS1- gets TOO hot!
I could not find the model number you listed. I also would be very concerned about over heating until we can find and locate the problem. Look inside the door and compare number with the on listed here at Fixya. Thanks, Sea Breeze
Posted on Mar 25, 2009
  • 91 Answers
SOURCE: Lint fell off trap and down into dryer chute.
for the most if you want to clean it it will take you a while, depending on your model, disconect the unit from the power outlet first,from the back panel remove about 6- to 8 screws an then you will see the inside back panel expose to be vacumm, you'll see the back panel of the shoot that runs behind the dryer, take the i think 4-5 screws an vacumm it, i dont think is going to hurt your machine if a little fell in there, a quick way is try to remove the exhaust tube off the back an insert the vacumm cleaner, to clean the tube going out of the house you can use a strong shopvac, to **** it in or a leaf blower to push it out ...........good luck!
Posted on May 28, 2009
Kenmore elete model 110.67032600 timer changes to higher # and takes a long time to dry on auto dry.
I had this and it was lint trapped in door below lint filter screen.( several handfulls) Took door apart/ reassembled and he worked fine.
Oct 07, 2015 | Kenmore Dryers
How do you take off toe panel from he3 electric kenmore dryer to clean plugged lint
Hello;
My name is Peter. I am a retired field service appliance technician.
There are two spring clips, one on each side of the bottom toe plate panel.
Dec 02, 2014 | Kenmore Dryers
How to clean lint out of a kenmore elite gas dryer?
Professionally Dryer need to be taken apart some.
by removing front of dryer and removing inner tub
.having a good shop vacuum. and a paint brush .We have a service and charge $65 come out and clean dryer and venting.
heavy lint build up in dryer normally means improper venting.
all domestic dryer venting should never go over 8 ft vertical venting the less turns the better and if vent go's up you need induced venting another fan to help dryer push air Sears website will have brake down on your dryer not a hard job if your good with tools
Jul 05, 2014 | Kenmore Elite HE3 Steam 8674 Dryer
How to clean lint out of inside of Kenmore Oasis Elite dryer
Here is a "youtube" video showing how to take the dryer apart. Right around 3:20 is where you need to take the plactic cover off to be ablwe to clean all the lint off.
Jun 26, 2014 | Kenmore Elite Oasis ST 7806 Dryer
Model 41798702891 Kenmore stacked washer/dryer is collecting lint inside the door and putting lint onto the clothes.
I am not much of an expert with dryers but i'll give it a stab. Should there be a filter that catches the lint so that it does not go all over the clothes? Have you got the manual. If not, see if you can find the manual online and see if there is anything mentioned about a lint filter.
Dec 14, 2013 | Kenmore 98702 Stacked Washer/Dryer
I have an electric dryer, Model 110-69822801. We clean the filter after each use, but I notice that there is lots of lint accumlated in the space below the filter. How can I clean it out?
The best and least messy way is to take it apart but you can get a lot of the lint by getting a long narrow condenser coil brush (Used to clean under your refrigerator and sold at any hardware store. I used this trick on mine but I had to go in from the filter side and from the outlet on the back to get most of it but then I pulled the dryer apart to get it totally cleaned. If you have the means and don't mind a mess you can blow it out with compressed air from an air compressor. I would also recommend getting a new filter, sounds like your old one is not stopping all the lint.
Jan 17, 2011 | Kenmore 67632 Electric Dryer
Have a Kenmore Gas Dryer 80 series, model # 110.78842990 that runs but has no heat, have torn everyting apart and cleaned out all the lint, but still no heat.
Burner not lighting/staying lit. Most likely the ignitor.
Check out
http://www.acmehowto.com/howto/appliance/dryer/gdryer/check/ignitor.php
Dec 08, 2009 | Kenmore Dryers
Dryers Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
