Question about Karcher K3.450 1800psi Electric Pressure Washer - -
My Karcher K3.450 won't build up any pressure - it oscillates on and off. It starts to build pressure, then the pressure drops, and it repeats the cycle over and over at a 2 or 3 second interval.
It has never been exposed to freezing temperatures.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 107 Answers
I fixed mine works good easy too watch my video step by step i put it on youtube
http://www.youtube.com/watch?v=UFXSLOBL0Mg
Posted on Oct 18, 2013
SOURCE: Karcher Power Washer Problem
I had the same problem with my Karcher. The recall was lifted Aug. 0f 2007. Tried numerous people at Karcher....head of Customer Service, vice president, etc. No one returns telephone calls not even cutomer service....poor, very poor customer service. Thinking about calling Germany.
Posted on Jun 14, 2008
  • 92 Answers
SOURCE: Karcher electric pressure washer
Dear mike husband,
One reasin for this fault could be a damaged lance or turbo lance. Try by replacing with new ones. If the problem is not solved, then the fault is due to a damaged spill valve. The spill valve could easily be damaged by using not suitable chemical or detergents. After using chemical detergents, one must always rinse the machine by passing pure water. The spill valve could also be damaged by leaving the machine for a long time with pressure in the system. One must never store such machines with pressure still inside. Always press the gun before storing.
Well the solution is to change the spill valve with a new one. In some cases even faulty suction valves can give this problem. But in the majority of cases it is the spill valve.
If you do not know how to fix this problem, it is better to be done by an expirienced technician.
Regards,
MG.
Posted on Nov 05, 2008
  • 12 Answers
SOURCE: Pressure is fine when first started ,if trigger released no Psi
Your uplift injector valve in the water pump is sticking. You need to remove this part. Lube the top o-ring only with a water proof grease. Reinstall this part. You will be up and running again.
You need to use needle nose vise grip tool to easily remove the valve. You need to grind down the vise grip tool to fit the opening where the valve is installed.
To prevent this problem from reoccuring use a pump guard additive.
Posted on Apr 06, 2009
  • 92 Answers
SOURCE: Electric Karcher pressure washer surging when turned on
Dear firenutt681,
One simple thing you can do, is to check for leaks. Check if hose at machine is leaking. Check gun if it is leaking. You can also check if water still comes out of lance nozzel. These leaks however so small, will cause the machine to surge.
Another reason is due to a faulty SPILL VALVE. This spill valve( often called CONTROL VALVE) will contract when the gun is closed. When it contracts under the enclosed pressure it will switch off the machine by means of a Micro Switch. Now if this Spill valve is faulty it will loose its compression under pressure and puts on the micro switch again. This can be seen once in a while or more frequent, as in your case. I sometimes do service Spill Valves, but mostly I replace them with a new one. I do not know the model number of your machine, but normally you have to open the cover and you should spot the spill valve on the head. Most probably you see a thick wire or a cap containing the micro swith. If you find the micro switch, you have found the spill valve. Sometimes it is a bit hard to pull out the spill valve. Myself, in various Karcher models I remove the spill valve by trying to feed water and put on a bit the machine. In this way the spill valve will be spitted out.
Another reason which makes your machine surge, is leakage from from the detergent inlet.
If you do not see no leakages at all....then for sure it is the SPILL VALVE.
If you cannot do this job yourself or you do not find spare parts...you can continue using the machine as it is...but before closing the gun...switch off the electricity. I only recommend this in an emergency. You do this so that you do not leave the machine surging. This surge will for sure damage the electric motor and the capacitor (assuming it is single phase).
Regards,
Fulltech.
Posted on May 30, 2009
  • 56 Answers
SOURCE: Karcher K4.97M electric waterblaster cycling
It sounds to me like the unloader valve is bypassing internally.
Posted on Nov 18, 2009
Why won't my brand new karcher k2700 psi pressure washer start
no water connected to the machine
pull the trigger to allow pressure to build up or to switch the pump on
Oct 26, 2016 | Karcher Garden
Have a Ryobi rpw 2400 petrol new never used yet, can't start it. If switch on O,nothing happen. If on 'I' pressure build up and block the motor .Any idea for solution?
As it's a new machine, check your operators manual it has a trouble shooting guide. But it sounds like the fuel maybe the problem, do not use old fuel as it deteriorates over time.
Dec 16, 2017 | Honda Karcher G2400HH-R Pressure Washer
EASTMAN11607 WON'T BUILD PRESSURE, MAYBE IT'S THE REED?
try puttingafew drops of linseed oil in the air intake, if it is oilless, or check to see if the oil is too low if it is the oil type.
Oct 06, 2012 | Air Tools & Compressors
Karcher K2.180 won't start
If you left the gas setting in the carb your carburetor may be gummed up drain the gas put new gas in and removevair filter ur just a little gas down the carb. And see if will start if it does pour a little mechanic in a bottle in the gas tank that will clean out the system.
Apr 21, 2012 | Karcher Garden
I have a Karcher K3.540 pressure washer. Won't take up detergent and motor pulses ever second if vari-lance increased towards maximim. Motor runs ok at lower pressure but can take 1min to start wh
This fault is within the control head, under the detergent valve is a small spring loaded valve that acts to induce the detergent, this will have failed, the shaft of the component breaks off the disk base leaving a small hole in the centre of the disk. This is enough to allow pressure past the component. The machine will pulse when operated and will not induce the detergent. I've looked everywhere to find this part as I have a karcher with the same fault.
Jan 22, 2012 | Karcher Garden
My karcher 2600 pressure washer gcv160 keeps cutting off?
Check out this link, it should tell you how to fix the problem that you are having with your machine
http://www.wmpcs.com/blog/?p=72
Oct 20, 2010 | Karcher 2500 PSI Pressure Washer
Karcher K4.99M Started to pulse and lose pressure so changed cylinder head which appeared to have a hairline crack. Having reassembled it still pulses but something is restricting flow of water when I...
pulsations indicates an pressure controller suffering from a partially blocked jet at the wand end
blocks up p pressure drops off , unblocks starts pressure to repeat the cycle
Nov 25, 2017 | Karcher Garden
My karcher pressure washer seems to oscilate on and off,the pressure is low ?
The most typical reason for this is that your supply pressure or volume is not sufficient. Try using a larger diameter hose.
Oct 30, 2009 | Karcher K2.26 Electric Power Washer
New Karcher pressure washer won't start
replace the fuel carburetor filter and, or, your fuel tank filter
Aug 31, 2009 | Karcher 2500 PSI Pressure Washer
Karcher K3.450 1800psi Electric Pressure Washer - - Logo
260 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
