Question about AudioBahn A2150HCT Car Audio Amplifier
Protect light stays on
Disconnected it from my jeep and stored in my living room for about 2 weeks went to hook it back up and the fans kick on everything lights up but the protect light wont go out its not my wires or subs i have a 500 watt sony hooked up right now and its working fine idk what to do
techman
  • 3130 Answers
SOURCE: my amp quit working
ok I thought I anwered this one but first thing to try is disconnect all your speakers and see if the light goes out if it doesnt then your gonna need a schematic and a working know how on solid state amplifiers. first check al the outputs for the speakers for dc If theres dc on an output then that output device is shorted or leaky. Ive have open drivers as well as current control transistors leaky or shorted to that made the protection come on.. Good Luck
Posted on Apr 07, 2006
Shuttle83
  • 1139 Answers
SOURCE: AUDIOBAHN a2300hct problems
This indicates a possibility of a power supply issue, you may have to open up the unit and take voltage measurements to determine if the voltages are correct. In order to do this you will need a schematic diagram of the unit. Once you have the schematic you will be abor to tell which voltages are legitimate. I hope this helps
Posted on Sep 16, 2007
  • 631 Answers
SOURCE: audiobahn a8000t problem
If the protect LED is lit, the amp probably has shortedoutput transistors. To eliminate other possible causes, read throughthe following page:
Amp in Protect Mode - Troubleshooting
Let me know if you have any other questions.
Posted on Nov 25, 2008
audio20
  • 22 Answers
SOURCE: VR3 Amp Protection Light problem
Looks like you have covered all the basics.
The remote wire is the switch that turns the amp on and off. So you are probably just killing the power to the amp.
Sounds like a short in the amp itself if all the input and output wires are disconnected and the protection is still coming on.
Posted on Mar 28, 2009
  • 506 Answers
SOURCE: audiobahn a8002t amplifier in protection mode
Let's measure some voltages. If you have a DMM measure the DC voltage at your amps power supply input. If much less than 10 volts I would suspect you may have possibly damage your power wire. When you have a lot of current flowing through a wire the resistance will change and cause a larger voltage to drop across that wire. Having to low of an input voltage is a trigger mode for some amplifiers to go into protection. Let me know what you find and we can go from there.
Posted on Dec 22, 2009
2007 town & counrty (3.8) cooling fans staying on
the radiator temperature is broken or cable to it is disconnected ?
if true they are set to run constant the fans to protect the engine from overheating. also check the relay is still seated correctly.
Dec 23, 2013 | 2007 Chrysler Town & Country LX New Cars
Lights won't work on Harbor Breeze ceiling fan
Ceiling fans operated with remote controls, pull chains, and/or wall switches tend to get confused and just fail. You can try disconnecting power at the source and, while pausing briefly, remove batteries from the remote and push all buttons to eliminate the "stuck button" cause. Then, reconnect power and try various combinations of controls until something works or you give up in frustration.
May 03, 2017 | Dryers
Harbor Breeze ceiling fan lights won't work
Check light wire in ceiling to make sure it didn't come loose.
Jun 06, 2013 | Dryers
Hot to install living room fan
mcdevito75 here, Most stores selling these ceiling fans will send someone to install it for a small fee or even a nice tip. First you"d need 2 people as the fan motor is 3--5 LBs in weight and has to be supported to hook up wires. If your handy and can follow the directions and have 2 people give it a try. If not, look for a handy preson in your area.
Jul 24, 2010 | Hampton Bay Dryers
I have a pyle 1000w 2 channel amp.just got it last week. last night driving home, stops working. protection light stays on. when i checked it, it was hot. so im assuming the thermal protection kicked on....
keep it in a vented area dont ever cover it position it were nothing will block it.it sounds like it does not have a fan so they sell those fans that you sit your laptop on.they cost about 10 bucks and wire it to your amp remote and ground inputs and it should help it stay cool....
May 24, 2010 | Pyle Car Audio & Video
Furnace kicks off and right back on
If this is a newer furnace, an indication of an error is that the room air blower stays on. Get in front of the furnace and see if you can see any blinking lights. Try not to remove any panels as you will erase any error codes. There should ba a small viewing port that you can look through. Once you count the blinks, look at the wiring diagram for the error code chart. It may give you a starting point. Can you tell us a make and model number of the system?
Dec 29, 2009 | Heating & Cooling
Hunter Fan # 20723 The Westminster - lights delayed when turn on
Here is the answer I received from Hunter Technical Support.
"The light fixtures are manufactured with a limiter that prevents a higher than recommended wattage bulb from working. The limiter causes the slight delay even when the correct bulbs are is in use."
Pretty annoying if you ask me.
Jan 25, 2009 | Hunter 28096 Westminster 52" Ceiling Fan...
Engine light goes just went on... 95 jeep wrangeler 2.5L
go to auto zone or parts store like that and have them pull the codes...it will help in fixing it
Nov 13, 2008 | 2005 Jeep Wrangler
Have a Denon 685 receiver. Purchased a Sony HD tuner (tuner only --$99). Hooked it up to phono input and it worked. After a while protection circuit clicked in. Used integrated tuner in unit. Worked longer...
if you disconnect speaker wire from rear and the problem is solved you will have a real problem in speaker wiring-you must fix it first or disconnect it from receiver and put new wires instead of.
Jul 16, 2008 | Denon Audio Players & Recorders
This Hampton Bay light fan fixture eats Light Bulbs
Read the manual to find out which size bulbs (base size and wattage) you need.
If you did use the right type of bulb and it lasted only 2 weeks, take them back to the store where you boght them for a refund.
Mike
Jan 17, 2008 | Hampton Bay 24750 Huntington III Ceiling...
AudioBahn A2150HCT Car Audio Amplifier Logo
Top AudioBahn Car Audio & Video Experts
Professor_V
Professor_V
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you an AudioBahn Car Audio and Video Expert? Answer questions, earn points and help others
