Question about Sharp AL 1631 Copier
Roller Peplacement Al1631
I replaced the roller but I still have a flashing red roller light.
A technician needs to reset that in service mode (code 24-07)
Posted on Mar 11, 2009
Flashing red button on printer feed. Rolls spinning but paper not coming out!
Dear
Its a mech.. failure, The pickup rubber (roller) have dusts also it separation pad or roller, Try to clean with a dampened lint free cloth.
It may also happen the roller may gets teared, in that case it has to be replaced.
Thanks.
Feb 28, 2015 | Office Equipment & Supplies
Red flashing light still on even after replacing p4014n catridge
Could be a paper jam inside the machine(pick up: between the tray and cartridge compartment or EXIT: Between fuser and EXIT UNIT.
ALSO could be BAD SEPARATION ROLLER IN THE PAPER CASSETTE TRAY and UPPER SEPARATION ROLLER OR BROKEN FUSER. Question? call 917-359-7432
Jun 10, 2014 | HP LaserJet P4014n Printer
Red indicator light is red for roller
Sounds like your roller is jammed up with bits of thread and hair... get in there and really look at those ends... pull/cut but remove the bits of hair that's jamming it up.
Dec 29, 2012 | Vacuums
Vacuum roller won't turn and there's no suctions. Red light Doesn't blink
go to http://www.dyson.com/
get the support and download the model, troubleshooting, video for your trouble.
God bless you
Sep 16, 2012 | Dyson DC28 Animal Bagless Upright Vacuum
After turning on power , brush roller freezes and indicator light turns red
try turning the roller by hand UNPLUG VACUUM FIRST
it should turn very easy, otherwise it is binding
all uprights have this problem eventually
hair and fibers get in roller bushing and seize
luckily disassembling is relatively easy, same procedure as replacing the small belt that drives the roller. Take the extra step and take out the roller slip off bushings and clean everything
have fun
alex
Feb 06, 2012 | Euro-Pro NV22 Shark Navigator Bagless...
How to fix red light flashing on my vax mach air pet and family
If you make sure that the roller is clear you just press the button near the left wheel that says 'Brushbar reset'. This worked with mine straight away. :)
Jan 03, 2012 | Vacuums
A loud clicking sound
This means that a gear is jammed or broken somewhere. Check for waste full and empty or drum waste roller and unblock the jammed toner inside that unit or check fuser gear if broken then replace it.
Nov 23, 2009 | Sharp AL 1631 Copier
ROLLER ROTATING KNOB TURNS CONSTANTLY ON SHARP AL1631
Many copiers will do this if you have run out of toner.Copiers will turn over trying to add toner from the cartridge to the developer unit.
Nov 18, 2009 | Sharp AL 1631 Copier
Red light flashing on panel
It is saying you need to replace the drum unit.
Oct 13, 2009 | Sharp AL 1631 Copier
Paper feed problem
please check if the rubber roller that pulls the paper inside the machine check if it is clean because after long use this roller becomes so smooth ddue to dust and doesnt take in the paper , first clean it ,wipe with wet towel  try again
Oct 27, 2007 | Xerox 5305 Copier
Sharp AL 1631 Copier Logo
60 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
