Question about LG LD450EAL Dehumidifier
LG LD450EAL error code 01
What is error code 01
2 Suggested Answers
  • 11800 Answers
SOURCE: HI I have an LG-LD450EAL
Check the bucket first, it might be full of water and the unit refuses to start because otherwise the water would spill.
If after emptying the bucket you get the same CH 10 message then the sensor assembly, Part # 6877A30013M, has failed and you will need to change it - here it is
http://www.encompassparts.com/products/?6877A30013M
Easy to change, just take out the rear covers and the new part plugs into the control board - the old one is secured with a small plastic clip , crimp it to disengage it.
Posted on May 04, 2011
LG LD450EAL no power
Try resetting the GFI breaker, assuming it is connected to one. Also check the main breaker panel to make sure the breaker is not tripped. Unfortunately the electronic panels do go bad in these systems after a few years of service. Try resetting the unit. There should be a tiny reset button on the back. Also if the bucket is full it will not turn on, make sure it is in place and seated properly or it will not turn on. There may be a reset on the cord itself as well, hope this helps.
Jun 02, 2014 | LG Dehumidifiers
Turn on, runs for about one minute theb code O1 appears and it shuts off
The Error Code 01, indicates that the air intake filter needs to be removed and cleaned.
Hope this helps you and thanks for choosing FixYa.
Sep 23, 2011 | LG Dehumidifiers
Have a year old lg dehumidifier and a code of 01 appears in the window and will not start.
The error Code 01 indicates that either the air intake filter is dirty and needs to be removed and cleaned and/or the water collection bucket is not installed properly. Turn the unit OFF & unplug it, before attempting any service work.
Hope this helped you & thanks for choosing FixYa.
Sep 12, 2011 | LG LHD45EL Dehumidifier
My dehumidifier gives the code of 01 in the display window and will not turn on.
Error Code '1' indicates that the air intake filter needs to be removed and thoroughly cleaned. be sure to turn the unit OFF and unplug it, before removing the filter. Never operate the unit without the filter in place. Doing so, could cause damage to the unit.
Hope this helped you and thanks for choosing FixYa.
Sep 08, 2011 | LG LHD459EL Dehumidifier
How do I hook this up to drain through a hose
The following link is to the Owner's Manual for your unit. Once the link opens, look to the right of the page and you will see Dehumidifiers Manual English. Click on that and the manual will download. Yours is a unique setup, so it's best you see not only the instructions, but also the pictures. Look at the section entitled Disposing of Collected Water, Page 12.
http://www.lg.com/us/appliances/dehumidifiers/LG-LD450EAL.jsp
Hope this helps you. Please let me know. Thanks.
Jul 06, 2011 | LG LHD459EL Dehumidifier
Timer switch mode is inoperable. no lights in timer setting, the lg ld450eal model operates continously. please advise how to program the 2 hour or 4 hour timer
With the Dehumidifier switch on, pressing the Timer Button should changed between 2hr and 4hr mode.
If this is what you're doing and it isn't lighting the LED nextto the 2hr and 4hr can you confirm what setting you have for the humidity?
Jun 25, 2011 | LG LHD45EL Dehumidifier
Hi, When I tried to start my dehumidifier, it won't work and indicate CH 01. The bucket is totally empty and in good place. What this CH 01 means?
Your model is no longer in manufacture or available. However, I was able to locate the Owners Manual for you. It does not list a CH 01 Error Code, but does list other reasons why your unit want turn ON.
http://www.lg.com/us/support/product/support-product-profile.jsp?customerModelCode=LHD45EL&matchedModelCode=1000001989&searchEngineModelCode=LHD45EL&targetPage=support-product-profile&initialTab=documents#
In the past, I have recommended turning the Master ON/OFF Switch to OFF and unplugging the unit for 12-15 minutes. This will give the unit time to hopefully, reset itself. Then Plug the unit back in and turn the Master ON/OFF Switch to ON. Set the humidity control as you normally would. If it successfully reset itself, it should operate normally.
If you continue to have problems, contact LG Customer Support at 800-243-0000.
Hope this helped you to solve the problem.
Apr 14, 2011 | LG LHD45EL Dehumidifier
My new LG "ld450eal" DeHumidifier
The switch that says 'Bucket is full' is not adjusted properly.
It will need to be adjusted, normally a screw driver or pliers,
so that when its empty the switch is not made or the contacts
are open.
If it is in adjustment properly, then the switch is bad and needs
replacing.
Before you replace it, check to make sure the wires leading to it
are not touching, it may be sending a signal meaning 'full' by
electricaly touching each other at the switch.
Feb 25, 2011 | LG Dehumidifiers
Gettin error code ch 01 wont run
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Nov 13, 2010 | LG LHD45EL Dehumidifier
Has ch 01 light on
I'm having the same problem. I spoke with LG today and this error code means the unit is not calculating the correct humidity percentage. I told him that I don't really care what percentage it calcs, I just want it to collect water. He told me there was no way to override this and that it will need service to operate.
Aug 08, 2009 | LG LHD45EL Dehumidifier
LG LD450EAL Dehumidifier Logo
143 people viewed this question
Top LG Dehumidifiers Experts
Bill Long
Craig Butler
Craig Butler
Gil Shultz
Are you a LG Dehumidifier Expert? Answer questions, earn points and help others
