Question about Garden
2000 grasshopper transmission whine
I have a transmission whine on the right and left sides while turning,is this normal?
onyeredson
  • 404 Answers
SOURCE: Right turn signals stay on, left stay off.
Hi!
From your good description I would say either a bad earth or corrosion.
Check bulbs too as wrong wattage can cause grief.
Make sure all bulb contacts inside holder are not corroded (With ignition OFF) also the sides are clean too for good earthing, still a problem? then check all wire connections to each indicator, a little WD40 or similar all round is a great help when doing this.
Good Luck!
Paul 'W'
Onyer~EDson(:0) {#><U.K.
Posted on Jan 16, 2009
  • 7353 Answers
SOURCE: 2000 plymouth grand voyager - right turn signal
the back bulb is out, replace it.
Posted on Sep 25, 2009
  • 111 Answers
SOURCE: Front whine when turning left and at whine when
Whine usually occurs on tight turns maximising pump output and/or pump may be worn and needs replacement. Leakage can be from pump reservor,connection, or power rack and pinion steering assy. Spray off any area with a sign of fluid with a brake clean or carb. cleaner and look for signs of leakage.
Posted on Oct 08, 2009
SOURCE: I cleaned my stovetop (gas with 4 burners). Now
It works now.After two days of trying, it now works like it should. I'm thinking something needed to dry.
Posted on Oct 12, 2009
  • 165 Answers
SOURCE: my 1997 dodge intrepid makes
power steering pump.check fluid level first tyhen the high &low pressure lines for leaks.keep posted
Posted on May 23, 2011
How to troubleshoot a high pitched whine in the right fron side of my Nissan Maxima 2004
Could be one of the belts slipping or worn out. Might even be the water pump bearing. Does the whine increase/decrease as you rev? Whine louder if you suddenly accelerate?
Dec 09, 2014 | 2004 Nissan Maxima
Whining noise in rear end as the transmission shifts
could be brakes... or bearings... check both and repost with more details if that doesnt fix.
Feb 08, 2014 | 2000 Chevrolet Silverado
Whining noise progressively gets louder with speed
One wheel turning faster than the other is normal if both wheels are off the ground. If one wheel is dragging when the other wheel is on the ground, it could be brakes or a wheel hub bearing.
Usually if the noise happens on right turns, the left hub bearing is failing, and vice versa.
May 07, 2013 | 2000 Buick LeSabre
Power steering pump is whining, I replaced it and the new one whines just as loud. what could be wrong
make sure your using power steering fluid recommended for the vehicle. If automatic transmission fluid it aerates causing bubbles. It's very similar to the effect of shaking a bottle of liquid detergent vigorously when half full. Having that much air in the system can cause it to whine very loudly and reduce the life of the pump.
Oct 14, 2010 | 1999 Ford Ranger SuperCab
Whining when i press gas
normally, the only part of your automatic transmission that will make a whining noise is the pump. it usually whines when iether the fluid is low or more commonly when the transmission oil filter is getting plugged up.
the power steering pump will also make a whining noise too.
turn the wheel all the way to the right and hold steady pressure against the stop. this puts maximum force on the power steering pump and, if the power steering pump is the one making the whine, it will change the sound of it. (usually louder).
if the trans pump is making the whine noise, it should sound different in neutral compared to drive. this test will really only work if it make the noise without the vehicle moving. if it wont do it at idle hold the rpms at 2000 or so.
if you decide the noise is coming from the transmission, and the transmission filter has not been replaced (assuming you installed a used transmission), replace the filter by removing the oil pan.
oh and also, if it is the power steering pump you should be able to make it make the whining noise while the vehicle is stationary. if it wont make noise unless its moving its not the power steering pump.
Mar 23, 2010 | 2003 Chevrolet TrailBlazer
2000 Jeep Cherokee Gear Grinding & 4WD Whine sound
Give a try by change your transmission/filters and Transfer case oil.
Oct 27, 2009 | 2000 Jeep Cherokee
Front whine when turning left and at whine when starting driving. Power steering and transmission fluid good level.Steering is good. Transmission shifts good. Some fluid on carport located left front of...
Oct 08, 2009 | 2005 Buick LaCrosse
Car makes a whining noise when turning left or right.
hi,if you turn the steering wheel in pull position,left or right it's normal to have whining noise,the system is sefl-bleeding if there is air ,ty
Mar 26, 2009 | 1999 Mercedes-Benz Mercedes Benz Sl Class
2000 GMC Jimmy Transmission Whine
Does it sound like a loud winding sound coming from the front right side? I have a 2001 Jimmy and the 4wd tries to engage when driving up steep hills and going at highway speeds. The actuator vacuum switch engaged when the transfer case vacuum switch sends the vacuumed air to the actuator. What is happening is their is either a leak in the vacuum lines, a faulty actuator switch, or a faulty transfer case vacuum switch. When the jimmy has enough air pulling in, the extra vacuum is trying to push the actuator switch in when it is not supposed to. It is a much cheaper fix than a transmission. GMC should have recalled the whole 4wd system on any of the S10's, the JImmy's, and Blazers.
Jul 30, 2008 | 2000 GMC Jimmy
Garden Logo
48 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
