Question about Garden
Carburetor leaking and not getting gas to the cylinder
I took the carburator apart as much as i can and curently dont have any ideas for how to get the carburetor working properly thank you
  • 7,482 Answers
Hi chrisgritema
Sounds like you have dirt/debris in your caburetor jets,fuel passages or a diaphgram that is becoming non-flexible.
Check/Clean/Replace your Air Filter, a dirty air filter can make your engine run to rich with fuel.
Also be sure to check and clean your spark arrestor in the exaust,if you have one installed on your engine.
Note: ALWAYS USE COMPRESSED AIR TO CLEAN YOUR JETS AND PASSAGES, VERY IMPORTANT.
Note:Before you disassemble the carburetor:
Write down on a piece of paper or take a picture of how the linkage attaches to your carburetor for later reference when you go to reinstall your carburetor.
Mark each piece with a awl, or some kind of instrument that will make an alignment scratch before you disassemble the carburetor into separate pieces.
That way you will know which way it goes back together when you reassemble it.
Sometimes you can get by with priming the carburetor or by using a very small shot of starting fluid and letting it run a few times like that, and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Be sure to check your fuel tank for water and dirt/debris, if there is water/debris then you need to clean your tank.
Check you fuel line condition after a while they will degrade and need replacment.
Check/Clean/Replace your fuel filter if you have one, normally they are located in the fuel tank of chainsaws and weedeaters.
When you remove your fuel lines from the carburetor be sure to make a drawing to how the lines are connected to the carburetor or take a pictue for later reference.
Normally the big line will be the line the fuel filter is connected to inside of the tank.The smaller of the two lines is the return to the fuel tank from the carburetor after it is pumped thru the carburetor by the primer bulb.
Make sure you are using fresh fuel...and oil if your using a two cycle chainsaw or weedeater with the oil to the right mixture...too much oil as it can cause hard starting and excessive smoking.
If the chainsaw/trimmer is over a couple of years old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
The diaphgram may look good and flexible, but it can be deceiving and not act as a fuel pump as it should because it has become too hard and will cause hard starting,start and run and shut off, etc.
When you clean your carburetor, I recommend that you use a laquer thinner type cleaner to clean and dissolve the laquer build-up in the float and needle jet passages.
Be sure to remove all plastic and rubber parts before using the laquer thinner because it can dissolve the plastic parts and render them unuseable.
Be sure to use COMPRESSED AIR to blow out all the fuel and air passages.The higher air pressure is needed to blow some of the trash/debris from the fuel or air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Keep in mind that the float (if you have one) for the carburetor must be level when you go to reassemble the carburetor or follow the instructions you get with the carburetor kit, or you could also ask the parts man that you get your kit from.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their original position before you started.
Note:
The little spring inside of the carburetor goes under the float arm.
That is where your fuel inlet needle/float valve is located...on the arm at the end.
Normally there is a small indention in the carburetor base and a small protrusion on the underneath of the float arm where the spring will be in the right postion for installation.
The spring will set in the indention and you will install the float arm with the needle/float valve and float rod into position over top of the spring,you will push down until it is in position and then you can tighten the screw that holds the float arm assembly in position.
Once you have your carburetor cleaned/rebuilt that should solve your problem.
Please take time to rate me
Bud
Posted on Apr 20, 2013
Testimonial: "thank you bud this is helpful i will be sure to use your advice when i get back to fixing the lawn mower tomarrow its a little push mower 5 hp by craftsman "
Gentron 10000w generator has a leaking carburator
Your carburetor float valve may be stuck open. You'll have to remove the carburetor, remove the sediment bowl at the bottom of the carburetor (where the float is), and check the float. Is it filled with gas? Replace the float if it is. If the float is dry inside, then remove the float and clean the needle valve & seat. (be careful to note how the float pin, linkage, spring, etc. are positioned so you properly reassemble. After cleaning & reassembling, turn the carburetor upside down & try blowing into the gas line connection on the carburetor. You shouldn't be able to blow air. Turn the carburetor right side up & repeat. If you can blow air into the carburetor's gas line connection, the float valve & seat are properly working. Reinstall the carburetor. You should be good to go.
Dec 03, 2013 | Gentron 10,000W Generator with Electric...
I have a 99 ktm 250 sx. Had to get cylinder replated and a new piston. I put the bike back together and oil was leaking from the front lower end of the cylinder and i wont idle. Took the bike back ap
If there is a leak in the head gasket it will never run properly. Maybe the carburetor is plugged if it has sat for a while. The gas/oil mixture can go bad over time. The leak could be from a loose gas line. Or possibly even oil dripping from the oil filter if you just cleaned and re-oiled it.
Aug 10, 2013 | Motorcycles
1998mazda 626 4 cylinder will not start unless you pour gas in carburator whats the trouble
3 things.1 the carburetor has internal leak and there no fuel in the carb,
2 the choke is a enrichment device make sure it works and last thing make sure3 the accelerator pump is spraying fuel when you pump the gas .good luck
Apr 19, 2013 | Cars & Trucks
My Echo SHC-212 floods out and will not start. Even with no choke and throtle wide open it will still flood cylinder. I have good spark.
Check your choke prime bulb and carburetor lines - sounds like its clogged and gas is barely leaking into flood the cylinder
Jan 25, 2013 | Echo Garden
I have a vacuum operated petcock on my 2000 sportster & replaced the petcock after gas leaking from diaphragm, how do I get gas to go to carburator now
Hi Terri, make sure you have a vacuum line hooked up from the intake manifold to the petcock. Good luck.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Sep 19, 2012 | 2002 Harley Davidson XL Sportster 883
Pump bulb on craftsman weed blower and no gas pumps into the bulb
If you slacken the screws fuel will leak as you have broken the seal between the carb body and the primer bulb so this is quite normal, behind the bulb is a plate with a red non return valve, if this valve is faulty it will not pump fuel, or if the filter in the tank is part blocked it will not pump fuel
Aug 26, 2012 | Garden
It was running after a carb re-build. now my bulb isn't pulling gas when i pump it
The bulb and/or fuel lines could have a small hole in them, losing vacuum, introducing air into the fuel system and causing problem. First off, check inside the fuel tank and make sure the fuel filter is attatched to fuel line. This is a common place for the line to break and if it does, it floats, introducing LOTS of air and a malfunctioning purge/primer bulb. When you depress the bulb, the vacuum created actually allows gas to Flow to the carburetor as it is pushing any air/old gas back to the fuel tank. So, in summary. Carefully check the condition of ALL of the fuel lines ,fuel filter and the bulb itself. If they are dry, non-flexible, or cracked, they need to be replaced.
Sep 16, 2011 | Poulan Garden
Oil smells like it has gas in it, will this damage any internal components?
Sounds like one or more Carburetor float valve is stuck open. Carburetors need overhaul. Gas in crankcase is not only damaging to engine, but dangerous.
Jul 11, 2009 | 1979 Suzuki GS 750 E
Carburetor adjustment weed eater fl sst 25,will only run if held 90% to the right.
My machine didn't run idle either. Took carburator apart of the Sst 25. Cleaned it with gasoline and a brush. But no luck. Figured it must be the nozzle of the idle. There are two more or less hidden black adjustment screws for the nozzles (idle and gas). I used a plastic tube from a ballpoint to take screw out, ran some air through it, reassembled it and now the machine runs smooth again...
Apr 22, 2009 | Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
