Question about Epson Stylus CX7000F All-In-One Printer
Paper keeps jamming
One day I got my first paper jam every with this printer, and it has never printed since. I've tried opening a new package of paper so it's not damp, fanned through it, didn't load too much, loaded it correctly like alway. Even unplugged the printer for a half hour in case something wanted to re-set itself. Nothing makes any different. The first piece of paper goes halfway into the printer, then stops. I press OK to clear it, start again, and the same thing happens.
futureloginn
  • 734 Answers
SOURCE: Epson Aculaser C900 - Paper Jam Notice, but no Jam?
Step1
Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred.
Step
Turn off the printer.
Step
Remove any paper trays. Inspect them for wrinkled or damaged paper.
Step
Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
Step
5
If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
Step
6
If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly (see A). The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
Step
7
If the paper does tear, try rotating the roller gears manually to free the paper (see B). Don't force anything, though.
Step
8
Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
Step
9
If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
Posted on Dec 04, 2008
pineworks
  • 4041 Answers
SOURCE: No paper jam but still says there is a paper jam
Hello there even if you not see any thing jams it worth a try. There this may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 15, 2010
SOURCE: automatic document feeder pulls paper through only part way
You need to replace the document feeder motor the gears on the motor shaft are split and slipping. New motor is 12.72 at http://www.compassmicro.com/parts2.cfm
Posted on Jul 13, 2010
  • 1218 Answers
SOURCE: Epson R320 "General Error" message - unable to clear
If you are getting a 'carriage jam' error as soon as you turn on your Epson printer with no tasks in progress, then check for any piece of paper stuck in the carriage. Remove the paper carefully. If the paper tears, part of it might remain inside the paper path and damage the product.
Fix 'Carriage Jam' : Open Door, clear carriage jam,
and then press OK to continue' error message
Turn off the printer and open it to see where the paper is stuck.
Manually move the carriage toward the opposite side.
Check the paper path and remove any piece of paper or any other object that is stuck in the path.
Reconnect the power cord and turn on the printer.
http://www.fixya.com/support/t5192341-epson_photo_1400_paper_feed_ink
Posted on Oct 04, 2010
  • 2386 Answers
SOURCE: Have completely cleared papaer path, unable to
you can get the technical support from Epson Official site HERE
Good Luck
do rate the solution if it helps
Posted on Nov 28, 2010
Jammed paper
You might need to update your drivers. If this doesn't help, there might be some loose gear inside the feeder . Try checking if there are also objects stuck.
Apr 17, 2012 | Epson Stylus R265 InkJet Photo Printer
Jam on roller
I had many jams using a Kodak printer, but lately I've been fanning the paper, which they may have told me to do, but I didn't know how to do it. Here is a step by step way to do it. Take the stack of paper you plan on using in your printer & straighten it by taking it by each side & tapping it on a surface (like a desk top). Bend the stack of paper as if going to fold it in half. On one side, the stack is fanned out. Grab the paper on the long sides with both hands & slide it into the printer tray. Go ahead & print, I've had fewer jams since loading my paper this way. Give it a try, see if it works for you!!!
Feb 21, 2012 | HP LaserJet 1020 Printer
I've got a 4 by 6 photo paper jam in my Lexmark S405 all-in-one printer.
Please follow the steps below to fix the problem:
1. Remove the sheets of paper from the feeder.
2. Try to reach for the paper jam.
3. If paper jam can't be reached, open the printer cover to access the cartridge area. You may be able to get a better hold of the paper jam in the cartridge area.
4. Remove the paper jam and make sure not to tear or leave any torn piece of paper in the printer.
When paper jam is clear, try to print a document again to verify that the problem is fixed.
If problem continues, please contact Lexmark Technical Support Center for additional assistance.
Sep 01, 2011 | Lexmark All-in-One Printer with PictBridge
Please help with cannon PIXMA MP150 printer problem, when trying to print, It reads that paper is jammed but I've checked several times and no paper is jammed. Printer will not print due to this...
Hello and Welcome to FixYa!
Paper jam means their may be small bit paper jam in side
, actually there are some "micro sensors" that detect a paper jam. There will be tiny piece of paper inside those sensors, thus tripping the sensor and paper jammed keeps coming up.
To solve this first of all Open printer cover and check to make sure no paper or foreign objects obstructing the printer feeder
, If you become sure that now really there is no paper, dust or foreign objects then Turn the printer off, and disconnect the AC power-cable. Open the printer cover & now give the printer a "blow-job" by compressed air.
If still problem exist then best & final option is to just contact to any Canon Printers service provider.
I hope this solution helps you
Thank you for using FixYa!
Aug 04, 2011 | Canon PIXMA MP150 All-In-One InkJet...
I have a problem with our ricoh printer at work. It is a ricoh aficio AP410N, and the serial # is Q3256500416. It keeps getting paper jams and nothing will print. I called tech support a month ago and all...
Did you try to start with a new pack of paper? Laser printers are very sensitive to humidity of the paper, or a little curled paper. You can start to turn the paper that is in the engine right now upside down. Sometimes this will help. If this doesn't work, than take a closed, new box/package of paper and try again. You might have an environmental problem with your paper. If it works well with the new package, try to store the paper on a better place (not at a window/heater/in a closed box/package etc.)
Jul 07, 2011 | Ricoh Office Equipment & Supplies
Error 241.1 Paper Jam. I have reseated the tray
Brand New T652n lexmark printer get a paper jam every time! just opened and haven't been able to print one paper. Doesn't matter if you print from tray one or tray two. It gets stuck right after the rollers pick it up and try to send it to the toner. Any suggestions? I've tried to reseat the toner, plain paper, sized the paper correctly, I've tried just about everything I can think of! I can feed paper manually through the top tray, and it will print. But, just using the manual tray defeats the purpose of the other two trays. Anyone else having this issue?
May 26, 2010 | Dell 5310n Laser Printer
Canon MP210 Paper Jam
A common issue is moisture. As the relative humidity changes, the paper will absorb some of the excess moisture. (Ink jets don't get as hot as other printers; but they do have temperature changes during operation.)
Unfortunately, the only solution that I have ever found is to use paper from a just opened package. Try to keep only enough paper in the printer for a short duration of printing (1-2 weeks). Keep the rest of an open package of paper somewhere else where the temperature and humidity stays fairly constant.
I hope this helps.
Feb 26, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
Epson Stylus photo 340 r printer paper jam when trying to print
first, make sure you the paper correctly to avoid paper jam.
Single Sheets 1. Open the paper support and raise the extension. 2. Place your paper short edge first against the right edge of the feeder, under the tab, with the printable (whiter or glossier) side up. If you are loading multiple sheets, fan the stack of paper before loading it to prevent paper jams. Note: Don’t load paper above the arrow mark inside the left edge guide. Some special papers can be loaded only one sheet at a time. Slide the left edge guide against the paper. Make sure it is snug, but not so tight that the paper is bent. (For letter- or A4-size paper, you may not need to move the edge guide over.) paper.4.2.1.jpg 4. Open the output tray and pull out the extension. You should also follow these guidelines:Always load the short edge first, even when you’re printing landscape-oriented pictures. • When using special papers, check the paper package for additional instructions. Some papers require using a support sheet included in the package. Note: Always keep unused paper in the original package and store it flat to prevent curling.
if you loaded the paper, it jammed again, remove the paper and tried to print, still the same, its a hardware issue, alraedy, the printers roller is broken
Feb 09, 2010 | Epson Office Equipment & Supplies
Canon MP470 keeps saying "paper jammed"
I had the same problem for DAYS and there was no paper jammed at all. I went to the cannon site as a last ditch effort & the solution below fixed it. Just clean the rollers and the link tells you how. Good luck!
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=15403
Jan 04, 2010 | Canon PIXMA MP470 All-in-One Printer
4355 papar jam error solution
THE PRINTERS MANUFACTURED BY HP ARE HAVING THIS PROBLEM IN COMMON ALL THE WAY. WE SHOULD TAKE FOLLOWING PRISCPRIPTIONS WHILE RUNNING THESE PRINTERS
1. LOAD PAPERS AT SOME DISTANCE FROM THE PAPER LIFTER THAT MEANS KEEP THE PAPERS SOMEWHAT BEHING YOU KEEP THEM
2. WHEN THE PRINTERS ARE OLD THEM GET THEIR PAPER LIFTER CHECKED AND TRY TO PRINT ONE PAPER AT A TIME.
THANKS
PROUD TO BE AN INDIAN
KAMAL DEV JHALLI
HAVE A GOOD DAY
Nov 25, 2009 | HP Officejet 4355 All-In-One InkJet...
Epson Stylus  CX7000F All-In-One Printer Logo
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
