Question about Stanley Bostitch 2hp 6gal Air Compressor Cap2060p
My Bostich CAP60PB-OF does not start
Plugged it in (yes, checked power source) and it simply won't go on... is there a reset switch I don't know about...?
    Top Expert:
  • Stanley Master
  • 35,521 Answers
How about a defective power switch?
Posted on Jul 11, 2013
I have a 94 honda civic ex and it's having
I would have the ignition switch checked, not the key switch but whats behind the key switch. Ignition Switch!
Jul 02, 2013 | Cars & Trucks
My whirlpool imperial seventy won't start
Unplug unbit, remove screws in console and lift panel. remove connector from push to start switch anc check continuity.
Feb 16, 2013 | Whirlpool Dryers
** TV won't turn on.** No picture or sound. Please Help !
If the red light won't come on it is not getting power.First,try plugging it in to a different outlet,or unplug one of the gadgets you know is working and plug the tv in there.You are simply switching.If you know that there is power coming from the outlet and it still won't come on then you'll have to check the cord;don't go much farther than that without expert help.
Apr 04, 2012 | Televison & Video
Dryer won't start
Obvious stuff: Check main power source. Is the dryer plugged in? Do other electrical things work when plugged in to the outlet? If not, check fuses or circuit breakers. If good, is the timer/cycle control out of the "Off" position? Try several different settings.
Door check: Is the door safety switch closing? If it is or if you don't know if it is, and if you can get to the switch, you can take the wires off the switch and connect them together with a jumper wire ( unplug the machine before you do this!). With the wires clear of any metal, plug the machine back in, then press the start switch (you can leave the door open). If the machine starts, the door switch is defective.
Sound check: Do you hear a motor running when you press the Start button? Listen carefully; electric motors are very quiet. If the motor is running, your drum belt is probably broken or has come off the idler pulley. If you can take the front (sometimes the back) off the machine, this is an easy fix. Just put the belt back on the pulleys and around the tumbler drum, Note: there is a reason the belt came off if it's not broken. Look for loose or damaged pulleys or springs, including on the motor.
Do you hear a hum without the motor running? If so it indicates wearing of the motor bearings, brushes or the stator. Brushes can usually be replaced easily, but other motor problems require professional repair or replacement.
Smell check: Any unusual odors when you try to start the machine? A hot rubber smell means belt trouble. Check the belt as above. An electrical burning smell means motor or other electrical failure. Call a repair man unless you know what you are doing.
Electrical check: If you can read an electrical schematic (usually on a sticker inside the dryer cabinet or in the owner's manual) and you can use a multimeter, check continuity in the timer/cycle control, relays and switches. If you don;t understand electricity, don't mess with it! It can kill you, especially if your dryer power is 220VAC.
Mar 17, 2012 | Dryers
Lookbook will not power on
A computer that won't start can be both alarming and infuriating, especially if you're on a deadline or you haven't been backing up all your data (like we all tend to do). Don't panic, though-this problem often has a simple solution.
1.If your desktop computer does nothing at all when you try to start it, first check that the power cable is securely plugged in at the back of the computer as well as into a working power outlet. It's amazing how often this is the case.
2.If you're starting from a button on the keyboard, make sure the keyboard is connected to the computer.
3.If the computer is plugged into a surge protector, see if the surge protector has a reset switch that you can push. (If it doesn't have a reset switch and the problem is with the surge protector, it will need to be replaced.) Try plugging a lamp or other device into one of the surge protector's outlets to make sure it's working.
4.If you can hear the computer's fan or hard-disk drive, or if you can see indicator lights on the main unit but the monitor stays dark, make sure that the monitor is connected to a working power source, that it's turned on and that it's securely connected to the computer via the video cable.
5.If the monitor and computer have power but the computer displays a "Non-system disk or disk error" message, check to make sure you didn't leave a disk in the A: drive. If you did, eject it and restart the computer.
6.If the operating system still won't start even though the computer and monitor have power, try restarting with a Windows CD-ROM in the CD-ROM drive or, if you've got a Macintosh, with a Mac OS disc in the CD-ROM drive. (You can start a Mac from the CDROM drive by holding down the C key while starting up.)
7.If the operating system then starts, your problem is probably with the startup hard drive or with the operating system installed on it. If you can't fix the drive, you'll have to replace it. (See also How to Fix Bad Sectors on a Hard Disk and How to Recover Lost Files.)
Aug 26, 2011 | Computers & Internet
My desktop computer won't turn on it just keeps blinking orange.
1. If your desktop computer does nothing at all when you try to start it, first check that the power cable is securely plugged in at the back of the computer as well as into a working power outlet. It's amazing how often this is the case.
2. If you're starting from a button on the keyboard, make sure the keyboard is connected to the computer.
3. If the computer is plugged into a surge protector, see if the surge protector has a reset switch that you can push. (If it doesn't have a reset switch and the problem is with the surge protector, it will need to be replaced.) Try plugging a lamp or other device into one of the surge protector's outlets to make sure it's working.
4. If you can hear the computer's fan or hard-disk drive, or if you can see indicator lights on the main unit but the monitor stays dark, make sure that the monitor is connected to a working power source, that it's turned on and that it's securely connected to the computer via the video cable.
5. If the monitor and computer have power but the computer displays a "Non-system disk or disk error" message, check to make sure you didn't leave a disk in the A: drive. If you did, eject it and restart the computer.
6. If the operating system still won't start even though the computer and monitor have power, try restarting with a Windows CD-ROM in the CD-ROM drive or, if you've got a Macintosh, with a Mac OS disc in the CD-ROM drive. (You can start a Mac from the CDROM drive by holding down the C key while starting up.)
7. If the operating system then starts, your problem is probably with the startup hard drive or with the operating system installed on it. If you can't fix the drive, you'll have to replace it.
You can check it here as well:
The minute your computer's hard disk starts to act flaky, make sure you have an up-to-date backup. Then you can do some simple diagnostics and repairs. Both Windows and Mac OS come with built-in hard-disk utility software that scans your hard disk for errors and attempts to fix them.
1. Double-click on My Computer to open the My Computer window.
2. Select the disk that you want to diagnose and repair.
3. Choose Properties from the File menu. You should see the Properties window for the drive that you selected.
4. Choose the Tools tab.
5. Click the Check Now button under Error Checking Status.
6. Depending on your version of Windows, choose either "Thorough" or "Scan for and Attempt Recovery of Bad Sectors."
7. Click on Start.
Aug 17, 2011 | Computers & Internet
Used my Bostich CAP2000P for total of less than 2 hours. (not continuous). Now it won't start, have 115 volts at switch, 115 volts at motor. replaced regulator switch. Does not smell of any electrical...
If the motor cover was removed to test power there and it is there. Check for electric continuity across the motor with the power leads disconnected. If the motor is electrical open, find the open or replace the motor.
Inside the motor is a thermal overload motor protection device, it may be defective
Aug 29, 2017 | Stanley FactoryReconditioned Bostitch...
My brother's PS3 on my non-HD tv. We tried connecting and getting different S-video cables but it still won't show up anything. We know the input channel is correct, it just won't show. My...
Yes the display settings need to be reset since he had HDTV and you don't. I do this by simply having the PS off then press power button and hold it for 5 seconds.
Jun 09, 2011 | Sony Playstation 3 (PS3) Console
Machine will not work. I checked the power source and also the cord is plugged into the machine and power source and still nothing
I don't fully understand what you mean but I assume the machine does not come on?
Some fax machines have a power switch, others don't.
Did you check for a power switch on the machine itself? Might have got turned off by accident.
If the fax suddenly quit, I'm afraid the problem is with the power circuit inside the fax machine.
You may need to take it to a service depot.
May 31, 2011 | Samsung SF-560 Plain Paper Laser Fax
Stanley Bostitch 2hp 6gal Air Compressor Cap2060p Logo
Top Stanley Air Tools & Compressors Experts
John Trevino
yoopertech
Joe Garcia
Joe Garcia
Are you a Stanley Air Tool and Compressor Expert? Answer questions, earn points and help others
