Question about Ryobi 18volt 12" Cordless Drill Model P206
My Ryobi SA1802 drill is sparking and smoking, what's the deal?
It started shooting sparks and smoking, I let it sit and now everytime I use it , the same thing happens. Is it broken? Or am I doing something wrong?
3 Suggested Answers
SOURCE: Ryobi impact drill compatibility with normal drill bits
Round bits are not compatible with the Ryobi impact drivers. You need the hex shank "quick connect" bits and accessories. There is an adapter available. it is basically a regular style of keyless drill chuck with the quick connect hex shank that should fit right in to your Impact.
Posted on Apr 11, 2009
  • 15 Answers
SOURCE: Compatability issues with new Ryobi Lithium Ion Batteries
something is wrong. take it back if possible.
Posted on Oct 10, 2009
Trouble shooting leaf blower problems
first check for spark then is the fuel fresh does it fire is you put a few drops of fuel down the carb
May 18, 2012 | Ryobi Garden
Can not get my Ryobi gas trimmer to start. It is fairly new and have never had a problem. It is getting gas and I've changed the spark plug but still can't get it to start.
There are 2 stroke and 4 stroke Ryobi's. The most common non-spark problem is the coil. (at least for me) Is it getting spark???
Sep 12, 2011 | Ryobi Garden
Ran last year, won't start this year. Changed fuel and replaced spark plug. Checked spark and attempted to start with battery and tried with pull cord but no start. pulled plug and it had fuel on it so...
It might have tipped over on its side. Look at the air filter, if you see oil or gas on the filter then you might have to remove and clean the carburetor. I would start by cleaning/replacing the air filter and trying it again. If its getting fuel and the spark plug works then the only other side of the fire triangle is air.
Jun 05, 2011 | Ryobi Backpack Blower 25.4cc
Paslode 16G finish nailer fires intermittently. Fan runs with each trigger pull but nail only fires about 1 out of 10 pulls if I'm lucky. I've installed a new gas canister so I know thats not the...
Clean it and oil it according to directions, then put a dab of dielectric grease on top of the spark plug. If this does not work ...Change the spark plug. I found one spark plug that had broken in half and made good contact intermittently which caused the problem you describe
Nov 27, 2010 | Craftsman Nailer Kit, Palm Air Driver
When using my panasonic 12v ey6409 drill there are sparks and smoke coming out at the rear, should I be concerned.
the tool with the brake will throw some sparks when it creates the short to stop rotation, but the SMOKE is an indication of a burnt motor and yes you should be concerned. Do you smell a burning odor when running if so the motor will soon fail.
Jun 30, 2010 | Panasonic Drill/Driver Kit 12 Volt
Ryobi 775r won't start. I replaced the spark plug but still no go. I have never replaced the fuel line didn't know that was necessary
make sure you have fresh gas miture first, then put spark plug on housing as you pull it over (with the switch on) watch for spark if its there then its a gas problem. old stinky gas is usually what happens when it sits for months. carb may need to be rebuilt if it still won't start. also check exhaust screen to make sure its not plugged.
Jul 16, 2009 | Ryobi Garden
Ryobi 18volt 12" Cordless Drill Model P206 Logo
158 people viewed this question
Top Ryobi Drills Experts
JOHN LAPIER
Are you a Ryobi Drill Expert? Answer questions, earn points and help others
