Question about Kenmore 23612 Progressive PowerMate Bagged Canister Vacuum
Kenmore model #116.22650C vacuum cleaner will not shut off; I need to umplug it off the electric wall outlet.
  • 85 Answers
SOURCE: vacuum cleaner will not pick up
How to Repair a Vacuum Cleaner
http://home.howstuffworks.com/how-to-repair-small-appliances8.htm
Posted on Feb 26, 2009
SOURCE: Kenmore Vacuum cleaner #175.3866180 bags and belt
I logged into the Kenmore website, entered the vacuum model no. and found that the bag has been superceeded by 20-50004, which appears to be available only from Kenmore. The belt required is #5270.
Posted on Aug 03, 2009
dnewcombe1
  • 1564 Answers
SOURCE: i need the owners manual for kenmore cannister 24212
If you type in the model number on your searchbar, the website will be listed "after" all the sponored sites. Use the site that has YOUR manufacturers name in the url. Under the "support" section choose manuals and especially the term pdf. Thank you, Dana
Posted on Feb 13, 2010
  • 52 Answers
SOURCE: how to disassemble power head on kenmore vacuum
uselly there is 2 scews and a couple of lock tabs
Posted on Mar 03, 2010
joeguest2
  • 2080 Answers
SOURCE: need owners manual for kenmore progressive vacuum cleaner model 116
First of all, thank you very much for choosing FIXYA today for your online technical support needs.
Here is a direct link to the ONLINE USER'S MANUAL for that model:
http://www.managemylife.com/mmh/lis_pdf/OWNM/L0412323.pdf
To view the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and blue highlighted text just above.
This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents, although many computers already have this type of utility pre-installed.
You can download this free at WWW.ADOBE.COM if necessary. Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, then follow the onscreen instructions to install the software on your computer.
I truly hope that was helpful to you.
Good luck and take care.
Joe.
Posted on Nov 29, 2011
Lately as I'm vacuuming, my vacuum will turn off. I can start it again, and it will shut off again. It seems like a power issue. Happens different places in the home, so it is not the outlet.
Some vacs shut off when the dirt bag is full Check your brush area and see if there is dirt or bits of string like things wrapped around the brush or the brush ends. This will cause the machine to shut down as well if there is pressure holding the brushes. Will it run if you wiggle the plug if so you could have a bad plug as well.
Jul 07, 2015 | Kenmore Vacuums
Vacuum cleaner Motors plural shut off during operation.
Probably not. Both motors usually wont stop working at the same time. You have given us very little information. Model number? Brand?
May 10, 2015 | Vacuums
Electrolux mondo z1175 vacuum cleaner not working.
Do not get upset with me, but I must ask this question!!! 1) Did u try any other appliance in that outlet, or 2) Did you go back to the original outlet to see if the vacuum works there? It is kind of a coincidence that it quit working only after you moved it to another area. Let me know please!
Nov 15, 2014 | Vacuums
Light keeps blinking
http://www.searspartsdirect.com/partsdirect/user-manuals/uh30010com-hoover-parts-vacuum-manual
WARNING: TO REDUCE RISK OF PERSONAL INJURY - UNPLUG CLEANER BEFORE SERVICING
PROBLEM POSSIBLE REASON POSSIBLE SOLUTION
2. Blown fuse or tripped breaker.
4. Thermal protector activated. (power
light is flashing)
1. Disposable bag is full. ("Check Bag"
indicator illumJnated red)
1. Disposable bag not installed correctly.
3. Brushroll is worn out.
2. Check fuse or breaker in home. Replace fuse/reset breaker.
4. Turn the cleaner off and disconnect it from the electrical
outlet. Then allow cleaner to cool for 30 minutes. If the
thermal protector continues to activate see Needs Service
solution #5.
1. Replace disposable bag - Pg. 9.
1. Review disposable bag removal and replacement - Pg. 9.
3. Replace brushroll - Pg. 10.
Mar 11, 2014 | Hoover UH30010COM Bagged Vacuum
Was vacuuming with no problem and the vaccum just shut off. . .what can I do?
Check that the electrical cord if fully inserted in the
wall outlet. See if the vac has a circuit breaker switch
on the electrical plug called a GCFI,or on the vac itself,which probably has tripped. Good luck.
Apr 01, 2010 | Hoover U6437-900 / U6439-900 Windtunnel...
This Model likes to shoot electrical sparks between the plug and wall outlet when plugging in. I'm afraid I'm going to burn out an outlet.
This sounds might hazardous! Worry less about burning out an outlet, and more about the risk of electrocuting yourself!
There's an electrical short-circuit somewhere, and the first place to look is the flex. Flex often gets damaged, usually just where it leaves the plug or where it enters the machine, especially if it's been pulled a lot. Damage is not always visible externally. I'd get it looked at by someone competent to deal with electrics. Better safe than sorry!
Feb 13, 2010 | Hoover U8311900 WindTunnel 2 Vacuum
Dyson DC07 won't shut off
It sounds like the power switch is no good.replace it.
Aug 27, 2009 | Kenmore 23612 Progressive PowerMate Bagged...
Power cut off after handle was dropped on floor while vacuuming
connections inside the handle came loose. happens to me all the time. take the handle apart and connect the wires back.
May 16, 2009 | Oreck XL Ultra Bagged Upright Vacuum
Vacuum will not turn on
Kenmore Model 116, behind the Vacuum cleaner there is a Motor Reset switch which you need to press.
1. Make sure the Vacuum Cleaner is unplugged.
2. Press the reset button gently in with a pen.
3. Plug back the Vacuum cleaner and it should work.
Jan 31, 2009 | Vacuums
Kenmore 21875
My first recomendation would be to try pluging into a diffrent wall outlet as well as something that is on a diffrent circut . It is a known problem that the pins inside that make the connection could be worn out . There are several pins from the one on the hose to the handle ect , check all componants to see that where the connection is lost you will find that you will need to replace that componant
Sep 17, 2008 | Kenmore 21513 Vacuum
Kenmore 23612 Progressive PowerMate Bagged Canister Vacuum Logo
51 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
