Question about Liebherr C1650 Stainless Steel Bottom Freezer Refrigerator
Liebherr replace freezer sensor - Liebherr C1650 Stainless Steel Bottom Freezer Refrigerator
  • Andrew Apr 19, 2013
    Greetings. I need to replace the freezer sensor due to the annoying F4 error. Does anyone have detailed instructions on how to replace the sensor?
Why is F4 showing for freezer temperature on my KIKNV 3056 fridge freezer?
F4 means that the freezer has an evaporator sensor fault.
You can get a replacement here:
https://shop.ukwhitegoods.co.uk/9590142-liebherr-fridge-freezer-sensor
You may want to have a repair man replace it. I don't have any instructions on how to do the replacement.
Mar 23, 2018 | Refrigerators
How do i reset my Liebherr Premium Freezer, the freezer is not cooling and making ice
It needs professional service. If it is out of warranty, you'll need to call a service tech for a visit.
Nov 26, 2014 | Liebherr SBSes 74S2 Premium NoFrost
The top part of the freezer compartment is warming up and setting off the alarm. Liebherr 7080 207-01 model
I also had defrost problem with Liebherr 7080 207-01. I removed freezer back panel, I defrosted all ice with hair dryer, but the freezer is not done for manually defrosting!!! You may have problems removing the back panel (I was not able to remove it with a screwdriver and i decided to pull it beaking the plastics supports and thean I put it back. It is a shame !!! Now it is working much better. I think this will be my last Liebherr freezer!
Oct 18, 2012 | Liebherr Refrigerators
I own a liebherr GNP2076 frost free upright frrezer
freezers do not normally go wrong too often so your going south is unusual.liebherr have given you a very good responce that some makers would not even dream of,i would recomend that you take up their offer as the chances of another problem are slim to zero...(in european law, it is you that has to prove that an appliance has a "inbuilt fault"to get anywhere.)
Apr 06, 2010 | Freezers
Liebherr Fridge Freezer fading door seal...
Look on e bay or kijji and see is anyone has one for sale That you could swap the door over .
Apr 06, 2017 | Liebherr KSv 4260
Fan not working, temperature too cold
You may need a man. Mine was doing the same, The sensor repair kit costs £35 the labour £60, both plus vat, so that was £109.25 in 2009.
Repair men seem thin on the ground and therefore his traveling time may add up. I believe, repair men pay for a course, and then charge like a wounded bull as they are the only ones that can do anything necessary
Apr 22, 2009 | Liebherr K3660-20 Refrigerator
Liebherr C1650 Stainless Steel Bottom Freezer Refrigerator Logo
50 people viewed this question
Top Liebherr Refrigerators Experts
Charles T Nevin
Charles T Nevin
Shehu Pro
Shehu Pro
Are you a Liebherr Refrigerator Expert? Answer questions, earn points and help others
