Question about Honda 2003 Accord 3.0 EX
Turn signals blinking fast on my 2003 honda accord
I have replaced the bulbs with halogen bulbs and I replaced the flasher with a led compatiable flasher and they still blink fast
  • 341 Answers
SOURCE: fast blinking flasher
Check for a burnt out bulb somewhere.
Posted on Nov 30, 2008
  • 204 Answers
SOURCE: turn singal problems
if i remember right the flasher is located on the back side of the fuse panel
Posted on Apr 14, 2009
  • 1779 Answers
SOURCE: Both turn signals are not working, need to find where to install the flasher can
driver side, under dash, above fuse box mounted on kick panel
Posted on May 03, 2009
co7196
  • 3433 Answers
SOURCE: 2004 Accord, left turn signal out, no indicator on
No, no seperate system. Your problem is generally caused by a burned out bulb, bad ground at tail light. A bad flasher would affect both sides. Front and rear must be good. Ck flasher plug in. Good Luck
Posted on May 25, 2010
  • 10865 Answers
SOURCE: turn signals blink fast (lights still work)? what
Hello. This happens when one of the bulbs is starting to go bad. pull all of the turn signal bulbs and look carefully at each one. you will find one with the filaments crossed. Replace that one. J.
Posted on Jun 15, 2010
My turnsignals dont work on my 1987 honda accord flashers do work
flashers and turn signals have separate flasher and separate fuse.
Mar 14, 2016 | Honda Cars & Trucks
I have changed my flasher bulbs with LED Bulbs, I now have rapid turh signals. 2013 Honda CRV EXL
I have seen this so many times. If you change the bulbs for LED lamps then you need to change the flasher unit. This is because the LED lamps draw less current then ordinary bulbs.
Apr 28, 2015 | Honda Cars & Trucks
2003 Honda Accord. Both turn signals on passenger side do not work. Both bulbs appear to be okay. Interior blinking arrow on dash board does not light up at all.
If the drivers side directional is working you probably have a burnt flasher unit located in the drivers side interior fuse box.
Mar 03, 2013 | 2003 Honda Accord
I have a 2006 honda accord, and the left blinker blink fast, i check all bulbs,
SYLVANIA 9006 Silverstar high performance Halogen headlight bulbs will fit your Honda.---------------------------------------------------------------------------------------
Digiprog 3
Dec 10, 2012 | 2004 Honda Accord
Fast blinking turn signal ford explorer 2003
could be a bad flasher do you have multiple bulbs for your turnsignals in the front make sure everything that needs to pulse is working
Sep 18, 2012 | 2003 Ford Explorer
When failed trun signal bulb, Jeep turning signal is fastly blinking. I changed rear turn signal bulb with LED bulb, but turn signal blinking speed doesn't go to normal, At first couple of seconds it is...
Try replacing with the same bulb type as was failed. Flasher unit isusually reliant on resistence from the bulbs to what speed that side will flash at when powered.Some of these led type have less resistence and that equates to a faster flash speed.That is why when one bulb blows that side will flash faster or may even stay on without flashing.You could even swap the led to the other side( to confirm.Check with the bulb retailer to whether they have those bulbs with a higher rated resistence in led.If this vehicle has leds as standard,you may need to get the correct type from dealer. Hope this helps or get back with findings if it still has fault after replacing bulb.
Mar 29, 2011 | 2009 Jeep Patriot
I HAVE A 1997 HONDA SHADOW 600 FRONT BLINKERS WORK FINE RIGHT REAR WORKS FINE BUT LEFT REAR WILL NOT BLINK LEFT FRONT DOSE BUT FAST I CHANGED BULB IN LEFT REAR DID NOT HELP IS IT A BAD FLASHER
If you have changed the blinkers over to LED lights , you need to put diodes on the wires to stop the fast flash. Honda turn signals Have to grounded to the green ground wires in the harness. You can not ground them to the frame or other wires or the flasher system will not work correctly. Double check that all the wires are connected to the harness correctly (They are color coded). Blue with white band is the same as blue with white stripe. Orange with white band is the same as orange with white stripe. If you have crossed the wires on the front turn signals you may be powering the rear turnsignal with the running light. The running light is the dimmer half of the bulb. The turn signal/flashing light is the brighter side of the bulb. Inspect your wiring carefully.
Mar 18, 2011 | 2004 Honda VT 600 CD Shadow
Turn signals blink fast (lights still work)? what
Jun 15, 2010 | 1998 Honda Accord
Open Questions:
Honda 2003 Accord 3.0 EX Logo
97 people viewed this question
Top Honda Heating & Cooling Experts
bigdawg7299
Thomas Perkins
Thomas Perkins
ray gallant
Are you a Honda Heating and Cooling Expert? Answer questions, earn points and help others
