Siemens xlp 1400 drum wont turn when switched on but can turn on by hand ok and belt is fine
Siemens xlp1400 fills with water ok but then the drum wont turn and wont spin but turns ok by hand and belt is ok
SOURCE: Siemens XLP 1400 stops with F12
The manual says that it means there's water in the base pan because the apliance is leaking and you should callCustomer Service.
I cleaned the filter and then put the machine onto its Empty cycle. After that it worked.
Posted on Jan 23, 2009
landsend
  • 1066 Answers
SOURCE: maytag coin-op top load wont spin, motor runs, belt burns.
it not a belt, there is a $20 plastic and rubber coupling between the motor and the transmission that has broken.  It needs replacing.
Posted on Mar 11, 2009
  • 21 Answers
SOURCE: My XLP 1400 siemens beeper has gone quiet all of a sudden?
Have you tryed unpluging for 10 seconds and plug back in. Sometimes this works. Let me know.
Posted on Apr 06, 2009
  • 4 Answers
SOURCE: fills, and drains but will not aggitate or spin,
Try replacing the motor start capacitor.
Posted on Jan 25, 2011
  • 9 Answers
SOURCE: Bosch classixx 1400 express wont spin or rinse.
why life so unfair ?
Posted on Jan 27, 2011
Motor is running but won't agitate and belt is on ? I can hear the motor humming and it will fill up but it wont agitate.
Check drum turning by hand ok not sticky sounds like could be motor if it hums and no turn..
Oct 18, 2014 | Hotpoint Washing Machines
Siemens xlm 1400 will not rinse clothes, it makes noise but the drum will not rotate eventhough it will turn by hand.
your motors drive brushes need replaced
so look to use the model number in EBAY
http://www.ebay.co.uk/sch/i.html?_from=R40&_trksid=p2050601.m570.l1313.TR0.TRC0.H0.Xxlm+1400+brushes.TRS0&_nkw=xlm+1400+brushes&_sacat=0
i used the search string
'xlm 1400 brushes'
and they are quite easy to replace..
it may do a whole wash cycle and count down etc just wont spin or move the drum with heavy water laden clothes
goes eeeeeeeheheeheh but no drum rotate
so
you can drain the machine only
lay the machine down with the soap drawer away from the ground
then it wont leak
two screws and one power clip removes the brushes
from the main motor {the one with the belt that drives the drum}
their are two brushes one each side
so 4 screws
and replace both ..
so...
good times
let us know the size of the brushes left
they should be like new 2.5" - 3" long
if they are less then 1.5" replace them
this is the issue
the main advice is not to use it just now
till you check the motor brushes
as this type of fault can further damage the motor
so .. dont use it till you check / replace the brushes as the intermittent contacting will damage the motors stator {the bit the brushes make contact with}
Aug 19, 2014 | Siemens Washing Machines
My washing machine drum wont turn. The washing machine fills with water then just sits with water in it. It will drain but wont spin It worked fine yesterday, but today nothing. When I turn the drum by...
hello. if it don't turn then it could be the brushes on the motor also check the interlock on the door. any spin problems could be the module control board get back to me if you still have problems
regards
shaun
Jan 03, 2011 | Hotpoint WMA13 Front Load Washer
Apr 06, 2009 | Siemens Washing Machines
Oct 19, 2008 | Siemens WXLP1460 Front Load
F12 Error
what is F12 error code on a siemans wxlp1400 and how do i cure the fault, cheers
Dec 29, 2007 | Siemens WXLP1460 Front Load
Washing Machines Logo
50 people viewed this question
Top Washing Machines Experts
