SOURCE: Need diagram for this carburetor #632508 or 632508
below is a copy of the only diagram I could find for you. hope it helps! thanks.
SOURCE: Engine part for Tecumseh 6hp 195cc
The float and pin can be bought as a repair kit., and replaced.
SOURCE: have a tecumseh ohh50 4 cycler engine on a garden
Check for condensation in the tank. Fill with FRESH gas, then if no luck, proceed ...
Main jet partially blocked. Undo bowl nut. Some models have the jet in the side of the nut - check and clean. If not, the jet is in the emusion tube of the carb - accessible throught the bowl nut orifice. Clean out & test.
SOURCE: ifound a Tecumseh Yard Machine Front Tine Tiller.
It sounds as if you still have Carburetor problems.
Use
a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to
clean the small portals in carb. These portals can become blocked.
(If there is a small screen in the Carb., this can get blocked too.
Make sure that it is clean as well.)
Reassemble and start. (If there is a small screen in the Carb., this can get blocked too. Make sure that it is clean as well.)
If the carb. parts are more than 4 years
old, you may have to replace them.
If you need further assistance
on:
1. Fuel line replacement or
2. Carburetor kit replacement
Just
let me know.
Jim
