Question about Craftsman Blower Attachment
I have a saers craftman 200 blower, installed a new sparkplug. only to have it still not to start.
  • 169 Answers
Bad fuel is prob your culprit, drain tank and carb and add fresh 89 octane gas oil mix, check for broken fuel lines and clogged inlet screen inside the carburetor. hope this helps
Posted on Nov 21, 2009
Drive belt for a craftman snow blower and auger belt
www.sears.com/parts or www.mowparts.com
Jan 13, 2014 | Garden
Craftman 6.75 turbo walk behind mower with tecumseh engine wont run fuel on sparkplug
It runs on a prime so that eliminates an ignition problem and indicates a fuel problem. You are on the right track, you just missed something in the carb. Remove the carb and clean it again. Be sure all passages are clear. you mmentioned that you replaced the inlet needle- what about the seat? They come as a set and should be replaced together. Be sure you clean the passages in the fixed jet also.
Take your time, clean the carb thouroughly and your problem should be solved.
Nov 21, 2012 | Garden
I have a craftman 6.0 21inch rear drive lawnmower it made a pop sound a will not start it has gas oil new sparkplug
Most of the time when a engine pops, or back fires, your valves are usually out of adjustment.
Jun 18, 2011 | Garden
I've put a new sparkplug and new filter -but the blower won't start . Doesn't even feel like it wants to start
Put a spoon full of gasoline straight down the plug hole. Reinstall the plug, if it starts then you obviously have a fuel problem. You may need a new kit installed in the carburetor. Easy fix.
Nov 17, 2010 | Craftsman 4 Cycle Blower/Vac
I have a craftman leaf blower model#368794963 hand held 25cc it was running fine but now it wont start
hello
if you have spark remove the sparkplug and priming the engine(put some gas in sparkplug hole into the cilinder).Pull the rope for starting engine as many times as you need until the engine starts but without any choke and the switch on the on position.Please let me know what is going on.
regards savumihai71
Nov 04, 2009 | Craftsman Garden
What is the oil mixture for a Craftmans Leaf Blower? Is the mixture the same for all Craftmans two cycle engines?
If you have the model number of the leaf blower then you can go to www.managemyhome.com and download the owners manual for free. Once you have that information then you can look it up.
Oct 27, 2009 | Craftsman Garden
Crafsman gas blower: fuel lines to primer bulb had to be reconnected; now blower won't fire at all. Replaced plug and made sure it sparked; still nothing when I try to start.
Hi
Priming the engine(put some gas in the sparkplug hole ,after you have checked the sparkplug,the colour of the spark has to be violet).Start the engine.If it starts there is a carburation problem,change the fuel lines to primer bulb.
wish you good luck savumihai71
Dec 04, 2008 | Craftsman 4 Cycle Blower/Vac
I have a craftman yard vac with a tecmseh 4.5. She has failed to
Hi gr2954;
Lots of the starting problems with 2 cycle engines (weed eaters, blowers, chain saws, etc) are caused by leaving them stored for long periods of time with the oil/gas mixture left in them. what happens is that a residue forms on parts in the carb.
Try the following: empty the fresh gas out of the blower. add a gas stabilizer to the existing gas you plan to put in the blower. You can get this stabilizer at any auto parts store. While you are there get a can of spray start fluid. Put the fresh, modified gas in the blower. Take the spark out and spray some starter fluid in the plug hole.Replace the spark plug and try to start the engine.It will probably take a few cycles of doing this to get the blower to stay running.
when you put the blower up for a long period, empty the remaining gas out then start the engine and run it till it stops. this gets the remaining gas out of the carb.
Nov 30, 2008 | Garden
Craftsman Blower Attachment Logo
236 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
