Question about JumpKing Enclosure Combo Trampoline Pole Cap
I need pole caps for an Asda 10ft jumpking trampolie
The caps are the one's where the top of the enclosure rim fit's in the middle
  • Robert Shaw Apr 21, 2013
    The top of the enclosure fits into the middle of the pole caps not around
Radiator cap
The parts of the cap that are supposed to turn together have come loose. The bottom part is riding freely under the rim of the radiator fitting. You need to remove the whole thing and replace it, obviously. Some suggestions for removal include pushing down from the top of the cap HARD while you turn it counterclockwise. Gently bending up one edge of the top of the cap with a pair of plyers to see if you can see the locking pins under the outer edge of the radiator fitting and then prying one of them up...
Jan 15, 2013 | 2007 Peugeot 207 CC
How tall should the pole be in tetherball?
If you are going to make a tetherball pole you should make it at least 10ft tall (roughly 3meters) from the ground.
Jan 13, 2013 | Sport & Outdoor - Others
I need pitching instructions for a Great Outdoors Apollo 4 man tent
Take out all poles and stakes and tend and seperate.. First lay tent on ground and streatch out where you wish to pitch the tent. Then take stakes and place them in the four corners of tent through the loops so ththat when you hammer in the stakes the tent is nice and stretched out tightly. There should be two more loops on each side int the middle. When the tent is secure to the ground, take the poles that should have been put together and feed them through the hoops of the tent on the sides and top. Leave the top center parts of poles apart until you have poles through rest of loops and attatch them at the top of tent. front, back and center usually work pretty good for order. Doint middle last because it is the highest point. Hope not too confuseing. I camped a month every year for many years. You never forget.
Dec 23, 2012 | Sport & Outdoor - Others
Purpose of the pole switch
The right hand drive have the bumper poles in front of the left hand head light. when the switch is pressed to the on position, the pole extends like an antenna and it has a green light on top of it. It helps to light up the area so you wont hit the curb and scrape the rims." __________________
Oct 08, 2012 | Toyota Cars & Trucks
Ive got a 10x10 lawn and party gazebo made by summer rite ... do you know where to get instructions ?
Okay, Here it goes.
First lay out all of the parts by number (little stickers on poles) or sizes if the stickers are gone.
_1430.jpgTake
Take the 1's and 2's and connect them together creating one big pole that will act as one of the roof peak structures. If you have lost your numbers, these two poles should be the two middle sized poles (4 of each).
Then connect each end of #1 to the center peak piece
Once all four combined poles (1 and 2) are attached to the center piece, add the pole brace pieces to each end of the bottom or #2 Piece.
Once this is done, combine two number 3's with one 4 (the 4 being in the middle of the two with both silver metal fasteners on the #3 poles facing outwards)
Then connect each end of the combined poles to the end piece.
Now lay out the final set of poles (# 5 and 6), but only connect the #5 pole to the end piece first, all around the gazebo.
Okay, now we want to start adding the actual canopy. Start by pulling the corners down at each pole joint then velcroing the tarp underneath in the middle of the 3-4-3 combined pole.
Now it is safe to connect the next set of poles (#6) to the leg poles (#5). Make sure the end with the 3 drilled holes are closest to the ground. On each end of the tarp legs there is a silver hook. Hook this into the 1st hole in the pole for support.
Connect the foot cap to the end of each pole and then connect the plastic o ring to the connector on the foot piece and readjust the silver hook as needed to either hole 2 or 3 (see photos).
Then the final parts are easy, secure any velcro straps to the legs, then use the stakes to stake down the whole thing and you may use the secure ropes as needed though I tend two just put two stakes in each foot piece at different angles.
Congratulations !!!!! Your Summer Rite Gazebo is ready for festivities. Hope this helps !!!
Sincerely Dustin R. Sponsler
May 30, 2011 | Camping, Backpacking & Hiking
Need instruction manual for the Ridgeway Moab Model 89034. 4 room tent
I borrowed one of these and got most of the job done. Here's what I ended up doing:
At a site with good drainage, a little uphill, stake down the floor of the tent
Longest two poles go through the twin sleeves in the center/top. They are color coded red and yellow
These two poles are anchored at the base by the center color coded ring_peg
The tube ends of the fiberglass poles. Fit over these pegs.
The slightly shprter fiberglass poles go trhough the two blue sleeves.
These poles get anchored on one end by a yellow ring peg and on the other by a red ring peg. They hold the vented windows up.
The arch shaped pole is threaded through a black sleeve atop the entrance to the. Tent.
The arch is anchored on either side by a red ring peg on one end and a yellow peg on the other.
Stake the lines from the screen windows outwards from the tent
Spread the tarp over the top and stake the corners to shelter the screened top from rain
Aug 23, 2010 | Sport & Outdoor - Others
Lost the instructions for circo monster play tent...need to set up for kids asap..
2 short poles A 2 longer poles B 1 medium pole C
Slide one assembled A pole through the pole sleeve at base fold and fasten the velcro tab over the end of the inserted pole repeat with other A pole on other side Slide one assebled B pole through the pole sleeve at rafter. (across the body) fold and fasten velcro tab repeat with other pole slide one assembled C pole through the pole sleeve at top (down the middle of the monster) Put plastic mold at the end of the inserted pole into the pole at front
Feb 19, 2010 | Toys
Where to purchase a bracket
Unfortunately there are two standards for the pole diameters. Some of the smaller poles have caps to accomodate the larger brackets. First thing is to measure what you have for poles and the two sizes of mounting holes. Many of the mounting bosses are standard and available online here is an example:
http://www.amazon.com/Speaker-Cabinet-Metal-Stand-Mounts/dp/B0035AJTL8
Sep 19, 2009 | Mackie SWA1501 Subwoofer
Need to know breaker and wire size to run from panel
Compressor 12/3 with 20 amp dual pole breaker. 220 VAC
Freezer 12/3 with 20 amp single pole breaker 120 VAC
May 24, 2009 | Nor-Lake Freezer Walk In Freezer 6ft x...
1987 GMC Jimmy Distributor cap and Rotor replacement
A diagram may not be needed as its a reasonably easy fix to do on your own.the distributor ca p will only fit on properly one way because at the base of the cap locaters can only fit the distributor if they line up.When doing the spark plug leads do them one at a time and if nessecary write or mark leads as 1,2 etc .The rotor can only fit on one way but put a mark on the distributor to show where the rotor was pointing when you took it off and if it still points there when the new one is fitted.When changing distributor cap and leads they have to go to the correct place.Pays to mark the outside of distributor cap where the locating bits are On the new and old one.Fit the new cap and rotor then take a spark plug lead and fit to new cap 1 at a time.You can tell by lining up the marks on the outside of the distributor cap when you hold them one on top of the other.Good luck
Oct 20, 2008 | 1987 GMC Jimmy
JumpKing Enclosure Combo Trampoline Pole Cap Logo
79 people viewed this question
Top JumpKing Sport & Outdoor - Others Experts
Are you a JumpKing Sport and Outdoor - Other Expert? Answer questions, earn points and help others
