Question about Epson Stylus Photo R220 InkJet Printer
Stylus photo r220 not picking up 4by 6 inch photo paper
Hi gentlemann i have here a stylus photo r220 printer it picks up letter paper and a4 ok only 4 by 6 inch paper is not being transported by this printer please help. I even select this papertype in page setup. but no result still i keep getting paperjam.
Thanks in advance for your help and cooperation .
  • 514 Answers
Move the paper sideways (end on as apposed to flat) or select portrait printing instead of standard. good luck!
Posted on Apr 11, 2009
Printer not picking up paper
The rubber wheels that fetch up paper can be cleaned with alcohol or benzin or even be rubbed with sand paper. Gently.
Check that the sensor for paper is working. If not it will say "Out of Paper"
Mar 05, 2010 | Epson Stylus Photo R220 InkJet Printer
Printer won't print with Hahnemuhle 300gsm papers.
Brand new printer feed up to 350 gsm paper. Rubber paper paper pick up deterioration. Replace paper feeder. Or find similar solution (repairing paper feeder) on aicaxz's for resolving this.
Feb 02, 2010 | Epson Stylus Photo R220 InkJet Printer
Two red lights are blinking simultaneously...I check if there is any paper jam but i don't see anything. anyone can help me would be much appreciated.
first have you checked any clogged papers? have you checked ink cartridges if yes continue doing the following
Before run adjustment program or software resetter Epson Stylus Photo R220 and R230, set date setting in your computer to 12 January 2006. Appearance of adjustment program Epson stylus photo R220 and R230 like adjustment program for Epson C45. Your Epson Stylus Photo R220 and R230 must be installed correctly in your computer before using the software otherwise so this software resetter will not be used.
Here how to use the software
  • Download and extract downloaded software and run it.
  • Click accept button.
  • Set model name, port selection and destination setting and equal to your printer.
  • Click Maintenance Tab.
  • Check mark waste ink pad counter.
  • And the clear the protection counter (reset counter to zero)
  • Then click Ok, Ok
  • done
download link:
http://www.mediafire.com/?9njmgwlxqgj
Nov 10, 2009 | Epson STYLUS R230 InkJet Photo Printer
Glossy A4 paper will not feed. Is it too heavy?
Actually, if printer is new, printer can feed up to 350 grm. But if pick up rubber at paper feeder mechanics had distort/loose thickness, it can't. Try to use 210 gsm glossy paper. Or, if you wish to use 280 gsm, pull down paper while printer grab paper.
Aug 20, 2009 | Epson Stylus Photo 2100 InkJet Printer
Printer will not pull envelope into print area - worked fine in the past and still no problem with 8½ X 11 paper.
Problem feeding thick paper. Replace paper feeder. Or, add double tape bellow pick up rubbers at paper feeder. Check lubrication too.
Jun 21, 2009 | Epson Stylus Photo R220 InkJet Printer
How can i copy a legal size document on the Epson Stylus CX9400?
Take a photo with digital camera. I am doing this on newspaper articles from books at local Historical Society then cropping and other editing in my Serif Photo Plus 11 program.
good luck,
LindaC in OK
Jan 28, 2009 | Epson Stylus CX9400 Photo Printer
I need the software & drivers please 4 epson styuls photo R220 some one send it to wickedwelchtattoos@att.net thank you.
Sep 22, 2008 | Epson Stylus Photo R220 InkJet Printer
Card making
This machine will only print certain sizes as borderless. A5 is not one of them. You can use the following media with this feature: Matte Paper - Heavyweight: A4, Letter Premium Glossy Photo Paper:A4, Letter, 5 x 7", 10 x 15 cm/4 x 6", 8 x 10" Photo Paper:A4 Premium Semigloss Photo Paper:A4, Letter, 10 x 15 cm/4 x 6" Glossy Photo Paper:Letter, 10 x 15 cm/4 x 6" As you can see A5 is not in the list, therefor you will not be able to print A5 borderless via the normal means.
Aug 21, 2007 | Epson RX620 All-In-One InkJet Photo...
Paper Jam with no Jam
You may have overloaded your paper feeder with heavy card stock and caused a very tiny jam that you have not found yet so that it will act oddly as it is. Look right up inside unit with a torch and down back where the paper goes in.Try printing on plain a4 agian, place a small stack in feeder, reset paper guides too. Also could be your paper sensor, fixable under warranty.
Aug 12, 2007 | Epson Stylus Photo R220 InkJet Printer
Epson Stylus Photo R220 InkJet Printer Logo
118 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
