Question about Gestetner DSc224 Copier
Black streaks on copies. Gestetner 1302 How do I get rid of them
How do I get rid of black streaks on copies?
Do the streaks appear when you use the contact glass or just when you use the Automatic feeder?
If both, then you need to replace either the (drum unit) or the fuser roller(s).
If it just happens through the auto feeder, then lift up the "feed-in section" (left side) and clean the narrow scanner glass.
Posted on Mar 11, 2009
How do i get rid of streaks on copy. There are 3 black streaks on each copy. I have a xerox 420dc
Print heads need deep cleaning. If not ink jet, then the drum is damaged (scratched) and needs to be replaced to eliminate the bogus lines.
Jan 17, 2017 | Xerox Document Centre 420 DC Laser Printer
Very light printing
is there away to adjust the arm in it ?
Sep 11, 2012 | Gestetner 89868 Br 1302 - 1-sd Yld Black...
I get streaks across colour copies and prints on my gestetner dsc460. How to clean heads or fix problem
replace clening drum plad
clen the drum unit
may be their is a duste on the meirror if is proplem hapend when you useing copy
Jan 31, 2011 | Gestetner DSc460 Copier
How do I get rid of blurry streaks down center of copy? The glass is clean.
Check the drum unit, if the drum is covered with streaks replace the crg.
Check the fixing unit.
Jun 03, 2010 | Canon PC-940 Black and White Copier
Sounds like the drum unit has some scarring on the surface and it is causing toner to be picked up in the grooves and placed on to every single page that is printed on the printer.
Pull the drum unit out of the copier and inspect the surface, being careful not to touch it as the oils of your skin will damage the drum surface. If you have scarring around the green/blue/black drum surface then you need to prder a new drum unit.
Hope this helps,
Cheers,
Keith
Jan 13, 2010 | Office Equipment & Supplies
My color copies have a black streak on the front and back of each copy. What can I do.
i have an lexmark 6500 all in one copier. If I print from the computer the copies are o.k., however, if I print a copy from the copier the copies have a black streak on them. How do I get rid of the streak on my copies
Nov 11, 2009 | Epson Aculaser C1100 Printer
Faxing and or copying a black streak developes, answer??
Open up the document feeder by pulling up and clean the scanner glass
Jan 11, 2009 | Brother MFC-5840CN All-In-One InkJet...
Gestetner DSc332 streaks and smears when printing in color
Check to see if you have a paper jammed near the drum near the color ink cartridge interface.
Nov 28, 2007 | Gestetner DSc332 Copier
346 people viewed this question
Top Gestetner Office Equipment & Supplies Experts
Adorjani Laszlo
ap-it
ap-it
jmartin50
Level 1 Expert
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
