Question about EliteGroup P4S5A/DX Motherboard
Switch Wiring for P4S5A/DX+
Need to know wiring from power switch,LED's to pins on MOBO.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • EliteGroup Master
  • 2,226 Answers
Go here download manual http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=39&MenuID=24&LanID=0
Posted on May 26, 2014
  • 2427 Answers
SOURCE: power LED on but no boot up
it could be your power switch, veriy that it isnt the power supply by
1.) un-plug it from the main board
2.) look at the main board connector(one coming of the power supply)
3.) you should see green wire and next to it a black one
4.) using a paper clip bridge the too wires
5.) if it works proceed to net step if not get a new power supply
to check case switch and board switch
1.) plug in power supply to main board
2.) look at the pins where the power button connects to
3.) using a metal object (blade screw driver) bridge the pins
if the board should start up>
then its your power button on the case that is bad, you can try to repair it, chage it or buy a new case,
if it doesnt work.
1.) ensure that jcms(jumper to flash the bios) is set correctly
2.) unjack each drive one at a time to see if any is causing stalling
3.) get a new main board
Posted on Jan 02, 2008
rhoncruz
  • 134 Answers
SOURCE: trouble locating panel1 wiring for EliteGroup 945G-M3 MOBO
I hope it helps!!!
Posted on Nov 30, 2008
  • 987 Answers
SOURCE: can any give me a manual of this mobo ecs 945gct-m2 i dont know
http://eudownload.ecs.com.tw/dlfileecs/manual/mb/eng/p4/24_945GCT-M2_1333%20(1.0A)_low.pdf
HERE U CAN DOWNLOAD THE MANUAL...
Posted on Mar 10, 2009
rockitman187
  • 2559 Answers
SOURCE: case front panel to motherboard wiring
Here is a link to the motherboard manual
And here is the hook up
Posted on Jun 03, 2009
  • 11 Answers
SOURCE: need the jumper numbers
Motherboard model please
Posted on Sep 13, 2009
ED if a purchesed MOBO it should be writen down in the documentation.
Apr 19, 2013 | EliteGroup P4S5A/DX Motherboard
Need the wiring diagram for the FP1 Header on LGA775 672M01-1.1-8EKSH DDR2 SATA Motherboard
http://www.ascendtech.us/foxconn-lga775-672m01-1-1-8eksh-ddr2_i_mb4672m0118eksh.aspx
Better photos,
http://www.ebay.com/itm/FOXCONN-LGA775-672M01-8EKSH-DDR2-SATA-PCIE-MOTHERBOARD-/250896116650
Go to the photo under the Specifications. Shows a Top view, and the Front Panel header. (FP1)
Note the colored areas on FP1 for the different contact pins.
The pins in the Red area should be for the Power On switch.
Suggest take an LED with two wires, and Briefly touch those two pins.
Power supply comes on touch the pins in the other colored areas.
1) LED light stays on? That's the two pins for the Power On LED.
2) LED light blinks? That's the two pins for the HarDDrive activity LED light.
3) Computer restarts? That's the two pins for the Restart switch.
(IF a Restart switch is used)
Regards,
joecoolvette
(Voltage used? 5 Volts DC
In comparison two D cell flashlight batteries store 3 Volts DC )
Oct 15, 2012 | Computers & Internet
FX58M powerSW
thank to answer.
@Jorico no threr is nothing wrote on the mobo (expt fp1)
Aug 19, 2012 | Computers & Internet
Need IBM motherboard 29R8260 front panel controls
John,
The front of your computer is the Front Panel.
The area of contact pins on the motherboard, that the main wires from the Front panel go to, is the Front Panel header.
What you need is a Front panel header pinout.
This I do not have. What I do have, is a simplistic method that may allow you to find out, what the pinout is.
http://www.ebay.com/itm/IBM-ThinkCentre-M51-29R8260-Socket-775-Motherboard-w-P4-3GHz-SL7PU-/390456414497?_trksid=p4340.m263&_trkparms=algo%3DSIC%26its%3DI%252BC%26itu%3DUCI%252BIA%252BUA%252BFICS%252BUFI%26otn%3D15%26pmod%3D260995444535%26ps%3D63%26clkid%3D1437936870868306373&_qi=RTM1062688
Looking at the Hardware Maintenance Manual for the ThinkCentre M51, (It also uses this mobo), the Front Panel header is to the right of the Ram Memory slots. (Processor to the left, Ram Memory slots at the Top)
Looking at the Ebay link, there are three views available. Click on the middle view. In the view photo the Front Panel header is the black rectangle below the Yellow ram memory slots.
Two rows of pins.
Power Supply plugged into power, use an LED light with two wires.
Go across the top row, and touch the first set of two pins next to each other.
No? Go on. Touch the next set of two pins. I'm willing to bet the third set of two pins is the Power On switch pins.
(Could be mistaken, however)
The contact made should be brief. The Power On switch is a Momentary Contact Switch.
Once the Power Supply comes on, wait a minute, then start testing the other pins.
LED light blinks? You have the HarDDrive activity LED pins.
LED light stays steady? You have the Power On LED pins.
Be aware however, that there may be 3 pins for the Power On LED.
Two Positive ( + ) pins, and one Negative ( - ) pin. This is for a dual color Power On LED. (Turbo mode/ Regular mode)
This would mean touching the first pin, or second pin, in the set of 3 pins, and the last pin in the set.
Computer restarts? You have the 2 pins for a Reset Switch.
(Do NOT touch the Power On switch pins again, or the computer may restart)
Not what I would like to state. Would like to state the exact pinout.
Perhaps if you get this figured out, you might take the time to post the pinout. Crude is fine, I can 'clean it up'. This way 100's to 1000's of people may be able to use your findings. Think how many people you would help.
Regards,
joecoolvette
Front panel wiring diagram ie power switch reset switch etc
HP Support > Compaq Presario SR5501F > Motherboard Specifications,
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01237538&tmp_task=prodinfoCategory&lc=en&dlc=en&cc=us&lang=en&product=3740354
The motherboard is made by ECS for HP/Compaq
ECS model number is MCP61PM-HM
HP/Compaq's name is Iris 8.
There is no wiring diagram per se to give you.
I'll have to detail the wiring connections step by step for you.
This may be a little lengthy.
On the link above you are looking at a photo of your motherboard.
There is also an illustration available.
I would like you to copy, and save them both.
Using this method you will be able to enlarge them for further clarity, of the connections to the motherboard.
Right-click on the motherboard photo. Left-click on Save Image As, in the list.
In the Save Image window that comes up, you will see the heading File name:
To the right of File name: will be c01237541.
Unless you want to search for c01237541 you may wish to do this:
Put your mouse cursor after the 1 in c01237541.
Left-click twice.
Make one space with your spacebar.
Type Compaq Presario SR5501F Mobo photo.
(Mobo stands for MOtherBOard)
You want this photo to go to your My Pictures folder.
(Windows XP. Different for Vista)
At the top of the Save Image window is the heading - Save in:
In the box to the right you should see - My Pictures
If you do Not you will have to change the destination.
Left-click on the blue down arrow to the right of the box.
In the list, left-click on - My Documents, then left-click on - My Pictures.
Now go to the bottom right of the Save Image window, and left-click on Save.
In the link, scrolling down you will see the heading - Motherboard layout
Left-click on the + sign next to Motherboard layout.
Copy and save it as you did for the motherboard photo.
In the File name: box type - Compaq Presario SR5501F Mobo Illustration.
Now all you have to do is go to your My Pictures folder (Start>My Pictures), and double-click on the photo, or illustration.
Left-click on the Zoom In icon at the bottom of the window to enlarge.
(+ sign in a magnifying glass icon)
Wiring Connections to the Motherboard:
A) Front Panel header: (Panel 1)
The Front Panel, is the plastic front of your computer where the Power On button, HarDDrive LED light, and Power On LED light is located.
The Front Panel header is the connections, or pins, on the motherboard, where the cables (Wires) go to from the Front Panel.
On the motherboard illustration it is marked as Panel 1.
(Down in the bottom right corner)
On your motherboard, Panel 1 (Front Panel header) is Black in color.
As you can see it is a rectangular block, and is placed vertically.
Has 2 columns of pins.
5 in the left column, 4 in the right column.
The Left column is numbered Odd.
Starting at the Top going down, Pins 1, 3, 5, 7, and 9
The Right column is numbered Evenly.
Starting at the top going down, Pins 2, 4, 6, and 8.
Pins 1 and 3 are for the HarDDrive LED light.
(HDD activity LED)
Pin 1 is for the Positive connection ( + )
Pins 5 and 7 are for the Reset switch.
Pin 7 is for the Positive connection. ( + )
Pin 9 is reserved, and may not be used.
Pins 2 and 4 are for the Message LED light. (LED = Light Emitting Diode)
Power On LED light.
Pins 6 and 8 are for the Power On switch.
There is No Pin 10.
If the cables (Wires) are not marked coming from the Front Panel, you will have to remove the Front Panel, and trace where they go.
You will be able to physically see where wires go to the Power On switch, Power On LED light, HarDDrive activity LED
Sep 21, 2011 | HP Compaq d530 SFF PC Desktop
How to connect power switch on msi ms6787
At the bottom right hand corner of the mobo you'll find there is a set of pins marked JFP 1 and the power switch pins are marked clearly so are the HDD Led, reset, Power Led etc. Plug in your wires which are also marked, corresponding to the marked pins.
Sep 23, 2009 | MSI P4MAM-V SND/LAN/VIDEO (6787060)...
Need power-switch pin-out for Sony VAIO PCV-RX470DS
The connector pinout is found on page 54 of the System Reference Manual, which is available in PDF from the Sony Support site at this link:)
javascript:moreinfowindow('http://www.docs.sony.com/reflib/docget.asp?manualid=3124&template_id=1&region_id=1&DL=',600,560,10,10,'Manuals')
Dec 30, 2008 | Sony VAIO PCV-RX470DS PC Desktop
No power supply activity
check all wiring connections going to the board, also check that the bios jumper is not set to clear bios.
Jan 14, 2008 | EliteGroup P4S5A/DX Motherboard
Problem with my mobo
are you sure the wires are on the right pins.
No it wont hurt the bios, but power may of fried something,
But thats rare.
here is the pins. #1 is lower left.
1 HD_LED_P
2 FP PWR/SLP *MSG LED(+)
3 HD_LED_N Hard disk LED(-)
4 FP PWR/SLP *MSG LED(-)
5 RST_SW_N Reset Switch(-)
6 PWR_SW_P Power Switch(+)
7 RST_SW_P Reset Switch(+)
8 PWR_SW_N Power Switch(-)
9 RSVD Reserved
10 Key No pin
Here is the manual
Nov 07, 2007 | EliteGroup P4M800-M7 Motherboard
EliteGroup P4S5A/DX Motherboard Logo
117 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
