Question about 1995-1997 Chevy 3500 Truck Ignition Starter Alarm Switch
Need the torque setting for wheel bearings on a 95 chevy c1500
Putting new brakes on truck - changing wheel bearings - can't find the spec
    Scholar:
  • 117 Answers
There should be very little to the front wheel brngs. Tighten them with a little torque, spin the wheel and tighten with a little tightness then back off until you have no play in the brngs.
Posted on Nov 02, 2013
What is the torque specs for a hub and bearing assembly on a 2001 four wheel drive chevy s10 blazer
Adjustment
The wheel bearings on these vehicles are not adjustable. If the bearings become loose or make noise, they must be replaced.
Removal & Installation
  1. Before servicing the vehicle, refer to the Precautions section.
  2. On 4WD vehicles, remove wheel center cap, if equipped, and the drive axle nut and washer
  3. Raise and support the vehicle.
  4. Remove or disconnect the following:
    NOTE Lay the hub and bearing on the wheel studs on the outboard side. This will avoid damaging the bearing seal.
    Tire and wheel Caliper, leaving the fluid lines connected Brake rotor Halfshaft from the hub and bearing on 4WD vehicles. Place a brass drift against the outer edge of the halfshaft to protect the shaft threads. Use a hammer to sharply strike the brass drift, but to do not remove the halfshaft at this time. Wheel speed sensor Wheel hub and bearing-to-steering knuckle bolts and hub and bearing
    Splash shield from the steering knuckle Seal from the hub and bearing
To install:
  1. Install or connect the following:
    Wheel hub and bearing seal Splash shield to the steering knuckle, making sure it-s properly aligned Hub and bearing to the steering knuckle, aligning the threaded holes Hub and bearing bolts and tighten to 77 ft. lbs. (105 Nm) Wheel speed sensor. Tighten the bolt to 13 ft. lbs. (18 Nm). Rotor and brake caliper Tire and wheel
    The Hub Bearing Torque - Front
    If Torque Specs are not in the box we recommend youtorque to this setting. Axle Nut: 103 Ft/Lbs.Flange Bolts: 77 Ft/Lbs. WARNING: Failure to observe the following warningscould create a risk of death or serious injury.Proper maintenance and handling practices arecritical.Always follow installation instructions and maintainproper lubrication.Every reasonable effort has been made to ensure theaccuracy of the information contained in thiswriting, but no liability is accepted for errors,omissions or for any other reason.This information is not intended to substitute forthe specific recommendations of your vehiclemanufacturer.Always use the recommended torque requirement unlessotherwise specified in the carton.Depending on the application, type of hub unitbearing and location, the installation process mayvary.Please review the vehicle manufacturer'srecommendation before removing or installingcomponents.
  2. Lower the vehicle
  3. On 4WD vehicles, install the drive axle nut and tighten to 103 ft. lbs. (140 Nm), then install the center cap.
Nov 10, 2012 | Cars & Trucks
Torque Spec
Front wheel bearing hub is 147 ft lbs. Axle nut is 170 ft lbs.
Oct 06, 2012 | 2006 Hyundai Accent
What are the torque specs for the Main Bearing Cap bolts on a 1990 CHEVROLET TRUCK C1500 5.7l 350
main caps 85 ftlbs (3divdedsetings30ftlbs all 50 ftlbs all ending at85ftlbs click, rocaps 45ftlbs, head bolts 85ftlbs workingfrom cdenter top ,center botom ,top center working clock wizeand out ,intake boltes45ftlbs again fromcenter working outleft side, right side,left, right 8 bolts one time only or u will distort gasket. oilpan from center alternate L side ,R side,clock wize25ftlbsclick recheck after breakin period valve covers 25ftlbs anrecheck flywheel 90ftlbs ,harmnic balancer bolt 75ftlbs, add oil!!!!run for 15 minutes drain oil &change filter run for 100miles for molly rings 10 mmiles for cast rings .let engine cool down retorque headbolts,replace valve covers .run it and get on it!!! good luck hve fun.
Aug 20, 2012 | 1990 Chevrolet C1500
I have a loud roaring coming from the front of my vehicle, it is a 2006 chevycobalt ls...i had a new axle put on yesterday, it is stil doing it..all my tires are brand new
Here's a video that will show you How To replace the front wheel bearing in our 2005-2010 Chevy Cobalt. Hope this helps you out.
1aauto.com
Jul 22, 2011 | 2006 Chevrolet Cobalt
How to change front hub assembly on 05 mustang
Remove tire/wheel. (5 nuts)
Seperate the brake pads just a little; pry apart with a screw driver. Easier to remove and replace later.
Remove caliper/brake assembly (2 bolts). Do NOT remove brake line.
Remove brake rotor (there may be a retainer clip or two that needs to be removed and discarded.
Remove black center cap (after reading warning on the cap).
Remove large spindle nut.
Slide bearing/hub assembly off the spindle. (If stuck, you may have to tap it with a hammer. It's a straight smooth shaft.
Reassemble in reverse order.
Tighten the nut to the correct torque spec. I don't know what it is, but it's pretty high... 200ft-lbs? The torque is important because it sets the preload on the bearing balls and races. Too low or torque will cause early bearing failure.
Bearing/hub looks like this:
Apr 09, 2011 | Ford Mustang Cars & Trucks
Exacly how to remove rear brake drums ? 2001 Ford Focus SE. I don't want to remove the hub & spindle. I simply want to replace the drums & Brake shoes.
The drum and hub are one assembly on that vehicle so you will need to remove the dust cap in the center of the drum and remove the large axle nut. The drum/hub/bearing assembly will then pull off of the spindle.
If you want to replace the drum you will either have to find one with a bearing already installed, Have your old bearing pressed out of the old drum and pressed into the new drum, or have new bearings pressed into the new drum.
When installing the new drum it is very important to tighten the axle nut to the proper spec. I can get that spec for you if you need it.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
Apr 06, 2011 | 2000 Ford Focus
I am installing a steering wheel on a 1991 chevy silverado pick up and I need the torque specs
mcdevito75 here, I really don"t know, even if there are manufacturers torque specs. I myself just make the nut very tight, remember the steering wheel goes onto the steering shaft which is tapered.
Jul 08, 2010 | 1991 Chevrolet C1500
Need torque specs 1988 Chevy silverado for main bearings and rod
Those values and most everything else you need for DIY work are contained in the Haynes manual for your vehicle. We have one with each of our vehicles and not only give you the info needed to do repairs yourself but also get an idea of how much work a specific repair should (or shouldn't) cost.
'88 Chevy pickup manual
You can also buy these from auto parts stores for a few dollars less and sometimes on eBay for even less.
Feb 20, 2010 | 1988 Chevrolet C1500
1995-1997 Chevy 3500 Truck Ignition Starter Alarm Switch Logo
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Mike
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
