Question about GE JKP27 Electric Double Oven
Replace oven control board for ge jkp27bw1bb
I foolishly removed defective oven control board prior to noting where wires would go on new board model wb27t10264
5 Suggested Answers
textonor
  • 130 Answers
SOURCE: Oven mystery....need the best GURU or Wiz....CHALLENGE! Please help!!!
Monogramman you have described where your issue is. When you dismount the front panel you are moving the wires. If I was looking at your unit and you told me that it worked with the panel removed, I would look at the wiring between the front panel and the relay board for a loose connection. You should be able to pull the connectors ( remember to shut off the power for safety) and put a flash light on the backside of the connector. Look thru the front an you should see very little light. If you see a lot of light there is your loose connection. Or if you are careful, you can wiggle the connectors until you get to one that is causing the clicking. Hope this helps. I doubt if it is the oven thermistor as the oven heats while the front panel is dropped down.
Posted on Jan 06, 2008
jandj_web
  • 3 Answers
SOURCE: Replacing ERC on GE oven
I ran into the same problem replacing my new part. The instructions indicated that the GROUND wasn't used. The Nuetral was located in near the same position. The L1B went to the little black box near the vacant L1B location on the board
Posted on Dec 01, 2009
SOURCE: How do I find the part number for replacing control board for GE?
WB27T10290
I would not be so sure about that the problem is in the control board. Check switches on the door lock assemblies first.
Posted on Jun 02, 2010
SOURCE: I need the squematic wiring GE 24" Built-In Gas Oven
I have the same problem -- did you ever get this question answered?
Posted on Jun 14, 2010
Hi,I've a problem with my GE. The clock show "F1" code sometines and it "bip", but the oven work. What can I do?Thanks
Check the wires going to the oven sensor. The temperature is controlled by 2 things--the sensor(looks like a thin metal pencil sticking out from the upper rear wall of the oven on either the left or right side) and the main board. There is a thin wire harness(2 wires) from the sensor to the main board. A big problem with ovens is the connector that joins the sensor pig tail to the harness from the board. It can become oxidized, heat damaged, etc. breaking the connection. The sensor should have about 1100 ohms of electrical resistance at room temperature +/- 10%. If the sensor and wires check good, then you have a defective main board and it will have to be replaced.
Aug 25, 2015 | GE Ovens
Tip
Replacing igniter
GE wall ovens have panels for regulator and ignitor wiring at the lower back of oven. remove all screws and plates to expose wiring. clip off defective igniter and use ceramic wire nuts to fasten new one. re-assemble.
I learned from local gas company that igniter is most frequent part to replace.
cost = $35
GE technical support = non-existent.
power of the internet - priceless!
on Jun 18, 2008 | GE JGRS14 Gas Single Oven
How do I replace the temperature controller in GE model P7 oven?
should be easy make sure u unplug from wall then in the back panel u can unplug after making sure to note where wire plugs are connected and ifinite switch can usually be removed by removing the screws holding it. remember to remove the knob from other side
Mar 08, 2015 | GE Ovens
F3 f4 f8 on a ge modeljtp15wdw2ww
GE Range / Stove / Oven Fault Codes Failure Code Fault Code Description Solution F0 Stuck touch pad Usually means that either the touch pad or the oven control (also called clock or ERC) is defective and needs to be replaced. If this fault code cannot be cancelled, replace the oven control (also called clock or ERC), touch pad, or both. F1 Stuck touch pad Usually means that either the touch pad or the oven control (also called clock or ERC) is defective and needs to be replaced. If this fault code cannot be cancelled, replace the oven control (also called clock or ERC), touch pad, or both. F2
During
BAKE Control senses oven temperature above 615F-630F If actual over temperature condition occurred: Look for welded relay contacts on bake or broil relays. If this happens, replace oven control (also called clock or ERC).
If no over temperature condition occurred: Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace sensor if found defective.
Remember: Oven control (ERC) measures resistance of sensor circuit , not actual oven temperature. F2
During
CLEAN Control senses oven temperature above 915F-930F If actual over temperature condition occurred: Look for welded relay contacts. If this happens, replace oven control (also called clock or ERC).
If no over temperature condition occurred: Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace sensor if found defective. Check door lock switches.
Remember: Oven control (ERC) measures resistance of sensor circuit , not actual oven temperature. F3
or
F4 Open or shorted oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok. F5 Loss of relay drive circuit If this fault code cannot be cancelled, replace the oven control (also called clock or ERC). F8 Shorted meat probe Problem could be with the probe, the receptacle, or probe circuit. Check probe. Look for pinched wire. Look for condensation or contamination on probe receptacle. F9 Lock switch Check wiring to door lock switch (the wire harness may be connected wrong). Check for stuck lock switch. FC Problem with door lock circuit such as pinched wires between control and door lock switches on motorized lock circuits Check wiring and test operation of switches. FD Shorted meat probe Problem could be with the probe, the receptacle, or probe circuit. Check probe. Look for pinched wire. Look for condensation or contamination on probe receptacle. Replace probe if all else checks out ok. FF Loss of door motor safety switch Replace the oven control (also called clock or ERC). FFF Control error, failed EEPROM Replace the oven control board (also called clock or ERC).
The main control operates a series of software commands, which control the various features and functions of the oven. Each function or operation has a numerical value assigned to it. The numerical values can be added up - this is called the check sum operation. Every time the system is powered up and after each clean cycle the system performs a check sum and compares the value to the value programmed into the software (stored in memory).
An EEPROM check sum error or FFF code occurs when the values differ. If this happens, replace the oven control board (also called clock or ERC).Here is a list of error codes and corrective action that should be taken. Mike
Nov 23, 2009 | GE JTP15 Electric Single Oven
Ge gas oven goes to f2 and beeps when we set the oven over 375f. 400f guaranteed to go off. We replace the glow coil last year and it stopped but its back. We use the oven at 375f for the top temp. We...
HI, You will need to check the oven sensor wires that link the actual sensor to the main control board. Make sure that the contacts are connected properly, and not loose, or corroded. If all the wiring checks out, test the sensor for the correct resistance readings.(you will need a multimeter for this test)
The most common oven sensor should be approximately, 1100 ohms when at room temperature. The others may be close to as follows:
100°F - 1143 ohms
200°F - 1350 ohms
300°F - 1553 ohms
350°F - 1654 ohms
400°F - 1753 ohms
500°F - 1949 ohms
If the sensor test is adequate, and the wiring is Ok at the control, this will lead to a failed control board. replace the control in this case.
F2- Failed Oven temp sensor, or control board.
Concerning the glow ignitior.
When the bake igniter becomes weak or burns out, your oven will not bake. The bake igniter is usually mounted on the oven burner. It's about 1 inch by 4-8 inches (depending on the model), and comes in round or flat styles. If you don't see the igniter glow at all, it's probably burned out. Replace the igniter if found defective. Note: one of the exceptions could be that your oven is set to automatic mode instead of manual. If this is the case, set your oven to manual mode and check again.
If the bake igniter glows red and not bright yellow or white, it is probably because it is too weak. When this happens, the safety valve will not let the gas out into the oven burner. A weak igniter must be replaced.
Nov 12, 2009 | GE Ovens
How do I determine which is defective, the keypad or Main board? After the F9 code displayed I shut power off and disconnected the wiring strip from the main board to clear the system. The code returned...
Hello, If after removing the tape wire to the EOC the code returned your problem is with the EOC (electronic oven control) Your going to need to replace it. If you have any other questions please feel free to comment again. Mike
Oct 14, 2009 | GE Ovens
Aug 19, 2009 | GE JRP15 Electric Single Oven
Is it easy to replace the keypanel of the GE
Hello, The simple answer is yes it's not too hard...Normally you have a couple of screw located underneath the control panel. In most mordern ovens today they just consist of 2 components, the EOC (Electronic oven control) and the touch pad which basically cosists of everything you see(the whole panel). If you are replacing the touchpad..remove screws holding old panel in...pull wire harness from control board (dont worry where they go because the will only fit in one place) remove tape from EOC and relocate the control board to the new touchpad panel...reattach wire harness and tape in the new touchpad panel and hook back on oven ..screws in and your good to go. if replacing the control board (EOC) drop touch pad panel from oven and pull wires install new control then reassemble..easy!. One thing i would check though before purchasing the part, check to see it is the touchpad and not the control board...Here is how to do it...shut breaker off...pull out control panel...remove ribbon for key pad from EOC the re install panel..go switch breaker back on. leave for 24 hours..if within the 24 hours the error messages come back it's the EOC that is bad, if the error messages do not come back then you can be sure it's the touchpad. I would check this before buying the part since they are expencive and offten non returnable. Good Luck!! If you have any other questions or concerns please feel free to comment again. Thanks for using Fixya!! Mike
Jul 24, 2009 | GE Profile JKP56 Electric Double Oven
Feb 28, 2009 | GE 24" Built-In Single Gas Wall Oven
Ovens Logo
50 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
