Question about YouTube Videos
Odyssey please clear this area so I can get to the sight I want thank u
    New Friend:
Try helpin yhur self
Posted on Apr 20, 2013
What does the code 09-02 mean for my Honda/Odyssey 2007?
This is an SRS code. Go to the Honda owners sight an enter your VIN in recalls. it will show you any on your Odyssey.
Jul 29, 2014 | 2007 Honda Odyssey
2001 honda odyssey splash shield replace how to?
remove and put in a new one?
please be clear.
or did it fall off?
is it old or new. or broken.
we are blind here...
Sep 26, 2013 | 2002 Honda Odyssey
Where is the a/c sight glass in a 2004 odyssey
there is no sight glass on the newer cars you have to hook up a/c gauge to check charge
Aug 26, 2012 | 2004 Honda Odyssey
Where is the fuel filter located? Thanks
FUEL FILTER LOCATED UNDER HOOD AROUND FIREWALL AREA,FOLLOW FUEL LINES INLET LINES THEY WILL LEAD YOU BACK TOWARD FUEL FILTER.
Jul 13, 2011 | 1997 Honda Odyssey
I just got a 1997 HONDA ODYSSEY LX. and it will not tell me how fast I am going or what I have gone in miles none of it works. I need to check the speedometer but do not now how to check to see if the...
more than likely the VVS speed sensor. Its on the top back side of the trany, under the throttle body. if thats the problem, they are around $50 or less new.
Here is a good website on VVS speed sensors. Its the same on almost all Hondas within the 90s, even on Acuras. So this sight will be valid on most its info for your Odyssey.
http://techauto.awardspace.com/vss.html
May 18, 2011 | 1997 Honda Odyssey
Adjustment over rear lens,+o-
its for focusing the scope to your eye sight,,,if you have a good sight pitchure thats in clear foucas your lucky,,,to have good eyes,,for an old blind git like me i would need to adjust the eye foucase to fit my eye sight,, and you would look through it and say
"what the **** are you looking at i can see a thing through this now?" and turn the ring till you could see clearly again,,,,hope this helps,,
Nov 20, 2009 | Tasco Riflescope 3-9x40ir Wc39x40ir
Our 2005 Honda Odyssey had a check engine light / misfire
When a cylinder mis-fires there is a reason. The dealer should have told you that. Most likely you have a fouled out spark plug. Which means you need new spark plugs and maybe wires. All this would be covered in a standard tune up. Once the bad spark plug is replaced, the computer will quit registering a mis-fire. Please give good ratings, they meen a lot to us.... Thank you
Aug 01, 2009 | 2005 Honda Odyssey
Wiper runs upside down. Instead of clearing window clears below.
sounds like its loose on the shaft
remove & inspect shaft
may just need moving to original park position and retightening
Jul 17, 2009 | 2003 Honda Odyssey
I have a 2001 Honda Odyssey and the malfunction light came on after starting the car. The car was sitting in the garage in the morning. The light came on right after starting the car. What kind of problems...
it could be a 100 different problems.a good mechanic can hook up a scan tool and tell you exactly which system had the malfunction,and then recommend repairs. i would suggest letting a mechanic clear the codes and see if it comes back.
Apr 29, 2009 | 2001 Honda Odyssey
Honda Odyssey doors
I read about this issue while I was looking for a fix to mine. Try the following:
Remove fuse #13 for 30 seconds or more from the passenger side fusebox. This will reset the door and the clock.
OR
1.) Disable the power door switch on the left dashboard.
2.) Remove the power door fuses located under the front passenger leg area.
3.) Manually open and close both sliding doors.
4.) Restore the power door fuses located under the front passenger leg area.
5.) Enable the power door switch on the left dashboard.
6.) Try opening the sliding doors.
http://www.topix.com/forum/autos/honda-odyssey/TD1QRDMAQ28J8EDA0
Sep 03, 2008 | 2002 Honda Odyssey
YouTube Videos Logo
24 people viewed this question
Top YouTube Computers & Internet Experts
Rizwan Hanif
Level 1 Expert
LP
Are you a YouTube Computer and Internet Expert? Answer questions, earn points and help others
