Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Hard starting smokes white like gas is getting into cylinders
Hard to start if engine stops on top of compression stroke acts like gas on piston when it starts it'll smoke white than stops last time used had a miss under a load new plug oil filter cleaned
  • 13 Answers
White smoke in a small engine is oil. Oil in the cylinder will create too much pressure for the engine to achieve compression. Make sure the engine is not getting fuel into the oil and thinning the mixture (literally smell the oil... gasoline and oil smell nothing alike, if it smells like gas, it is). If this is the case, the carb is leaking fuel into the engine, thinning the oil and causing the oil to leak past the rings into the cylinder head, through the valves and, from there, into the exhaust to burn off. Black smoke indicates a direct fuel issue in a small engine, white is oil based.
Posted on Mar 14, 2009
Excessive white smoke from tail pipe
White smoke:
White smoke is caused by raw, un-burnt fuel passing into the exhaust stream. Common causes include:
·Incorrect fuel injection timing
·Defective fuel injectors
·Low cylinder compression
Low cylinder compression may be caused by leaking valves, sticking piston rings, ring wear, cylinder wear, or cylinder glaze. When white smoke occurs at cold start and then disappears as the engine warms up, the most common causes are fouling deposits around piston rings and/or cylinder glazing.
Continuous evidence of white smoke indicates a mechanical defect, or incorrect fuel timing.
Jan 25, 2015 | Chrysler PT Cruiser Cars & Trucks
Engine chugs, lots of white smoke
Smell your oil. If it smells gassy, your carb is stuck wide open-i mean the float stuck, allowing gas to run past the valves and into the block, causing the white/blu smoke. Did you fill the oil to the TOP of the dipstick??? Should be at the bottom. Just a couple of scenarios.
May 22, 2013 | Garden
Had problem with white smoke coming from tailpipe.addad diptaine to the tank and took van for a good spin.black smoke started coming from tailpipe. thought problem was solved,few days later coloured...
Don't know what car or engine you're writing about, but I'd recommend replacing the entire engine with a good used engine. White smoke usually comes from coolant in the engine (bad head gasket or cracked block/head). Fuel additives will do nothing to correct this. Low/no compression may be a piston ring, may be a holed piston, may be broken valves. You're going to pay someone to tear down the engine and they're going to find a lot more wrong than a bad piston ring. Just get another engine.
Sep 05, 2017 | Cars & Trucks
95 Mazda b2300
Sounds like there is unburnt fuel. Could be a spark plug that's burnt out and therefore just flooding a cylinder. Which would push out fuel through the exhaust valve on the exhaust stroke. So once the fuel hits the inside of the exhaust manifold, it burns white, as if you're boiling it off. That one cylinder could have a damaged compression ring on the piston, so the fuel is bypassing it and going into the oil.
I would have your engine tuned up, and check the compressions on the cylinders.
May 27, 2012 | Mazda Cars & Trucks
I have a 1998 Monte carlo z34 with a 3.8. changed the fuel pump, thermostat, fuel and air filter, and intake manifold gasket because of dissappearing anitfreeze and it was running rough.and having...
Dense white smoke usually means coolant is getting into the combustion chambers. If the engine then quit and will not easily turn over (as you described 'battery is dead'), you may have one or more cylinders hydraulically locked. There is coolant in the cylinder and the piston cannot come to the top on the compression stroke because water prevents it; air is compressible, water is not. Remove the spark plugs one by one and see if they are wet or very clean (steam cleaned). If so, you need to find why coolant is getting into that/those cylinders. Bad head gasket, cracked head, cracked block.
Apr 02, 2017 | 1998 Chevrolet Monte Carlo
Iv been working on a Subaru that my friend started and couldn't get running so he called me he replaced a burnt valve in the head and re installed it got it back together and no start. i got there...
if its firing 180 out you need to make sure when you set the timing its on the compression . when the piston is at the very top of the stroke The first one is the Intake stroke, the piston moves down the cylinder while the intake valve is open. Once the piston reaches the bottom of the intake stroke the intake valve closes. The next stroke is the Compression stroke, during this stroke all valves are closed and the piston moves back to the top of the cylinder compressing the air fuel mixture. Once the piston reaches the top you are starting the ignition stroke. With the piston at the top the spark plug fires igniting the compressed air fuel mixture forcing the piston back to the bottom of the cylinder. Once it reaches the bottom you begin the Exhaust stroke. The exhaust valves opens allowing the piston to rotate back to the top pushing out the burnt gases.
Jun 18, 2011 | Subaru Legacy Cars & Trucks
Have a B&S, Vanguard, 23HP motor, model 386777 with 300hrs on it. Motor starts and runs fairly well, but a fair amount of smoke is being emitted from air intake. Very evident with air cleaner removed....
sounds like you have a bad set of rings on one cylinder,or a bad valve set.
the stronger compression cylinder will burn richer due to the fact that the lower compression cylinder isnt pulling a hard enough vacumme to draw in all the fuel that is dumped into the intake.when the good cylinder makes it intake stroke it pulls in the excess fuel and a fresh amount from the carb.
im leaning more towards the valve train on the bad cylinder due to the white smoke comming from the carb,if the intake valve isnt seating properly,you will have compression escaping,back feeding through the intake.but yoy should hear a popping along with the smoke,everytime the engine fires that cylinder.
hope this info helps you.
4 stroke
#1 intake stroke
exhaust valve closed,intake valve open.as the piston is on its way to the bottom of the bore,it creates a vacumme.drawing in the air/fuel mixture from the carb.when the piston hits the bottom of its downward travel,the intake valve closes,then the next stroke comes into play.
#2 compression stroke
after drawing in the air fuel mixture,the intake and exhaust valve are both closed.the rotating momentium pushes the piston back up the cylinder,compressing the air/fuel into the cylinder.
#3 power stroke
(depending on the timing)when the cylinder reaches top dead center (tdc)in the bore.the spark plug ignites the fuel,which causes the air/fuel mix explode.that explosion forces the piston back down into the bore.when the piston travels down,this stroke is completed.
#4 exhaust stroke
after the power stroke,the piston then travels back up the bore,while opening the exhaust valve.the moving pistion then pushes the exhausted air through the exhaust chamber and out the muffler.
then the cycle starts over again.
so if you have a valve thats not seating properly,on compression stroke you will have loss of compression,on the power stroke,loss of power....forcing that ignited fuel back through the valve that isnt seated corectly(if intake) you will get white smoke and a poping sound from the carb.on the exhaust stroke it will sent exhausted air back through the intake aswell.
once again i hope this helps,id dig into the valve train on that cylinder.
nick
Sep 07, 2010 | Briggs & Stratton Briggs Stratton Vanguard...
Exhaust smokes when engine starts
Most common reason for that is worn valve stem seals and or guides or gunk buildup in the cylinder head blocking oil return holes.... Or, broken piston ring or burned piston lands. (use compression test to verify that) Knocking can be from oil detonating in cylinder or bad rod bearing etc.
Aug 01, 2009 | 2002 Suzuki XL-7
Do i have to mix 2 stroke oil on the gas for the 4 stroke bikes or just add regular gas on the tank? if is what is the scale for the mix?
DO NOT mix oil in the gas on your four stroke engine. You will foul the spark plug(s), build up deposits on the valves and head, and make a smokey, smelly mess. A two stroke engine uses the fuel/oil mix to lubricate the engine before being used as fuel. A four stroke engine has a separate lubrication system and does not normally burn any oil. As the name implies, a two stroke engine works in two strokes. The first stroke is downward, where the fuel/oil mix and air are drawn into the cylinder. The momentum from the crankshaft counterbalance or force from the other cylinder(s) drive the piston back up compressing the mix, and the spark plug sparks at or slightly before the top of the stroke. The rapid combustion of the fuel/oil/air mix drives the piston down, which is the power stroke, and then the cycle starts all over again. A four stroke engine has an intake stroke down taking in the fuel/air mix, a compression stroke up, a power stroke down as the fuel/air mix is ignited at or before the top of the stroke, and a exhaust stroke up before starting all over again. A four stroke is much cleaner and more reliable than a two stroke, but it is heavier and has less torque. A two stroke engine is much lighter and has more torque, but takes more maintenance.
Feb 28, 2009 | 2003 Yamaha YZ 250 F
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
931 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
