Turn on the component you wish to sync to your universal remote--your television, DVD player, VCR or stereo.
Point the remote at the device
you are programming and press the corresponding device button on the
remote. These buttons are labeled "TV," "VCR", "DVD," etc. Hold the
device button for three to five seconds.
Push the power button on the remote. This should turn on the device that you are syncing.
Push the "Channel Up" or "Channel Down" button on your remote gradually until the device that you are programming shuts off.
Press "OK" or "Enter" on the remote once the synced device turns off.
Press the device button for the
component you just programmed, and hit the power button while pointing
the remote at the component. If programmed correctly, the device should
turn on, and you should be able to control it with your Living Solutions
Universal Remote.
To help you reset Epson I200 Printer, please follow the step-by-step instructions as given below:
- Remember your printer should be switched ON and connected to the computer.
- Program 'WIC Reset Utility' can only be reset ink Level empty marked with a 'FUN'.
- After WIC Reset Utility open, select type of your epson printer.
- Then click on 'Reset Inks' and then click YES and now Click Done.
For additonal information, it is suggested to contact Epson Support Center for further assistance: http://www.epson.com/cgi-bin/Store/support/SupportIndex.jsp?oid=-16521
The cisco 3925 has 4 WIC slots and 2 SM slots - you can get a converter that turns SM into NM (SM-NM-ADPTR) and maybe even one that turns an SM into HWIC too I think (maybe SM-SLOT-DIVIDER, never used it myself) so I don't see the problem?
WIC Reset Utility is the only solution to the problem. Caution! WIC Interface uses Technical terms for settings and have many factory level setting options, which should not be disturbed by an end-user, so carefully use WIC only to reset INK Levels and Pad Counters. Better refer screenshots of WIC from internet before trying, me too have an L210, the solution is 100% sure and Applied, I am sure you will be thanking me..
Hi, thanks for reporting this issue, please answer the following and try the method after that: 1. What version of NET FRAMEWORK are you trying to install, the 4.0 or the 4.5? 2. With what browser are you trying to do that?
1. Use the CAL/ALM button to toggle the display until it shows the calendar
2. Press and hold SET until the screen flashes "12hr"
3. Use the UP (antenna) and DOWN (alarm) buttons to change the settings
4. Press SET to set the value
This mode will let you set the 12/24 hours clock, the time, date and year. You should be in the right time zone before you start.
B. To set the alarm1 time
1. Use the CAL/ALM button to toggle the display until it shows the AL1 alarm time
2. Press and hold SET until the alarm time flashes
C. To set the alarm2 time
1. Use the CAL/ALM button to toggle the display until it shows the AL2 alarm time
D. To turn on alarm1
2. Use the DOWN (alarm) button to toggle the alarm on and off (a bell appears on the screen)
E. To turn on alarm2
F. To have the atomic clock set automatically
1. Press and hold the UP (antenna) button until a little triangle flashes on the screen
2. Wait for clock to set
3. To give up waiting, press the UP (antenna) button again.
G. To change the time zone 1. Tap the ZONE button to toggle between the 4 time zones
