Question about Olympus FE-170 Digital Camera
My samsung l200 wont take pictures help
I push the button to take pics and nothing i put a brand new battery in it to
    New Friend:
Have you got an SD card in it?
Posted on Apr 20, 2013
SOURCE:
Camera shuts down after 1-2mins an does not take pics
Just to let you I had Moultire m-80 when I used a pny sd card it ruined my camera. They were kind enough to replace it for me. I just use what they recommended do not have any more problems. I only delete pic on my computer and not digital camera. Try doing a hard reset take everything out turn to the on position for about 2-3 minutes after 3 min put brand new battery's in it while on the on position should say no card at this time. If doesn't turn camera off put sandisk sdhc card in it. Test camera again if still not working Moultire will help you I have talked them great customer service.
Nov 26, 2013 | Moultrie Game Spy M-880
Turned on camara lens came out and wont go back in, pushed power button makes a sound but nothing happens
Have you tried changing the batteries with a brand new pair? I had the same problem once and it was because I had one old battery and one newer one.
Nov 06, 2010 | Samsung SL502 Digital Camera
Problems with the samsung camera. the screen is blank black!
Sounds like the ZIF connector for the screen or another part came loose. I will say it sounds like a hardware issues and I would strongly recommend looking into coverage via manufactures parts and repair coverage. About the picture folder not showing up, If your using the camera cord to attach it to the computer Make sure you turn the camera on after connecting, if the drive for the camera does not appeare in " Computer " I would say get a card reader for the SDHC cards and try to load the pictures through there.
Mar 13, 2010 | Samsung L200 Digital Camera
I pushed format on my camera just to see what it does. and all my pics and vids are lost! i kept reformatting and tuk 2 more pics but didnt save them. i am sooo scared they mite b lost. i just turned 14...
Format is used to clean everything off your memory card or memory device. Do not format until you have downloaded your pics.
I seems they are lost.
Jun 17, 2009 | Samsung L200 Digital Camera
Nikon coolpix s210 Not taking pictures
It sounds like you should try a new set of batteries in the camera. I have a similar camera and the flash is the first to go when the batteries are dying.
I hope this helps,
Eric
Jan 19, 2009 | Nikon Coolpix S210 Digital Camera
'File error' message on samsung L200 camera when viewing a photo
Possible solution:
I had/have the same problem using L200 and SDHC memory card, called Samsung. Can't view certain pictures on camera or computer, camera freezes when viewing those certain pictures, green light flashing.
Samsung support told me that I needed to copy my (good) pictures to a computer first because a memory format will erase everything. Then format (menu->settings->format->yes) my memory card. Tried this just now and took some new pictures, so far so good.
Jan 15, 2009 | Samsung L200 Digital Camera
Samsung l200 cant take more than 4 pictures
i just had this problem too! the way i fixed it was to:
press the review button click the menu (center) button go all the way to the right side "settings" area (a little cogged wheel and wrench) format the camera ---> yes reset the camera ---> yes
make sure you don't have any valuable pictures still on the camera, because this will delete them, override any of your previous settings (like no sound, or different sounds) and basically reset the camera to original factory settings.
this worked for me, so i hope it will work for you, too!
Dec 21, 2008 | Samsung L200 Digital Camera
My pictures are too big to load
You have two options:
First: use a picture management software to resize the pictures to a smaller resolution such as 640x480 pixels.
Second: reduce resolution on camera. The smallest resolution possible is 1024x768 on L200.
To do so in your Samsung L200, press Fn button. Then scrool up or down until you see SIZE on-screen. Press button to right until 1M appears, then press OK.
Oct 27, 2008 | Samsung L200 Digital Camera
Olympus FE-170 Digital Camera Logo
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you an Olympus Camera Expert? Answer questions, earn points and help others
