Question about Lite On LVW-5005X DVD Recorder
Liteon Dvd VCR Recorder tray has a disc in it but I cant open
The DVD portion has a disc in it but it will not open to remove. It will not eject. Liteon LVW-5005X R/W DVD will not open the drawer to eject the disc.
    New Friend:
  • 3 Answers
I have discovered the answer to this common problem (at least on my LVW-5006), it's to do with the little "turntable" which the disc sits on, it would have been made with a padded "ring" of felt or rubber etc. which was self adhesive and stuck onto the turntable, now if this ring comes unstuck you're just left with the adhesive which the disc and/or the weighted "press" above the disc will stick to (the latter when no disc is present). When you try to open the tray the mech tries to drop the whole laser/turntable assembly away from the disc to allow it out; but it's effectively "glued" to the upper assembly or the disc itself and that's when you hear the eject motor straining and squealing (and probably giving up!). Often a tap on the lid will free it but the best solution would be to replace the ring pad, although I suspect just removing the adhesive would work (I've noticed that cheap CD players don't even have such luxuries in the first place!) Hope this helps
Posted on Nov 29, 2014
  • 23 Answers
The door motor has weakened remove the dvd door, the unit ewill now opost and should work
Posted on Feb 17, 2013
  • 252 Answers
CLICK ON START
CLICK ON COMPUTER
RIGHT CLICK ON THE DRIVE IN QUESTION
CLICK ON EJECT
(MAY HAVE TO DO MORE THAN ONCE)
Posted on Mar 11, 2009
DVD-VR375 Disc Tray Won't Open
The disc ejection mechanism may have failed.
Apr 13, 2014 | Samsung DVD-VR375 DVD Recorder/VCR
Disc tray locked. Won't open
Remove Power, pry the tray outward with paperclip, Reapply power.
Dec 18, 2010 | Samsung DVD-VR320 DVD Recorder/VCR
Toshiba DVR19DTKB2 user manual
i have a dvr19dtkb2 video and dvd freeview recorder it has froze on channel 800 tried unplugging it still froze when turned back on can you help please
Oct 12, 2010 | Televison & Video
Can not eject tray to load DVD disc
the mechanism of your dvd are stucked up lubricate the moving parts and gears by using a small amoun of lubricating oil.to do it manually eject the loader by turning the gears by your hand..
May 17, 2010 | Televison & Video
Disc tray will not open on my Liteon dvd recorder
read user manual, unplug the device from mains cord...
remove the outer cover, check if the tray is strucked into it or else check the connection cable b/w them... If it still continues,then check out the motor used for tray open...
Apr 03, 2010 | Televison & Video
Liteon DVD recorder LVW-5045 has disc inside and won't open tray
Use your knuckles to knock on top of cabinet just above disc tray door while at the same time pressing open button,99% of the time disc tray will open.The problem you have is caused by a worn out belt drive or the tray is out of alignment.The disc tray belts only cost $2,when tray is open you can see the minature belt that controls door to the right.Use twizzers to remove and replace.Belt size 1.9
Aug 02, 2009 | Lite On LVW-5005X DVD Recorder
DVD door will not open
unplug for 5 min when you turn it back on and push eject wiggle the door a little with your finger at the same time
Dec 04, 2008 | Philips Magnavox DVD/VCR Dual Player
Govideo r6750 stuck tray
my 10 year old nephew forgot to take a disc out and inserted another this stopped the tray from opening i had to undo the screws holding the cover and remove them .Good luck p.s. don't forget to unplug firse
May 21, 2008 | GoVideo VR3845 DVD Recorder/VCR
Liteon DVD Player LVW-5115GHC+ Disk Tray stuck
The tray is either broken, or off track. You may be able to get it back on track by opening the cover and checking it out, but unplug it first, and only try this if warrantee is over and you're feeling brave...
Jan 27, 2008 | Lite On LVW-5115GHC+ DVD Recorder
Lite On LVW-5005X DVD Recorder Logo
587 people viewed this question
Top Lite On Televison & Video Experts
Jaime Hernandez
jason
Are you a Lite On Televison and Video Expert? Answer questions, earn points and help others
